Gudhi  1.1.0
 All Classes Functions Typedefs Friends Groups Pages
Public Types | Public Member Functions | List of all members
Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle > Class Template Reference
Simplex Tree data structure for representing simplicial complexes. More...
#include <Simplex_tree.h>
Public Types
typedef FiltrationValue Filtration_value
 Type for the value of the filtration function. More...
typedef SimplexKey Simplex_key
 Key associated to each simplex. More...
typedef VertexHandle Vertex_handle
 Type for the vertex handle. More...
typedef Dictionary::iterator Simplex_handle
 Handle type to a simplex contained in the simplicial complex represented byt he simplex tree.
Range and iterator types
The naming convention is Container_content_(iterator/range). A Container_content_range is essentially an object on which the methods begin() and end() can be called. They both return an object of type Container_content_iterator, and allow the traversal of the range [ begin();end() ).
typedef
boost::transform_iterator
< return_first, Dictionary_it >
Complex_vertex_iterator
 Iterator over the vertices of the simplicial complex. More...
typedef boost::iterator_range
< Complex_vertex_iterator >
Complex_vertex_range
 Range over the vertices of the simplicial complex.
typedef
Simplex_tree_simplex_vertex_iterator
< Simplex_tree >
Simplex_vertex_iterator
 Iterator over the vertices of a simplex. More...
< Simplex_vertex_iterator >
Simplex_vertex_range
 Range over the vertices of a simplex.
typedef
Simplex_tree_boundary_simplex_iterator
< Simplex_tree >
Boundary_simplex_iterator
 Iterator over the simplices of the boundary of a simplex. More...
< Boundary_simplex_iterator >
Boundary_simplex_range
 Range over the simplices of the boundary of a simplex.
typedef
Simplex_tree_complex_simplex_iterator
< Simplex_tree >
Complex_simplex_iterator
 Iterator over the simplices of the simplicial complex. More...
< Complex_simplex_iterator >
Complex_simplex_range
 Range over the simplices of the simplicial complex.
typedef
Simplex_tree_skeleton_simplex_iterator
< Simplex_tree >
Skeleton_simplex_iterator
 Iterator over the simplices of the skeleton of the simplicial complex, for a given dimension. More...
< Skeleton_simplex_iterator >
Skeleton_simplex_range
 Range over the simplices of the skeleton of the simplicial complex, for a given dimension.
typedef std::vector
< Simplex_handle >::iterator
Filtration_simplex_iterator
 Iterator over the simplices of the simplicial complex, ordered by the filtration. More...
< Filtration_simplex_iterator >
Filtration_simplex_range
 Range over the simplices of the simplicial complex, ordered by the filtration.
- Public Types inherited from FilteredComplex
typedef unspecified Simplex_handle
typedef unspecified Simplex_key
typedef unspecified Filtration_value
typedef unspecified Indexing_tag
 Specifies the nature of the indexing scheme. More...
typedef unspecified Boundary_simplex_iterator
 Iterator on the simplices belonging to the boundary of a simplex. More...
typedef unspecified Boundary_simplex_range
 Range giving access to the simplices in the boundary of a simplex. More...
typedef unspecified Filtration_simplex_iterator
 Iterator over all simplices of the complex in the order of the indexing scheme. More...
typedef unspecified Filtration_simplex_range
 Range over the simplices of the complex in the order of the filtration. More...
Simplex_key key (Simplex_handle sh)
 Returns the key associated to a simplex. More...
Simplex_handle simplex (Simplex_key key)
 Returns the simplex associated to a key. More...
Filtration_value filtration (Simplex_handle sh)
 Returns the filtration value of a simplex. More...
Filtration_value filtration ()
 Returns an upper bound of the filtration values of the simplices.
Simplex_handle null_simplex ()
 Returns a Simplex_handle different from all Simplex_handles associated to the simplices in the simplicial complex. More...
Simplex_key null_key ()
 Returns a key different for all keys associated to the simplices of the simplicial complex.
Vertex_handle null_vertex ()
 Returns a Vertex_handle different from all Vertex_handles associated to the vertices of the simplicial complex.
size_t num_vertices ()
 Returns the number of vertices in the complex.
const unsigned int & num_simplices () const
 Returns the number of simplices in the complex. More...
int dimension (Simplex_handle sh)
 Returns the dimension of a simplex. More...
int dimension ()
 Returns an upper bound on the dimension of the simplicial complex.
bool has_children (Simplex_handle sh)
 Returns true iff the node in the simplex tree pointed by sh has children.
template<class RandomAccessVertexRange >
Simplex_handle find (const RandomAccessVertexRange &s)
 Given a range of Vertex_handles, returns the Simplex_handle of the simplex in the simplicial complex containing the corresponding vertices. Return null_simplex() if the simplex is not in the complex. More...
Simplex_handle find_vertex (Vertex_handle v)
 Returns the Simplex_handle corresponding to the 0-simplex representing the vertex with Vertex_handle v.
std::pair< Simplex_handle, bool > insert (RandomAccessVertexRange &simplex, Filtration_value filtration)
 Insert a simplex, represented by a range of Vertex_handles, in the simplicial complex. More...
void assign_key (Simplex_handle sh, Simplex_key key)
 Assign a value 'key' to the key of the simplex represented by the Simplex_handle 'sh'.
Simplex_handle >
endpoints (Simplex_handle sh)
Siblings * self_siblings (Simplex_handle sh)
Siblings * root ()
void set_filtration (Filtration_value fil)
void set_num_simplices (const unsigned int &num_simplices)
void set_dimension (int dimension)
void initialize_filtration ()
 Initializes the filtrations, i.e. sort the simplices according to their order in the filtration and initializes all Simplex_keys. More...
template<class OneSkeletonGraph >
void insert_graph (const OneSkeletonGraph &skel_graph)
 Inserts a 1-skeleton in an empty Simplex_tree. More...
void expansion (int max_dim)
 Expands the Simplex_tree containing only its one skeleton until dimension max_dim. More...
void print_hasse (std::ostream &os)
 Write the hasse diagram of the simplicial complex in os. More...
Range and iterator methods
Complex_vertex_range complex_vertex_range ()
 Returns a range over the vertices of the simplicial complex. More...
Complex_simplex_range complex_simplex_range ()
 Returns a range over the simplices of the simplicial complex. More...
Skeleton_simplex_range skeleton_simplex_range (int dim)
 Returns a range over the simplices of the dim-skeleton of the simplicial complex. More...
Filtration_simplex_range filtration_simplex_range (linear_indexing_tag)
 Returns a range over the simplices of the simplicial complex, in the order of the filtration. More...
Filtration_simplex_range filtration_simplex_range ()
Simplex_vertex_range simplex_vertex_range (Simplex_handle sh)
 Returns a range over the vertices of a simplex. More...
Boundary_simplex_range boundary_simplex_range (Simplex_handle sh)
 Returns a range over the simplices of the boundary of a simplex. More...
Constructor/Destructor
 Simplex_tree ()
 Constructs an empty simplex tree.
 ~Simplex_tree ()
 Destructor; deallocates the whole tree structure.
- Public Member Functions inherited from FilteredComplex
size_t num_simplices ()
 Returns a key that is different from the keys associated to the simplices.
 Assign a key to a simplex.
 Returns a range giving access to all simplices of the boundary of a simplex, i.e. the set of codimension 1 subsimplices of the Simplex. More...
 Returns a range over the simplices of the complex in the order of the filtration. More...
Detailed Description
template<typename IndexingTag = linear_indexing_tag, typename FiltrationValue = double, typename SimplexKey = int, typename VertexHandle = int>
class Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >
Every simplex $[v_0, \cdots ,v_d]$ admits a canonical orientation induced by the order relation on vertices $ v_0 < \cdots < v_d $.
Details may be found in [4].
Member Typedef Documentation
typedef Simplex_tree_boundary_simplex_iterator<Simplex_tree> Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::Boundary_simplex_iterator
'value_type' is Simplex_handle.
typedef Simplex_tree_complex_simplex_iterator<Simplex_tree> Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::Complex_simplex_iterator
typedef boost::transform_iterator<return_first, Dictionary_it> Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::Complex_vertex_iterator
'value_type' is Vertex_handle.
typedef std::vector<Simplex_handle>::iterator Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::Filtration_simplex_iterator
typedef FiltrationValue Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::Filtration_value
Must be comparable with <.
typedef SimplexKey Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::Simplex_key
Must be a signed integer type.
typedef Simplex_tree_simplex_vertex_iterator<Simplex_tree> Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::Simplex_vertex_iterator
typedef Simplex_tree_skeleton_simplex_iterator<Simplex_tree> Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::Skeleton_simplex_iterator
typedef VertexHandle Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::Vertex_handle
Must be a signed integer type. It admits a total order <.
Member Function Documentation
Boundary_simplex_range Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::boundary_simplex_range ( Simplex_handle  sh)
inline
The boundary of a simplex is the set of codimension $1$ subsimplices of the simplex. If the simplex is $[v_0, \cdots ,v_d]$, with canonical orientation induced by $ v_0 < \cdots < v_d $, the iterator enumerates the simplices of the boundary in the order: $[v_0,\cdots,\widehat{v_i},\cdots,v_d]$ for $i$ from $0$ to $d$, where $\widehat{v_i}$ means that the vertex $v_i$ is omitted.
We note that the alternate sum of the simplices given by the iterator gives $(-1)^{\text{dim} \sigma}$ the chains corresponding to the boundary of the simplex.
Parameters
[in]shSimplex for which the boundary is computed.
Complex_simplex_range Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::complex_simplex_range ( )
inline
In the Simplex_tree, the tree is traverse in a depth-first fashion. Consequently, simplices are ordered according to lexicographic order on the list of Vertex_handles of a simplex, read in increasing < order for Vertex_handles.
Complex_vertex_range Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::complex_vertex_range ( )
inline
The order is increasing according to < on Vertex_handles.
int Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::dimension ( Simplex_handle  sh)
inline
Must be different from null_simplex().
std::pair<Simplex_handle, Simplex_handle> Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::endpoints ( Simplex_handle  sh)
inline
Returns the two Simplex_handle corresponding to the endpoints of and edge. sh must point to a 1-dimensional simplex. This is an optimized version of the boundary computation.
void Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::expansion ( int  max_dim)
inline
The expanded simplicial complex until dimension $d$ attached to a graph $G$ is the maximal simplicial complex of dimension at most $d$ admitting the graph $G$ as $1$-skeleton. The filtration value assigned to a simplex is the maximal filtration value of one of its edges.
The Simplex_tree must contain no simplex of dimension bigger than 1 when calling the method.
Filtration_value Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::filtration ( Simplex_handle  sh)
inline
Called on the null_simplex, returns INFINITY.
Filtration_simplex_range Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::filtration_simplex_range ( linear_indexing_tag  )
inline
The filtration is a monotonic function $ f: \mathbf{K} \rightarrow \mathbb{R} $, i.e. if two simplices $\tau$ and $\sigma$ satisfy $\tau \subseteq \sigma$ then $f(\tau) \leq f(\sigma)$.
The method returns simplices ordered according to increasing filtration values. Ties are resolved by considering inclusion relation (subsimplices appear before their cofaces). If two simplices have same filtration value but are not comparable w.r.t. inclusion, lexicographic order is used.
The filtration must be valid. If the filtration has not been initialized yet, the method initializes it (i.e. order the simplices).
Simplex_handle Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::find ( const RandomAccessVertexRange &  s)
inline
The type RandomAccessVertexRange must be a range for which .begin() and .end() return random access iterators, with value_type Vertex_handle.
void Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::initialize_filtration ( )
inline
After calling this method, filtration_simplex_range() becomes valid, and each simplex is assigned a Simplex_key corresponding to its order in the filtration (from 0 to m-1 for a simplicial complex with m simplices).
The use of a depth-first traversal of the simplex tree, provided by complex_simplex_range(), combined with a stable sort is meant to optimize the order of simplices with same filtration value. The heuristic consists in inserting the cofaces of a simplex as soon as possible.
Will be automatically called when calling filtration_simplex_range() if the filtration has never been initialized yet.
std::pair<Simplex_handle, bool> Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::insert ( RandomAccessVertexRange &  simplex,
inline
Parameters
[in]simplexrange of Vertex_handles, representing the vertices of the new simplex
[in]filtrationthe filtration value assigned to the new simplex. The return type is a pair. If the new simplex is inserted successfully (i.e. it was not in the simplicial complex yet) the bool is set to true and the Simplex_handle is the handle assigned to the new simplex. If the insertion fails (the simplex is already there), the bool is set to false. If the insertion fails and the simplex already in the complex has a filtration value strictly bigger than 'filtration', we assign this simplex with the new value 'filtration', and set the Simplex_handle filed of the output pair to the Simplex_handle of the simplex. Otherwise, we set the Simplex_handle part to null_simplex.
All subsimplices do not necessary need to be already in the simplex tree to proceed to an insertion. However, the property of being a simplicial complex will be violated. This allows us to insert a stream of simplices contained in a simplicial complex without considering any order on them.
The filtration value assigned to the new simplex must preserve the monotonicity of the filtration.
The type RandomAccessVertexRange must be a range for which .begin() and .end() return random access iterators, with 'value_type' Vertex_handle.
void Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::insert_graph ( const OneSkeletonGraph &  skel_graph)
inline
The Simplex_tree must contain no simplex when the method is called.
Inserts all vertices and edges given by a OneSkeletonGraph. OneSkeletonGraph must be a model of boost::AdjacencyGraph, boost::EdgeListGraph and boost::PropertyGraph.
The vertex filtration value is accessible through the property tag vertex_filtration_t. The edge filtration value is accessible through the property tag edge_filtration_t.
boost::graph_traits<OneSkeletonGraph>::vertex_descriptor must be Vertex_handle. boost::graph_traits<OneSkeletonGraph>::directed_category must be undirected_tag.
Simplex_key Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::key ( Simplex_handle  sh)
inline
The filtration must be initialized.
Simplex_handle Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::null_simplex ( )
inline
One can call filtration(null_simplex()).
const unsigned int& Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::num_simplices ( ) const
inline
Does not count the empty simplex.
void Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::print_hasse ( std::ostream &  os)
inline
Each row in the file correspond to a simplex. A line is written: dim idx_1 ... idx_k fil where dim is the dimension of the simplex, idx_1 ... idx_k are the row index (starting from 0) of the simplices of the boundary of the simplex, and fil is its filtration value.
Siblings* Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::root ( )
inline
Returns a pointer to the root nodes of the simplex tree.
Siblings* Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::self_siblings ( Simplex_handle  sh)
inline
Returns the Siblings containing a simplex.
void Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::set_dimension ( int  dimension)
inline
Set a dimension for the simplicial complex.
void Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::set_filtration ( Filtration_value  fil)
inline
Set an upper bound for the filtration values.
void Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::set_num_simplices ( const unsigned int &  num_simplices)
inline
Set a number of simplices for the simplicial complex.
Simplex_handle Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::simplex ( Simplex_key  key)
inline
Simplex_vertex_range Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::simplex_vertex_range ( Simplex_handle  sh)
inline
The order in which the vertices are visited is the decreasing order for < on Vertex_handles, which is consequenlty equal to $(-1)^{\text{dim} \sigma}$ the canonical orientation on the simplex.
Skeleton_simplex_range Gudhi::Simplex_tree< IndexingTag, FiltrationValue, SimplexKey, VertexHandle >::skeleton_simplex_range ( int  dim)
inline
The $d$-skeleton of a simplicial complex $\mathbf{K}$ is the simplicial complex containing the simplices of $\mathbf{K}$ of dimension at most $d$.
Parameters
[in]dimThe maximal dimension of the simplices in the skeleton.
The simplices are ordered according to lexicographic order on the list of Vertex_handles of a simplex, read in increasing < order for Vertex_handles.
The documentation for this class was generated from the following file:
