Bottleneck distance user manual#
Definition#
_images/perturb_pd.png
Bottleneck distance is the length of the longest edge#
Bottleneck distance measures the similarity between two persistence diagrams. It’s the shortest distance b for which there exists a perfect matching between the points of the two diagrams (+ all the diagonal points) such that any couple of matched points are at distance at most b, where the distance between points is the sup norm in R2.
Author:
François Godi
Since:
GUDHI 2.0.0
License:
MIT (GPL v3)
Requires:
CGAL 4.11.0
This implementation by François Godi is based on ideas from “Geometry Helps in Bottleneck Matching and Related Problems” [20] and requires CGAL (GPL v3).
gudhi.bottleneck_distance(diagram_1: numpy.ndarray[numpy.float64], diagram_2: numpy.ndarray[numpy.float64], e: float | None = None) float#
Compute the Bottleneck distance between two diagrams. Points at infinity and on the diagonal are supported.
Parameters:
  • diagram_1 (numpy array of shape (m,2)) – The first diagram.
  • diagram_2 (numpy array of shape (n,2)) – The second diagram.
  • e (float) – If e is 0, this uses an expensive algorithm to compute the exact distance. If e is not 0, it asks for an additive e-approximation, and currently also allows a small multiplicative error (the last 2 or 3 bits of the mantissa may be wrong). This version of the algorithm takes advantage of the limited precision of double and is usually a lot faster to compute, whatever the value of e. Thus, by default (e=None), e is the smallest positive double.
Return type:
float
Returns:
the bottleneck distance.
This other implementation comes from Hera (BSD-3-Clause) which is based on “Geometry Helps to Compare Persistence Diagrams” [23] by Michael Kerber, Dmitriy Morozov, and Arnur Nigmetov.
Warning
Beware that its approximation allows for a multiplicative error, while the function above uses an additive error.
gudhi.hera.bottleneck_distance(X: numpy.ndarray[numpy.float64], Y: numpy.ndarray[numpy.float64], delta: float = 0.01) float#
Compute the Bottleneck distance between two diagrams. Points at infinity are supported.
Note
Points on the diagonal are not supported and must be filtered out before calling this function.
Parameters:
  • X (n x 2 numpy array) – First diagram
  • Y (n x 2 numpy array) – Second diagram
  • delta (float) – Relative error 1+delta
Returns:
(approximate) bottleneck distance d_B(X,Y)
Return type:
float
Distance computation#
The following example explains how the distance is computed:
import gudhi
message = "Bottleneck distance = " + '%.1f' % gudhi.bottleneck_distance([[0., 0.]], [[0., 13.]])
print(message)
Bottleneck distance = 6.5
_images/bottleneck_distance_example.png
The point (0, 13) is at distance 6.5 from the diagonal and more specifically from the point (6.5, 6.5).#
Basic example#
This other example computes the bottleneck distance from 2 persistence diagrams:
import gudhi
diag1 = [[2.7, 3.7],[9.6, 14.],[34.2, 34.974], [3.,float('Inf')]]
diag2 = [[2.8, 4.45],[9.5, 14.1],[3.2,float('Inf')]]
message = "Bottleneck distance approximation = " + '%.2f' % gudhi.bottleneck_distance(diag1, diag2, 0.1)
print(message)
message = "Bottleneck distance value = " + '%.2f' % gudhi.bottleneck_distance(diag1, diag2)
print(message)
The output is:
Bottleneck distance approximation = 0.72
Bottleneck distance value = 0.75
