All Classes Functions Variables Typedefs Friends Groups Pages
Gudhi::alphacomplex::Alpha_complex< Kernel > Class Template Reference
Alpha complex data structure. More...
#include <gudhi/Alpha_complex.h>
Public Types
typedef
CGAL::Delaunay_triangulation
< Kernel, TDS >
 A Delaunay triangulation of a set of points in $ \mathbb{R}^D$.
typedef Kernel::Point_d Point_d
 A point in Euclidean space.
typedef Kernel Geom_traits
 Geometric traits class that provides the geometric types and predicates needed by Delaunay triangulations.
- Public Types inherited from Gudhi::Simplex_tree<>
typedef Options::Filtration_value Filtration_value
 Type for the value of the filtration function. More...
typedef Options::Simplex_key Simplex_key
 Key associated to each simplex. More...
typedef Options::Vertex_handle Vertex_handle
 Type for the vertex handle. More...
typedef Dictionary::iterator Simplex_handle
 Handle type to a simplex contained in the simplicial complex represented by the simplex tree.
typedef
boost::transform_iterator
< return_first, Dictionary_it >
Complex_vertex_iterator
 Iterator over the vertices of the simplicial complex. More...
typedef boost::iterator_range
< Complex_vertex_iterator >
Complex_vertex_range
 Range over the vertices of the simplicial complex.
typedef
Simplex_tree_simplex_vertex_iterator
< Simplex_tree >
Simplex_vertex_iterator
 Iterator over the vertices of a simplex. More...
< Simplex_vertex_iterator >
Simplex_vertex_range
 Range over the vertices of a simplex.
typedef std::vector
< Simplex_handle >
Cofaces_simplex_range
 Range over the cofaces of a simplex.
typedef
Simplex_tree_boundary_simplex_iterator
< Simplex_tree >
Boundary_simplex_iterator
 Iterator over the simplices of the boundary of a simplex. More...
< Boundary_simplex_iterator >
Boundary_simplex_range
 Range over the simplices of the boundary of a simplex.
typedef
Simplex_tree_complex_simplex_iterator
< Simplex_tree >
Complex_simplex_iterator
 Iterator over the simplices of the simplicial complex. More...
< Complex_simplex_iterator >
Complex_simplex_range
 Range over the simplices of the simplicial complex.
typedef
Simplex_tree_skeleton_simplex_iterator
< Simplex_tree >
Skeleton_simplex_iterator
 Iterator over the simplices of the skeleton of the simplicial complex, for a given dimension. More...
< Skeleton_simplex_iterator >
Skeleton_simplex_range
 Range over the simplices of the skeleton of the simplicial complex, for a given dimension.
typedef std::vector
< Simplex_handle >
Filtration_simplex_range
 Range over the simplices of the simplicial complex, ordered by the filtration.
typedef
Filtration_simplex_range::const_iterator
Filtration_simplex_iterator
 Iterator over the simplices of the simplicial complex, ordered by the filtration. More...
Public Member Functions
 Alpha_complex (const std::string &off_file_name, Filtration_value max_alpha_square=std::numeric_limits< Filtration_value >::infinity())
 Alpha_complex constructor from an OFF file name. Uses the Delaunay_triangulation_off_reader to construct the Delaunay triangulation required to initialize the Alpha_complex. More...
template<typename InputPointRange >
 Alpha_complex (const InputPointRange &points, Filtration_value max_alpha_square=std::numeric_limits< Filtration_value >::infinity())
 Alpha_complex constructor from a list of points. More...
 ~Alpha_complex ()
 Alpha_complex destructor. More...
Point_d get_point (Vertex_handle vertex) const
 get_point returns the point corresponding to the vertex given as parameter. More...
- Public Member Functions inherited from Gudhi::Simplex_tree<>
bool operator== (Simplex_tree &st2)
 Checks if two simplex trees are equal.
bool operator!= (Simplex_tree &st2)
 Checks if two simplex trees are different.
Simplex_handle simplex (Simplex_key key) const
 Returns the simplex associated to a key. More...
Filtration_value filtration () const
 Returns an upper bound of the filtration values of the simplices.
void assign_filtration (Simplex_handle sh, Filtration_value fv)
 Sets the filtration value of a simplex.
Exceptions
std::invalid_argumentIn debug mode, if sh is a null_simplex.
Vertex_handle null_vertex () const
 Returns a Vertex_handle different from all Vertex_handles associated to the vertices of the simplicial complex.
size_t num_vertices () const
 Returns the number of vertices in the complex.
size_t num_simplices ()
 returns the number of simplices in the simplex_tree.
int dimension (Simplex_handle sh)
 Returns the dimension of a simplex. More...
int dimension () const
 Returns an upper bound on the dimension of the simplicial complex.
bool has_children (SimplexHandle sh) const
 Returns true if the node in the simplex tree pointed by sh has children.
Simplex_handle find (const InputVertexRange &s)
 Given a range of Vertex_handles, returns the Simplex_handle of the simplex in the simplicial complex containing the corresponding vertices. Return null_simplex() if the simplex is not in the complex. More...
std::pair< Simplex_handle, bool > insert_simplex (const InputVertexRange &simplex, Filtration_value filtration=0)
 Insert a simplex, represented by a range of Vertex_handles, in the simplicial complex. More...
std::pair< Simplex_handle, bool > insert_simplex_and_subfaces (const InputVertexRange &Nsimplex, Filtration_value filtration=0)
 Insert a N-simplex and all his subfaces, from a N-simplex represented by a range of Vertex_handles, in the simplicial complex. More...
void assign_key (Simplex_handle sh, Simplex_key key)
 Assign a value 'key' to the key of the simplex represented by the Simplex_handle 'sh'.
Simplex_handle >
endpoints (Simplex_handle sh)
Siblings * self_siblings (SimplexHandle sh)
Siblings * root ()
void set_filtration (Filtration_value fil)
void set_dimension (int dimension)
void initialize_filtration ()
 Initializes the filtrations, i.e. sort the simplices according to their order in the filtration and initializes all Simplex_keys. More...
Cofaces_simplex_range star_simplex_range (const Simplex_handle simplex)
 Compute the star of a n simplex. More...
Cofaces_simplex_range cofaces_simplex_range (const Simplex_handle simplex, int codimension)
 Compute the cofaces of a n simplex. More...
void insert_graph (const OneSkeletonGraph &skel_graph)
 Inserts a 1-skeleton in an empty Simplex_tree. More...
void expansion (int max_dim)
 Expands the Simplex_tree containing only its one skeleton until dimension max_dim. More...
void print_hasse (std::ostream &os)
 Write the hasse diagram of the simplicial complex in os. More...
bool make_filtration_non_decreasing ()
 Browse the simplex tree to ensure the filtration is not decreasing. The simplex tree is browsed starting from the root until the leaf, and the filtration values are set with their parent value (increased), in case the values are decreasing. More...
bool prune_above_filtration (Filtration_value filtration)
 Prune above filtration value given as parameter. More...
void remove_maximal_simplex (Simplex_handle sh)
 Remove a maximal simplex. More...
Complex_vertex_range complex_vertex_range ()
 Returns a range over the vertices of the simplicial complex. The order is increasing according to < on Vertex_handles.
Complex_simplex_range complex_simplex_range ()
 Returns a range over the simplices of the simplicial complex. More...
Skeleton_simplex_range skeleton_simplex_range (int dim)
 Returns a range over the simplices of the dim-skeleton of the simplicial complex. More...
Filtration_simplex_range const & filtration_simplex_range (Indexing_tag=Indexing_tag())
 Returns a range over the simplices of the simplicial complex, in the order of the filtration. More...
Simplex_vertex_range simplex_vertex_range (Simplex_handle sh)
 Returns a range over the vertices of a simplex. More...
Boundary_simplex_range boundary_simplex_range (SimplexHandle sh)
 Returns a range over the simplices of the boundary of a simplex. More...
 Simplex_tree ()
 Constructs an empty simplex tree.
 Simplex_tree (const Simplex_tree &simplex_source)
 User-defined copy constructor reproduces the whole tree structure.
 Simplex_tree (Simplex_tree &&old)
 User-defined move constructor moves the whole tree structure.
void rec_copy (Siblings *sib, Siblings *sib_source)
 depth first search, inserts simplices when reaching a leaf.
 ~Simplex_tree ()
 Destructor; deallocates the whole tree structure.
Additional Inherited Members
- Static Public Member Functions inherited from Gudhi::Simplex_tree<>
static Simplex_key key (Simplex_handle sh)
 Returns the key associated to a simplex. More...
static Filtration_value filtration (Simplex_handle sh)
 Returns the filtration value of a simplex. More...
static Simplex_handle null_simplex ()
 Returns a Simplex_handle different from all Simplex_handles associated to the simplices in the simplicial complex. More...
static Simplex_key null_key ()
 Returns a key different for all keys associated to the simplices of the simplicial complex.
Detailed Description
template<class Kernel = CGAL::Epick_d<CGAL::Dynamic_dimension_tag>>
class Gudhi::alphacomplex::Alpha_complex< Kernel >
The data structure can be constructed from a CGAL Delaunay triangulation (for more informations on CGAL Delaunay triangulation, please refer to the corresponding chapter in page http://doc.cgal.org/latest/Triangulation/) or from an OFF file (cf. Points_off_reader).
Please refer to Alpha complex for examples.
The complex is a template class requiring an Epick_d dD Geometry Kernel [16] from CGAL as template, default value is CGAL::Epick_d < CGAL::Dynamic_dimension_tag >
Remarks
When Alpha_complex is constructed with an infinite value of alpha, the complex is a Delaunay complex.
Examples:
Alpha_complex/Alpha_complex_from_off.cpp, Alpha_complex/Alpha_complex_from_points.cpp, and Persistent_cohomology/alpha_complex_persistence.cpp.
Constructor & Destructor Documentation
Gudhi::alphacomplex::Alpha_complex< Kernel >::Alpha_complex ( const std::string &  off_file_name,
Filtration_value  max_alpha_square = std::numeric_limits<Filtration_value>::infinity()
inline
Duplicate points are inserted once in the Alpha_complex. This is the reason why the vertices may be not contiguous.
Parameters
[in]off_file_nameOFF file [path and] name.
[in]max_alpha_squaremaximum for alpha square value. Default value is + $\infty$.
Gudhi::alphacomplex::Alpha_complex< Kernel >::Alpha_complex ( const InputPointRange &  points,
inline
Parameters
[in]pointsRange of points to triangulate. Points must be in Kernel::Point_d
The type InputPointRange must be a range for which std::begin and std::end return input iterators on a Kernel::Point_d.
Postcondition
Compare num_simplices with InputPointRange points number (not the same in case of duplicate points).
Gudhi::alphacomplex::Alpha_complex< Kernel >::~Alpha_complex ( )
inline
Warning
Deletes the Delaunay triangulation.
Member Function Documentation
Point_d Gudhi::alphacomplex::Alpha_complex< Kernel >::get_point ( Vertex_handle  vertex) const
inline
Parameters
[in]vertexVertex handle of the point to retrieve.
Returns
The point found.
Exceptions
std::out_of_rangeIn case vertex is not found (cf. std::vector::at).
The documentation for this class was generated from the following file:
GUDHI  Version 1.3.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. Generated on Fri Apr 15 2016 17:36:21 for GUDHI by doxygen 1.8.6
