Gudhi  1.1.0
 All Classes Functions Typedefs Friends Groups Pages
Public Types | Public Member Functions | List of all members
FilteredComplex Struct Reference
The concept FilteredComplex describes the requirements for a type to implement a filtered cell complex, from which one can compute persistent homology via a model of the concept PersistentHomology. More...
#include <FilteredComplex.h>
Public Types
typedef unspecified Simplex_handle
typedef unspecified Simplex_key
 Key associated to each simplex. More...
typedef unspecified Filtration_value
 Type for the value of the filtration function. More...
typedef unspecified Indexing_tag
 Specifies the nature of the indexing scheme. More...
typedef unspecified Boundary_simplex_iterator
 Iterator on the simplices belonging to the boundary of a simplex. More...
typedef unspecified Boundary_simplex_range
 Range giving access to the simplices in the boundary of a simplex. More...
typedef unspecified Filtration_simplex_iterator
 Iterator over all simplices of the complex in the order of the indexing scheme. More...
typedef unspecified Filtration_simplex_range
 Range over the simplices of the complex in the order of the filtration. More...
Simplex_handle null_simplex ()
size_t num_simplices ()
 Returns the number of simplices in the complex. More...
int dimension (Simplex_handle sh)
 Returns the dimension of a simplex.
Filtration_value filtration (Simplex_handle sh)
 Returns the filtration value of a simplex. More...
Simplex_key null_key ()
 Returns a key that is different from the keys associated to the simplices.
Simplex_key key (Simplex_handle sh)
 Returns the key associated to a simplex.
Simplex_handle simplex (Simplex_key key)
 Returns the simplex associated to a key. More...
void assign_key (Simplex_handle sh, Simplex_key key)
 Assign a key to a simplex.
Boundary_simplex_range boundary_simplex_range (Simplex_handle sh)
 Returns a range giving access to all simplices of the boundary of a simplex, i.e. the set of codimension 1 subsimplices of the Simplex. More...
Filtration_simplex_range filtration_simplex_range ()
 Returns a range over the simplices of the complex in the order of the filtration. More...
Detailed Description
Member Typedef Documentation
value_type must be 'Simplex_handle'.
.begin() and .end() return type Boundary_simplex_iterator.
'value_type' must be 'Simplex_handle'.
.begin() and .end() return type Filtration_simplex_iterator.
typedef unspecified FilteredComplex::Filtration_value
Must be comparable with <.
typedef unspecified FilteredComplex::Indexing_tag
is model of IndexingTag.
typedef unspecified FilteredComplex::Simplex_handle
Handle to specify a simplex.
typedef unspecified FilteredComplex::Simplex_key
Must be a signed integer type.
Member Function Documentation
Boundary_simplex_range FilteredComplex::boundary_simplex_range ( Simplex_handle  sh)
If the simplex is $[v_0, \cdots ,v_d]$, with canonical orientation induced by $ v_0 < \cdots < v_d $, the iterator enumerates the simplices of the boundary in the order: $[v_0,\cdots,\widehat{v_i},\cdots,v_d]$ for $i$ from 0 to d
We note that the alternate sum of the simplices given by the iterator gives the chains corresponding to the boundary of the simplex.
Filtration_value FilteredComplex::filtration ( Simplex_handle  sh)
If sh is null_simplex(), returns the maximal value of the filtration function on the complex.
Filtration_simplex_range FilteredComplex::filtration_simplex_range ( )
Simplex_handle FilteredComplex::null_simplex ( )
Returns a Simplex_hanlde that is different from all simplex handles of the simplices.
size_t FilteredComplex::num_simplices ( )
Does not count the empty simplex.
Simplex_handle FilteredComplex::simplex ( Simplex_key  key)
If key is different from null_key(), there must be a unique simplex having this key.
The documentation for this struct was generated from the following file:
