#include <CGAL/Epick_d.h>
#include <gudhi/Alpha_complex.h>
#include <iostream>
#include <string>
#include <vector>
#include <limits>
typedef CGAL::Epick_d< CGAL::Dimension_tag<2> > Kernel;
typedef Kernel::Point_d Point;
typedef std::vector<Point> Vector_of_points;
void usage(int nbArgs, char * const progName) {
std::cerr << "Error: Number of arguments (" << nbArgs << ") is not correct\n";
std::cerr << "Usage: " << progName << " [alpha_square_max_value]\n";
std::cerr << " i.e.: " << progName << " 60.0\n";
exit(-1);
int main(int argc, char **argv) {
if ((argc != 1) && (argc != 2)) usage(argc, (argv[0] - 1));
double alpha_square_max_value = std::numeric_limits<double>::infinity();
if (argc == 2)
alpha_square_max_value = atof(argv[1]);
Vector_of_points points;
points.push_back(Point(1.0, 1.0));
points.push_back(Point(7.0, 0.0));
points.push_back(Point(4.0, 6.0));
points.push_back(Point(9.0, 6.0));
points.push_back(Point(0.0, 14.0));
points.push_back(Point(2.0, 19.0));
points.push_back(Point(9.0, 17.0));
std::cout << "Alpha complex is of dimension " << alpha_complex_from_points.dimension() <<
" - " << alpha_complex_from_points.num_simplices() << " simplices - " <<
alpha_complex_from_points.num_vertices() << " vertices." << std::endl;
std::cout << "Iterator on alpha complex simplices in the filtration order, with [filtration value]:" << std::endl;
for (auto f_simplex : alpha_complex_from_points.filtration_simplex_range()) {
std::cout << " ( ";
for (auto vertex : alpha_complex_from_points.simplex_vertex_range(f_simplex)) {
std::cout << vertex << " ";
std::cout << ") -> " << "[" << alpha_complex_from_points.filtration(f_simplex) << "] ";
std::cout << std::endl;
return 0;
