Data structure representing a Hasse diagram, i.e. a complex where all codimension 1 incidence relations are explicitly encoded. More...
#include <Hasse_complex.h>
Additional Inherited Members | |
Public Types inherited from FilteredComplex | |
| typedef unspecified | Simplex_handle |
| typedef unspecified | Simplex_key |
| Key associated to each simplex. More... | |
| typedef unspecified | Filtration_value |
| Type for the value of the filtration function. More... | |
| typedef unspecified | Indexing_tag |
| Specifies the nature of the indexing scheme. More... | |
| typedef unspecified | Boundary_simplex_iterator |
| Iterator on the simplices belonging to the boundary of a simplex. More... | |
| typedef unspecified | Boundary_simplex_range |
| Range giving access to the simplices in the boundary of a simplex. More... | |
| typedef unspecified | Filtration_simplex_iterator |
| Iterator over all simplices of the complex in the order of the indexing scheme. More... | |
| typedef unspecified | Filtration_simplex_range |
| Range over the simplices of the complex in the order of the filtration. More... | |
Public Member Functions inherited from FilteredComplex | |
| Simplex_handle | null_simplex () |
| size_t | num_simplices () |
| Returns the number of simplices in the complex. More... | |
| int | dimension (Simplex_handle sh) |
| Returns the dimension of a simplex. | |
| Filtration_value | filtration (Simplex_handle sh) |
| Returns the filtration value of a simplex. More... | |
| Simplex_key | null_key () |
| Returns a key that is different from the keys associated to the simplices. | |
| Simplex_key | key (Simplex_handle sh) |
| Returns the key associated to a simplex. | |
| Simplex_handle | simplex (Simplex_key key) |
| Returns the simplex associated to a key. More... | |
| void | assign_key (Simplex_handle sh, Simplex_key key) |
| Assign a key to a simplex. | |
| Boundary_simplex_range | boundary_simplex_range (Simplex_handle sh) |
| Returns a range giving access to all simplices of the boundary of a simplex, i.e. the set of codimension 1 subsimplices of the Simplex. More... | |
| Filtration_simplex_range | filtration_simplex_range () |
| Returns a range over the simplices of the complex in the order of the filtration. More... | |
1.8.7
