Simplex tree reference manual¶
class
gudhi.SimplexTree¶ Bases:
objectThe simplex tree is an efficient and flexible data structure for representing general (filtered) simplicial complexes. The data structure is described in Jean-Daniel Boissonnat and Clément Maria. The Simplex Tree: An Efficient Data Structure for General Simplicial Complexes. Algorithmica, pages 1–22, 2014.
This class is a filtered, with keys, and non contiguous vertices version of the simplex tree.
__init__()¶ SimplexTree constructor.
assign_filtration()¶ This function assigns a new filtration value to a given N-simplex.
- Parameters
Note
Beware that after this operation, the structure may not be a valid filtration anymore, a simplex could have a lower filtration value than one of its faces. Callers are responsible for fixing this (with more
assign_filtration()ormake_filtration_non_decreasing()for instance) before calling any function that relies on the filtration property, likepersistence().
betti_numbers()¶ This function returns the Betti numbers of the simplicial complex.
- Returns
The Betti numbers ([B0, B1, …, Bn]).
- Return type
list of int
- Note
betti_numbers function requires
compute_persistence()function to be launched first.
collapse_edges()¶ Assuming the simplex tree is a 1-skeleton graph, this method collapse edges (simplices of higher dimension are ignored) and resets the simplex tree from the remaining edges. A good candidate is to build a simplex tree on top of a
RipsComplexof dimension 1 before collapsing edges (cf.rips_complex_edge_collapse_example.py). For implementation details, please refer to [6].- Parameters
nb_iterations¶ (int) – The number of edge collapse iterations to perform. Default is 1.
compute_persistence()¶ This function computes the persistence of the simplicial complex, so it can be accessed through
persistent_betti_numbers(),persistence_pairs(), etc. This function is equivalent topersistence()when you do not want the listpersistence()returns.- Parameters
homology_coeff_field¶ (int) – The homology coefficient field. Must be a prime number. Default value is 11.
min_persistence¶ (float) – The minimum persistence value to take into account (strictly greater than min_persistence). Default value is 0.0. Sets min_persistence to -1.0 to see all values.
persistence_dim_max¶ (bool) – If true, the persistent homology for the maximal dimension in the complex is computed. If false, it is ignored. Default is false.
- Returns
Nothing.
dimension()¶ This function returns the dimension of the simplicial complex.
- Returns
the simplicial complex dimension.
- Return type
int
Note
This function is not constant time because it can recompute dimension if required (can be triggered by
remove_maximal_simplex()orprune_above_filtration()methods).
expansion()¶ Expands the Simplex_tree containing only its one skeleton until dimension max_dim.
The expanded simplicial complex until dimension \(d\) attached to a graph \(G\) is the maximal simplicial complex of dimension at most \(d\) admitting the graph \(G\) as \(1\)-skeleton. The filtration value assigned to a simplex is the maximal filtration value of one of its edges.
The Simplex_tree must contain no simplex of dimension bigger than 1 when calling the method.
- Parameters
max_dim¶ (int) – The maximal dimension.
extend_filtration()¶ Extend filtration for computing extended persistence. This function only uses the filtration values at the 0-dimensional simplices, and computes the extended persistence diagram induced by the lower-star filtration computed with these values.
Note
Note that after calling this function, the filtration values are actually modified within the Simplex_tree. The function
extended_persistence()retrieves the original values.Note
Note that this code creates an extra vertex internally, so you should make sure that the Simplex_tree does not contain a vertex with the largest possible value (i.e., 4294967295).
extended_persistence()¶ This function retrieves good values for extended persistence, and separate the diagrams into the Ordinary, Relative, Extended+ and Extended- subdiagrams.
- Parameters
min_persistence¶ (float) – The minimum persistence value (i.e., the absolute value of the difference between the persistence diagram point coordinates) to take into account (strictly greater than min_persistence). Default value is 0.0. Sets min_persistence to -1.0 to see all values.
- Returns
A list of four persistence diagrams in the format described in
persistence(). The first one is Ordinary, the second one is Relative, the third one is Extended+ and the fourth one is Extended-. See https://link.springer.com/article/10.1007/s10208-008-9027-z and/or section 2.2 in https://link.springer.com/article/10.1007/s10208-017-9370-z for a description of these subtypes.
Note
This function should be called only if
extend_filtration()has been called first!Note
The coordinates of the persistence diagram points might be a little different than the original filtration values due to the internal transformation (scaling to [-2,-1]) that is performed on these values during the computation of extended persistence.
filtration()¶ This function returns the filtration value for a given N-simplex in this simplicial complex, or +infinity if it is not in the complex.
- Parameters
simplex¶ (list of int) – The N-simplex, represented by a list of vertex.
- Returns
The simplicial complex filtration value.
- Return type
float
find()¶ This function returns if the N-simplex was found in the simplicial complex or not.
- Parameters
simplex¶ (list of int) – The N-simplex to find, represented by a list of vertex.
- Returns
true if the simplex was found, false otherwise.
- Return type
bool
flag_persistence_generators()¶ Assuming this is a flag complex, this function returns the persistence pairs, where each simplex is replaced with the vertices of the edges that gave it its filtration value.
- Returns
First the regular persistence pairs of dimension 0, with one vertex for birth and two for death; then the other regular persistence pairs, grouped by dimension, with 2 vertices per extremity; then the connected components, with one vertex each; finally the other essential features, grouped by dimension, with 2 vertices for birth.
- Return type
Tuple[numpy.array[int] of shape (n,3), List[numpy.array[int] of shape (m,4)], numpy.array[int] of shape (l,), List[numpy.array[int] of shape (k,2)]]
- Note
flag_persistence_generators requires that persistence() be called first.
get_cofaces()¶ This function returns the cofaces of a given N-simplex with a given codimension.
- Parameters
- Returns
The (simplices of the) cofaces of a simplex
- Return type
list of tuples(simplex, filtration)
get_filtration()¶ This function returns a generator with simplices and their given filtration values sorted by increasing filtration values.
- Returns
The simplices sorted by increasing filtration values.
- Return type
generator with tuples(simplex, filtration)
get_simplices()¶ This function returns a generator with simplices and their given filtration values.
- Returns
The simplices.
- Return type
get_skeleton()¶ This function returns a generator with the (simplices of the) skeleton of a maximum given dimension.
- Parameters
dimension¶ (int) – The skeleton dimension value.
- Returns
The (simplices of the) skeleton of a maximum dimension.
- Return type
get_star()¶ This function returns the star of a given N-simplex.
- Parameters
- Returns
The (simplices of the) star of a simplex.
- Return type
initialize_filtration()¶ This function initializes and sorts the simplicial complex filtration vector.
Deprecated since version 3.2.0.
insert()¶ This function inserts the given N-simplex and its subfaces with the given filtration value (default value is ‘0.0’). If some of those simplices are already present with a higher filtration value, their filtration value is lowered.
lower_star_persistence_generators()¶ Assuming this is a lower-star filtration, this function returns the persistence pairs, where each simplex is replaced with the vertex that gave it its filtration value.
- Returns
First the regular persistence pairs, grouped by dimension, with one vertex per extremity, and second the essential features, grouped by dimension, with one vertex each
- Return type
Tuple[List[numpy.array[int] of shape (n,2)], List[numpy.array[int] of shape (m,)]]
- Note
lower_star_persistence_generators requires that persistence() be called first.
make_filtration_non_decreasing()¶ This function ensures that each simplex has a higher filtration value than its faces by increasing the filtration values.
- Returns
True if any filtration value was modified, False if the filtration was already non-decreasing.
- Return type
bool
num_simplices()¶ This function returns the number of simplices of the simplicial complex.
- Returns
the simplicial complex number of simplices.
- Return type
int
num_vertices()¶ This function returns the number of vertices of the simplicial complex.
- Returns
The simplicial complex number of vertices.
- Return type
int
persistence()¶ This function computes and returns the persistence of the simplicial complex.
- Parameters
min_persistence¶ (float) – The minimum persistence value to take into account (strictly greater than min_persistence). Default value is 0.0. Set min_persistence to -1.0 to see all values.
- Returns
The persistence of the simplicial complex.
- Return type
list of pairs(dimension, pair(birth, death))
persistence_intervals_in_dimension()¶ This function returns the persistence intervals of the simplicial complex in a specific dimension.
- Parameters
dimension¶ (int) – The specific dimension.
- Returns
The persistence intervals.
- Return type
numpy array of dimension 2
- Note
intervals_in_dim function requires
persistence_pairs()¶ This function returns a list of persistence birth and death simplices pairs.
- Returns
A list of persistence simplices intervals.
- Return type
list of pair of list of int
- Note
persistence_pairs function requires
persistent_betti_numbers()¶ This function returns the persistent Betti numbers of the simplicial complex.
- Parameters
- Returns
The persistent Betti numbers ([B0, B1, …, Bn]).
- Return type
list of int
- Note
persistent_betti_numbers function requires
prune_above_filtration()¶ Prune above filtration value given as parameter.
- Parameters
filtration¶ (float) – Maximum threshold value.
- Returns
The filtration modification information.
- Return type
bool
Note
Note that the dimension of the simplicial complex may be lower after calling
prune_above_filtration()than it was before. However,upper_bound_dimension()will return the old value, which remains a valid upper bound. If you care, you can calldimension()method to recompute the exact dimension.
remove_maximal_simplex()¶ This function removes a given maximal N-simplex from the simplicial complex.
- Parameters
Note
The dimension of the simplicial complex may be lower after calling remove_maximal_simplex than it was before. However,
upper_bound_dimension()method will return the old value, which remains a valid upper bound. If you care, you can calldimension()to recompute the exact dimension.
set_dimension()¶ This function sets the dimension of the simplicial complex.
- Parameters
dimension¶ (int) – The new dimension value.
Note
This function must be used with caution because it disables dimension recomputation when required (this recomputation can be triggered by
remove_maximal_simplex()orprune_above_filtration()).
upper_bound_dimension()¶ This function returns a valid dimension upper bound of the simplicial complex.
- Returns
an upper bound on the dimension of the simplicial complex.
- Return type
int
write_persistence_diagram()¶ This function writes the persistence intervals of the simplicial complex in a user given file name.
- Parameters
persistence_file¶ (string) – Name of the file.
- Note
