All Classes Functions Variables Typedefs Friends Groups Pages
Witness complex
Functions
template<typename KNearestNeighbours , typename Point_random_access_range >
void Gudhi::witness_complex::landmark_choice_by_furthest_point (Point_random_access_range const &points, int nbL, KNearestNeighbours &knn)
 Landmark choice strategy by iteratively adding the furthest witness from the current landmark set as the new landmark. More...
void Gudhi::witness_complex::landmark_choice_by_random_point (Point_random_access_range const &points, int nbL, KNearestNeighbours &knn)
 Landmark choice strategy by taking random vertices for landmarks. More...
template<class KNearestNeighbors , class SimplicialComplexForWitness >
void Gudhi::witness_complex::witness_complex (KNearestNeighbors const &knn, int nbL, int dim, SimplicialComplexForWitness &sc)
 Iterative construction of the witness complex. More...
Detailed Description
Author
Siargey Kachanovich
Witness complex representation
Definitions
Witness complex $ Wit(W,L) $ is a simplicial complex defined on two sets of points in $\mathbb{R}^D$:
The simplices are based on landmarks and a simplex belongs to the witness complex if and only if it is witnessed, that is:
$ \sigma \subset L $ is witnessed if there exists a point $w \in W$ such that w is closer to the vertices of $ \sigma $ than other points in $ L $ and all of its faces are witnessed as well.
The data structure is described in [4] .
Implementation
The principal class of this module is Gudhi::Witness_complex.
In both cases, the constructor for this class takes a {witness}x{closest_landmarks} table, where each row represents a witness and consists of landmarks sorted by distance to this witness. This table can be constructed by two additional classes Landmark_choice_by_furthest_point and Landmark_choice_by_random_point also included in the module.
Running time as function on number of landmarks
Running time as function on number of witnesses for |L|=300
Function Documentation
void Gudhi::witness_complex::landmark_choice_by_furthest_point ( Point_random_access_range const &  points,
int  nbL,
KNearestNeighbours &  knn
It chooses nbL landmarks from a random access range points and writes {witness}*{closest landmarks} matrix in knn.
The type KNearestNeighbors can be seen as Witness_range<Closest_landmark_range<Vertex_handle>>, where Witness_range and Closest_landmark_range are random access ranges
void Gudhi::witness_complex::landmark_choice_by_random_point ( Point_random_access_range const &  points,
int  nbL,
It chooses nbL distinct landmarks from a random access range points and outputs a matrix {witness}*{closest landmarks} in knn.
The type KNearestNeighbors can be seen as Witness_range<Closest_landmark_range<Vertex_handle>>, where Witness_range and Closest_landmark_range are random access ranges and Vertex_handle is the label type of a vertex in a simplicial complex. Closest_landmark_range needs to have push_back operation.
Examples:
Witness_complex/witness_complex_from_file.cpp, and Witness_complex/witness_complex_sphere.cpp.
void Gudhi::witness_complex::witness_complex ( KNearestNeighbors const &  knn,
int  nbL,
int  dim,
SimplicialComplexForWitness &  sc
The witness complex is written in simplicial complex sc_ basing on a matrix knn of nearest neighbours of the form {witnesses}x{landmarks}.
The type KNearestNeighbors can be seen as Witness_range<Closest_landmark_range<Vertex_handle>>, where Witness_range and Closest_landmark_range are random access ranges.
Procedure takes into account at most (dim+1) first landmarks from each landmark range to construct simplices.
Landmarks are supposed to be in [0,nbL_-1]
Examples:
GUDHI  Version 1.3.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. Generated on Fri Apr 15 2016 17:36:21 for GUDHI by doxygen 1.8.6
