Tangential complex reference manual#
- class gudhi.TangentialComplex#
Bases:
objectThe class Tangential_complex represents a tangential complex. After the computation of the complex, an optional post-processing called perturbation can be run to attempt to remove inconsistencies.
- __init__()#
TangentialComplex constructor.
- Parameters:
Or
- Parameters:
off_file¶ (string) – An OFF file style name.
- __new__(**kwargs)#
- compute_tangential_complex()#
This function computes the tangential complex.
- Raises:
ValueError – In debug mode, if the computed star dimension is too low. Try to set a bigger maximal edge length value with
set_max_squared_edge_length()if this happens.
- create_simplex_tree()#
Exports the complex into a simplex tree.
- Returns:
A simplex tree created from the complex.
- Return type:
- fix_inconsistencies_using_perturbation()#
Attempts to fix inconsistencies by perturbing the point positions.
- get_point()#
This function returns the point corresponding to a given vertex.
- Parameters:
vertex¶ (int.) – The vertex.
- Returns:
The point.
- Return type:
list of float
- num_inconsistent_simplices()#
- Returns:
The number of inconsistent simplices.
- Return type:
unsigned
- num_inconsistent_stars()#
- Returns:
The number of stars containing at least one inconsistent simplex.
- Return type:
unsigned
- num_simplices()#
- Returns:
Total number of simplices in stars (including duplicates that appear in several stars).
- Return type:
unsigned
- num_vertices()#
- Returns:
The number of vertices.
- Return type:
unsigned
- set_max_squared_edge_length()#
Sets the maximal possible squared edge length for the edges in the triangulations.
- Parameters:
max_squared_edge_length¶ (double) – Maximal possible squared edge length.
If the maximal edge length value is too low
compute_tangential_complex()will throw an exception in debug mode.
