11#ifndef READER_UTILS_H_
   12#define READER_UTILS_H_
   15#include <gudhi/Debug_utils.h>
   17# include <boost/iterator/function_output_iterator.hpp>
   18#include <boost/graph/adjacency_list.hpp>
   46inline void read_points(std::string file_name, std::vector<std::vector<double>>& points) {
   47  std::ifstream in_file(file_name.c_str(), std::ios::in);
   48  if (!in_file.is_open()) {
   49    std::cerr <<
"Unable to open file " << file_name << std::endl;
   55  while (getline(in_file, line)) {
   56    std::vector<double> point;
   57    std::istringstream iss(line);
   62    if (!point.empty()) points.push_back(point);
   83template <
typename Graph_t,
typename Filtration_value,
typename Vertex_handle>
   85  std::ifstream in_(file_name.c_str(), std::ios::in);
   87    std::string error_str(
"read_graph - Unable to open file ");
   88    error_str.append(file_name);
   89    std::cerr << error_str << std::endl;
   90    throw std::invalid_argument(error_str);
   93  typedef std::pair<Vertex_handle, Vertex_handle> Edge_t;
   94  std::vector<Edge_t> edges;
   95  std::vector<Filtration_value> edges_fil;
   96  std::map<Vertex_handle, Filtration_value> vertices;
  102  while (getline(in_, line)) {
  103    std::istringstream iss(line);
  119          edges.push_back(Edge_t(u, v));
  120          edges_fil.push_back(fil);
  129  if ((
size_t)(max_h + 1) != vertices.size()) {
  130    std::cerr <<
"Error: vertices must be labeled from 0 to n-1 \n";
  133  Graph_t skel_graph(edges.begin(), edges.end(), edges_fil.begin(), vertices.size());
  134  auto vertex_prop = boost::get(vertex_filtration_t(), skel_graph);
  136  typename boost::graph_traits<Graph_t>::vertex_iterator vi, vi_end;
  137  auto v_it = vertices.begin();
  138  for (std::tie(vi, vi_end) = boost::vertices(skel_graph); vi != vi_end; ++vi, ++v_it) {
  139    boost::put(vertex_prop, *vi, v_it->second);
  157template <
typename Vertex_handle,
typename Filtration_value>
  160  if (!(in_ >> dim))
return false;
  162  for (
int i = 0; i < dim + 1; ++i) {
  163    if (!(in_ >> v))
return false;
  164    simplex.push_back(v);
  166  if (!(in_ >> fil))
return false;
  167  in_.ignore((std::numeric_limits<std::streamsize>::max)(),
'\n');
  182template <
typename Simplex_key,
  185  if (!(in_ >> dim))
return false;
  191  for (
  193    boundary.push_back(key);
  219template <
  221        const char separator =
  223  std::clog <<
"Using procedure read_lower_triangular_matrix_from_csv_file \n";
  225  std::vector<std::vector<Filtration_value>> result;
  227  in.open(filename.c_str());
  235  std::getline(in, line);
  236  std::vector<Filtration_value> values_in_this_line;
  237  result.push_back(values_in_this_line);
  239  int number_of_line = 0;
  242  while (std::getline(in, line)) {
  244    if (line.size() == 0)
break;
  247    if (line[line.size() - 1] == separator) {
  253    std::replace(line.begin(), line.end(), separator,
  256    std::istringstream iss(line);
  259    int number_of_entry = 0;
  260    std::vector<Filtration_value> values_in_this_line;
  264      if (number_of_entry <= number_of_line) {
  265        values_in_this_line.push_back(entry);
  269    if (!values_in_this_line.empty()) result.push_back(values_in_this_line);
  275  std::clog <<
"Here is the matrix we read : \n";
  276  for (
size_t i = 0; i != result.size(); ++i) {
  277    for (
size_t j = 0; j != result[i].size(); ++j) {
  278      std::clog << result[i][j] <<
  280    std::clog << std::endl;
  294template <
typename OutputIterator>
  297  std::clog <<
"read_persistence_intervals_and_dimension - " << filename << std::endl;
  299  std::ifstream in(filename);
  301    std::string error_str(
"read_persistence_intervals_and_dimension - Unable to open file ");
  302    error_str.append(filename);
  303    std::cerr << error_str << std::endl;
  304    throw std::invalid_argument(error_str);
  310    if (line.length() != 0 && line[0] !=
  312      int n = sscanf(line.c_str(),
"%lf %lf %lf %lf", &numbers[0], &numbers[1], &numbers[2], &numbers[3]);
  314      std::clog <<
"[" << n <<
  315      for (
int i = 0; i < n; i++) {
  316        std::clog << numbers[i] <<
  318      std::clog << std::endl;
  321        int dim = (n >= 3 ?
static_cast<int>(numbers[n - 3]) : -1);
  322        *out++ = std::make_tuple(dim, numbers[n - 2], numbers[n - 1]);
  336    std::string
const& filename) {
  337  std::map<int, std::vector<std::pair<double, double>>> ret;
  339      filename, boost::make_function_output_iterator([&ret](std::tuple<int, double, double> t) {
  340        ret[get<0>(t)].push_back(std::make_pair(get<1>(t), get<2>(t)));
  356        int only_this_dim = -1) {
  357  std::vector<std::pair<double, double>> ret;
  359      filename, boost::make_function_output_iterator([only_this_dim, &ret](std::tuple<int, double, double> t) {
  360        if (only_this_dim == get<0>(t) || only_this_dim == -1) ret.emplace_back(get<1>(t), get<2>(t));
Graph simplicial complex methods.
bool read_hasse_simplex(std::istream &in_, std::vector< Simplex_key > &boundary, Filtration_value &fil)
Read a hasse simplex from a file.
Definition: reader_utils.h:183
Graph_t read_graph(std::string file_name)
Read a graph from a file.
Definition: reader_utils.h:84
std::vector< std::pair< double, double > > read_persistence_intervals_in_dimension(std::string const &filename, int only_this_dim=-1)
Definition: reader_utils.h:355
void read_persistence_intervals_and_dimension(std::string const &filename, OutputIterator out)
Definition: reader_utils.h:295
bool read_simplex(std::istream &in_, std::vector< Vertex_handle > &simplex, Filtration_value &fil)
Read a face from a file.
Definition: reader_utils.h:158
std::vector< std::vector< Filtration_value > > read_lower_triangular_matrix_from_csv_file(const std::string &filename, const char separator=';')
Read a lower triangular distance matrix from a csv file. We assume that the .csv store the whole (squ...
Definition: reader_utils.h:220
void read_points(std::string file_name, std::vector< std::vector< double > > &points)
Read a set of points to turn it into a vector< vector<double> > by filling points.
Definition: reader_utils.h:46
std::map< int, std::vector< std::pair< double, double > > > read_persistence_intervals_grouped_by_dimension(std::string const &filename)
Definition: reader_utils.h:335
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
