Searching...
No Matches
hooks_simplex_base.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Clément Maria
4 *
5 * Copyright (C) 2020 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef SIMPLEX_TREE_HOOKS_SIMPLEX_BASE_H_
12#define SIMPLEX_TREE_HOOKS_SIMPLEX_BASE_H_
13
14#include <boost/intrusive/list.hpp>
15#include <stdexcept>
16
17namespace Gudhi {
21
30 public:
32 // The following 2 functions are conceptually wrong, but when copying a Simplex_tree it is more convenient to have
33 // them (and fix things asap after they are called).
34 // copy constructor, inherited by the Node class, requires to copy hooks
36 : list_max_vertex_hook_() { }
37 // copy assignment
39 throw std::logic_error("Should not happen");
40 }
41 // move constructor
43 list_max_vertex_hook_.swap_nodes(other.list_max_vertex_hook_);
44 }
45 // move assignment
47 list_max_vertex_hook_.swap_nodes(other.list_max_vertex_hook_);
48 return *this;
49 }
50 void unlink_hooks() { list_max_vertex_hook_.unlink(); }
51 ~Hooks_simplex_base_link_nodes() {} // unlink_hooks(); }
52
53 typedef boost::intrusive::list_member_hook< // allows .unlink()
54 boost::intrusive::link_mode<boost::intrusive::auto_unlink>>
55 Member_hook_t;
56
57 Member_hook_t list_max_vertex_hook_;
58 };
59
60} // namespace Gudhi
61
62#endif // SIMPLEX_TREE_HOOKS_SIMPLEX_BASE_H_
No hook when SimplexTreeOptions::link_nodes_by_label is false.
Definition: hooks_simplex_base.h:20
