Simplex tree user manual
Definition
Simplex tree representation
The simplex tree is an efficient and flexible data structure for representing general (filtered) simplicial complexes.
The data structure is described in [5]
Author
Clément Maria
Introduced in
GUDHI 2.0.0
Copyright
MIT
A simplicial complex K on a set of vertices V={1,,|V|} is a collection of simplices {σ}, σV such that τσKτK. The dimension n=|σ|1 of σ is its number of elements minus 1.
A filtration of a simplicial complex is a function f:KR satisfying f(τ)f(σ) whenever τσ. Ordering the simplices by increasing filtration values (breaking ties so as a simplex appears after its subsimplices of same filtration value) provides an indexing scheme.
Implementation
The simplex tree is an efficient and flexible data structure for representing general (filtered) simplicial complexes. The data structure is described in [5].
Example
import gudhi
st = gudhi.SimplexTree()
if st.insert([0, 1]):
    print("[0, 1] inserted")
if st.insert([0, 1, 2], filtration=4.0):
    print("[0, 1, 2] inserted")
if st.find([0, 1]):
    print("[0, 1] found")
result_str = 'num_vertices=' + repr(st.num_vertices())
print(result_str)
result_str = 'num_simplices=' + repr(st.num_simplices())
print(result_str)
print("skeleton(2) =")
for sk_value in st.get_skeleton(2):
    print(sk_value)
The output is:
[0, 1] inserted
[0, 1, 2] inserted
[0, 1] found
num_vertices=3
num_simplices=7
skeleton(2) =
([0, 1, 2], 4.0)
([0, 1], 0.0)
([0, 2], 4.0)
([0], 0.0)
([1, 2], 4.0)
([1], 0.0)
([2], 4.0)
