All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Searching...
No Matches
cech_complex_example_from_points.cpp
Bitmap_cubical_complex
#include <gudhi/Cech_complex.h>
#include <gudhi/Simplex_tree.h>
#include <CGAL/Epeck_d.h> // For EXACT or SAFE version
#include <iostream>
#include <string>
#include <vector>
int main() {
// Type definitions
using Kernel = CGAL::Epeck_d<CGAL::Dimension_tag<2>>;
using Point = typename Kernel::Point_d;
using Point_cloud = std::vector<Point>;
Point_cloud points;
points.emplace_back(1., 0.); // 0
points.emplace_back(0., 1.); // 1
points.emplace_back(2., 1.); // 2
points.emplace_back(3., 2.); // 3
points.emplace_back(0., 3.); // 4
points.emplace_back(3. + std::sqrt(3.), 3.); // 5
points.emplace_back(1., 4.); // 6
points.emplace_back(3., 4.); // 7
points.emplace_back(2., 4. + std::sqrt(3.)); // 8
points.emplace_back(0., 4.); // 9
points.emplace_back(-0.5, 2.); // 10
// Init of a Cech complex from points
Filtration_value max_radius = 1.;
Cech_complex cech_complex_from_points(points, max_radius);
Simplex_tree stree;
cech_complex_from_points.create_complex(stree, 2);
// Display information about the one skeleton Cech complex
std::clog << "Cech complex is of dimension " << stree.dimension() << " - " << stree.num_simplices() << " simplices - "
<< stree.num_vertices() << " vertices." << std::endl;
std::clog << "Iterator on Cech complex simplices in the filtration order, with [filtration value]:" << std::endl;
for (auto f_simplex : stree.filtration_simplex_range()) {
std::clog << " ( ";
for (auto vertex : stree.simplex_vertex_range(f_simplex)) {
std::clog << vertex << " ";
std::clog << ") -> "
<< "[" << stree.filtration(f_simplex) << "] ";
std::clog << std::endl;
return 0;
Options::Filtration_value Filtration_value
Type for the value of the filtration function.
Definition: Simplex_tree.h:102
Filtration_simplex_range const & filtration_simplex_range(Indexing_tag=Indexing_tag())
Returns a range over the simplices of the simplicial complex, in the order of the filtration.
Definition: Simplex_tree.h:338
Simplex_vertex_range simplex_vertex_range(Simplex_handle sh) const
Returns a range over the vertices of a simplex.
Definition: Simplex_tree.h:349
static Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
Definition: Simplex_tree.h:614
size_t num_vertices() const
Returns the number of vertices in the complex.
Definition: Simplex_tree.h:651
size_t num_simplices()
Returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:664
Cech complex class.
Definition: Cech_complex.h:44
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
