#define BOOST_PARAMETER_MAX_ARITY 12
#include <sys/types.h>
#include <sys/stat.h>
#include <gudhi/Simplex_tree.h>
#include <gudhi/Witness_complex.h>
#include <gudhi/Landmark_choice_by_random_point.h>
#include <gudhi/reader_utils.h>
#include <iostream>
#include <fstream>
#include <ctime>
#include <utility>
#include <string>
#include <vector>
#include "generators.h"
template < typename Data_range >
void write_data(Data_range & data, std::string filename) {
std::ofstream ofs(filename, std::ofstream::out);
for (auto entry : data)
ofs << entry.first << ", " << entry.second << "\n";
ofs.close();
int main(int argc, char * const argv[]) {
if (argc != 2) {
std::cerr << "Usage: " << argv[0]
<< " number_of_landmarks \n";
return 0;
int number_of_landmarks = atoi(argv[1]);
clock_t start, end;
std::vector< std::pair<int, double> > l_time;
for (int nbP = 500; nbP < 10000; nbP += 500) {
Point_Vector point_vector;
generate_points_sphere(point_vector, nbP, 4);
std::cout << "Successfully generated " << point_vector.size() << " points.\n";
std::cout << "Ambient dimension is " << point_vector[0].size() << ".\n";
start = clock();
std::vector<std::vector< int > > knn;
end = clock();
double time = static_cast<double>(end - start) / CLOCKS_PER_SEC;
std::cout << "Witness complex for " << number_of_landmarks << " landmarks took "
<< time << " s. \n";
std::cout <<
"Number of simplices is: " << simplex_tree.
num_simplices() <<
"\n";
l_time.push_back(std::make_pair(nbP, time));
write_data(l_time, "w_time.dat");
