Witness complex reference manual¶
class
gudhi.WitnessComplex¶ Bases:
objectConstructs (weak) witness complex for a given table of nearest landmarks with respect to witnesses.
__init__()¶ WitnessComplex constructor.
Parameters: nearest_landmark_table (list of list of pair of int and float) – A list of lists of nearest landmarks and their distances. nearest_landmark_table[w][k]==(l,d) means that l is the k-th nearest landmark to witness w, and d is the (squared) distance between l and w.
create_simplex_tree()¶ Parameters: max_alpha_square (float) – The maximum relaxation parameter. Default is set to infinity. Returns: A simplex tree created from the Delaunay Triangulation. Return type: SimplexTree
