Reader utils reference manual¶
gudhi.read_off()¶ Read points from OFF file.
Parameters: off_file (string) – An OFF file style name. Returns: The point set. Return type: vector[vector[double]]
gudhi.read_lower_triangular_matrix_from_csv_file()¶ Read lower triangular matrix from a CSV style file.
Parameters: - csv_file (string) – A CSV file style name.
- separator (char) – The value separator in the CSV file. Default value is ‘;’
Returns: The lower triangular matrix.
gudhi.read_persistence_intervals_grouped_by_dimension()¶ Reads a file containing persistence intervals. Each line might contain 2, 3 or 4 values: [[field] dimension] birth death The return value is an map[dim, vector[pair[birth, death]]] where dim is an int, birth a double, and death a double. Note: the function does not check that birth <= death.
Parameters: persistence_file (string) – A persistence file style name. Returns: The persistence pairs grouped by dimension. Return type: map[int, vector[pair[double, double]]]
gudhi.read_persistence_intervals_in_dimension()¶ Reads a file containing persistence intervals. Each line of persistence_file might contain 2, 3 or 4 values: [[field] dimension] birth death Note: the function does not check that birth <= death.
Parameters: - persistence_file (string) – A persistence file style name.
- only_this_dim (int.) – The specific dimension. Default value is -1. If only_this_dim = -1, dimension is ignored and all lines are returned. If only_this_dim is >= 0, only the lines where dimension = only_this_dim (or where dimension is not specified) are returned.
Returns: The persistence intervals.
Return type: numpy array of dimension 2
