Rips complex reference manual¶
- class gudhi.RipsComplex¶
Bases:
objectThe data structure is a one skeleton graph, or Rips graph, containing edges when the edge length is less or equal to a given threshold. Edge length is computed from a user given point cloud with a given distance function, or a distance matrix.
- __init__()¶
RipsComplex constructor.
- Parameters
Or
- Parameters
distance_matrix¶ – A distance matrix (full square or lower triangular).
And in both cases
- Parameters
sparse¶ (float) – If this is not None, it switches to building a sparse Rips and represents the approximation parameter epsilon.
Weighted Rips complex reference manual¶
- class gudhi.weighted_rips_complex.WeightedRipsComplex(distance_matrix, weights=None, max_filtration=inf)[source]¶
Bases:
objectClass to generate a weighted Rips complex from a distance matrix and weights on vertices, in the way described in [1]. Remark that all the filtration values are doubled compared to the definition in the paper for the consistency with RipsComplex.
DTM Rips complex reference manual¶
- class gudhi.dtm_rips_complex.DTMRipsComplex(points=None, distance_matrix=None, k=1, q=2, max_filtration=inf)[source]¶
Bases:
gudhi.weighted_rips_complex.WeightedRipsComplexClass to generate a DTM Rips complex from a distance matrix or a point set, in the way described in [1]. Remark that all the filtration values are doubled compared to the definition in the paper for the consistency with RipsComplex. :Requires: SciPy
- __init__(points=None, distance_matrix=None, k=1, q=2, max_filtration=inf)[source]¶
- Parameters
points¶ (numpy.ndarray) – array of points.
distance_matrix¶ (numpy.ndarray) – full distance matrix.
k¶ (int) – number of neighbors for the computation of DTM. Defaults to 1, which is equivalent to the usual Rips complex.
q¶ (float) – order used to compute the distance to measure. Defaults to 2.
max_filtration¶ (float) – specifies the maximal filtration value to be considered.
