Persistent cohomology user manual#
Definition#
Computation of persistent cohomology using the algorithm of [15] and [18] and the Compressed Annotation Matrix implementation of [3].
The theory of homology consists in attaching to a topological space a sequence of (homology) groups, capturing global topological features like connected components, holes, cavities, etc. Persistent homology studies the evolution – birth, life and death – of these features when the topological space is changing. Consequently, the theory is essentially composed of three elements:
topological spaces
their homology groups
an evolution scheme.
Topological Spaces#
Topological spaces are represented by simplicial complexes.
Let
Homology#
For a ring
of finitely many groups
We refer to [25] for an introduction to homology theory and to [19] for an introduction to persistent homology.
Indexing Scheme#
“Changing” a simplicial complex consists in applying a simplicial map. An indexing scheme is a directed graph together with a traversal order, such that two consecutive nodes in the graph are connected by an arrow (either forward or backward). The nodes represent simplicial complexes and the directed edges simplicial maps.
From the computational point of view, there are two types of indexing schemes of interest in persistent homology:
These indexing schemes have a natural left-to-right traversal order, and we describe them with ranges and iterators. In the current release of the Gudhi library, only the linear case is implemented.
In the following, we consider the case where the indexing scheme is induced by a filtration.
Ordering the simplices by increasing filtration values (breaking ties so as a simplex appears after its subsimplices of same filtration value) provides an indexing scheme.
Examples#
We provide several example files: run these examples with -h for details on their use.
