Bottleneck distance user manual
Definition
_images/perturb_pd.png
Bottleneck distance is the length of the longest edge
Bottleneck distance measures the similarity between two persistence diagrams. It’s the shortest distance b for which there exists a perfect matching between the points of the two diagrams (+ all the diagonal points) such that any couple of matched points are at distance at most b, where the distance between points is the sup norm in R2.
Author
François Godi
Introduced in
GUDHI 2.0.0
Copyright
MIT (GPL v3)
Requires
CGAL 4.11.0
This implementation is based on ideas from “Geometry Helps in Bottleneck Matching and Related Problems” [1]. Another relevant publication, although it was not used is “Geometry Helps to Compare Persistence Diagrams” [2].
Function
gudhi.bottleneck_distance()
This function returns the point corresponding to a given vertex.
Parameters
  • diagram_1 (vector[pair[double, double]]) – The first diagram.
  • diagram_2 (vector[pair[double, double]]) – The second diagram.
  • e (float) –
    If e is 0, this uses an expensive algorithm to compute the exact distance. If e is not 0, it asks for an additive e-approximation, and currently also allows a small multiplicative error (the last 2 or 3 bits of the mantissa may be wrong). This version of the algorithm takes advantage of the limited precision of double and is usually a lot faster to compute, whatever the value of e.
    Thus, by default, e is the smallest positive double.
Return type
float
Returns
the bottleneck distance.
Distance computation
The following example explains how the distance is computed:
import gudhi
message = "Bottleneck distance = " + '%.1f' % gudhi.bottleneck_distance([[0., 0.]], [[0., 13.]])
print(message)
Bottleneck distance = 6.5
_images/bottleneck_distance_example.png
The point (0, 13) is at distance 6.5 from the diagonal and more specifically from the point (6.5, 6.5)
Basic example
This other example computes the bottleneck distance from 2 persistence diagrams:
import gudhi
diag1 = [[2.7, 3.7],[9.6, 14.],[34.2, 34.974], [3.,float('Inf')]]
diag2 = [[2.8, 4.45],[9.5, 14.1],[3.2,float('Inf')]]
message = "Bottleneck distance approximation = " + '%.2f' % gudhi.bottleneck_distance(diag1, diag2, 0.1)
print(message)
message = "Bottleneck distance value = " + '%.2f' % gudhi.bottleneck_distance(diag1, diag2)
print(message)
The output is:
Bottleneck distance approximation = 0.81
Bottleneck distance value = 0.75
