Delaunay complex reference manual#
- class gudhi.DelaunayComplex#
DelaunayComplex is a simplicial complex constructed from the finite cells of a Delaunay Triangulation.
When
filtrationis:None (default value) - The filtration value of each simplex is not computed (set to NaN)
‘alpha’ - The filtration value of each simplex is computed as an
AlphaComplex‘cech’ - The filtration value of each simplex is computed as a
DelaunayCechComplex
- __init__()#
- Parameters:
- Raises:
ValueError – In case of inconsistency between the number of points and weights.
- create_simplex_tree(max_alpha_square=inf, filtration=None, output_squared_values=True)#
- Parameters:
max_alpha_square¶ (
float) – The maximum alpha square threshold the simplices shall not exceed. Default is set to infinity, and there is very little point using anything else since it does not save time.filtration¶ (
Literal['alpha','cech'] |None) – Set this value to None (default value) if filtration values are not needed to be computed (will be set to NaN). Set it to alpha to compute the filtration values with the Alpha complex, or to cech to compute the Delaunay Cech complex.output_squared_values¶ (
bool) – Square filtration values when True. Default is True.
- Returns:
- A simplex tree created from the Delaunay Triangulation. The vertex k corresponds to the k-th
input point. The vertices may not be numbered contiguously as some points may be discarded in the triangulation (duplicate points, weighted hidden point, …).
- Return type:
- static get_float_relative_precision()#
- Return type:
float- Returns:
The float relative precision of filtration values computation when constructing with
precision = 'safe'(the default).
- static set_float_relative_precision(precision)#
- Parameters:
precision¶ (
float) – When constructingdelaunay_cech_complex(),alpha_complex(), orweighted_alpha_complex()withprecision = 'safe'(the default), one can set the float relative precision of filtration values computed. Default is1e-5(cf.get_float_relative_precision()). For more details, please refer to CGAL::Lazy_exact_nt<NT>::set_relative_precision_of_to_double- Raises:
ValueError – If precision is not in (0, 1).
Alpha complex reference manual#
- class gudhi.AlphaComplex#
Bases:
DelaunayComplexAlphaComplex is a simplicial complex constructed from the finite cells of a Delaunay Triangulation.
The filtration value of each simplex is computed as the squared radius of the smallest empty sphere passing through all of its vertices.
All simplices that have a filtration value strictly greater than a given alpha squared value are not inserted into the complex.
For more details about the algorithm, please refer to the Alpha complex C++ documentation
Note
When Alpha Complex is constructed with an infinite value of alpha, the complex is a Delaunay complex.
- create_simplex_tree(max_alpha_square=inf, default_filtration_value=False, output_squared_values=True)#
- Parameters:
max_alpha_square¶ (
float) – The maximum alpha square threshold the simplices shall not exceed. Default is set to infinity, and there is very little point using anything else since it does not save time.default_filtration_value¶ (
bool) – Default value is False (which means compute the filtration values). Set this value to True if filtration values are not needed to be computed (will be set to NaN), but please consider constructing aDelaunayComplexinstead.output_squared_values¶ (
bool) – Square filtration values when True. Default is True to keep backwardcompatibility.¶
- Returns:
- Return type:
- get_point(vertex)#
This function returns the point corresponding to a given vertex from the
SimplexTree(the same as the k-th input point, where k=vertex)- Parameters:
vertex¶ (
int) – The vertex.- Return type:
list[float]- Returns:
the point.
- Raises:
IndexError – In case the point has no associated vertex in the diagram (because of weights or because it is a duplicate).
Delaunay Čech complex reference manual#
- class gudhi.DelaunayCechComplex#
Bases:
DelaunayComplexDelaunayCechComplex is a simplicial complex constructed from the finite cells of a Delaunay Triangulation.
The filtration value of each simplex is equal to the squared radius of its minimal enclosing ball (MEB).
Note
When DelaunayCechComplex is constructed with an infinite value of alpha, the complex is a Delaunay complex.
- __init__()#
- create_simplex_tree(max_alpha_square=inf, output_squared_values=True)#
- Parameters:
- Returns:
A simplex tree created from the Delaunay Čech Triangulation. The vertex k corresponds to the k-th input point. The vertices may not be numbered contiguously as some points may be discarded in the triangulation(duplicate points, …).
- Return type:
