#include <gudhi/Persistence_vectors.h>
#include <iostream>
#include <sstream>
#include <limits>
#include <vector>
int main(int argc, char** argv) {
  std::clog << "This program creates persistence vectors files (*.vect) of persistence diagrams files (*.pers) "
            << "provided as an input.\n"
            << "The first parameter of this program is a dimension of persistence that will be used in creation of "
            << "the persistence heat maps."
            << "If your input files contains persistence pairs of various dimension, as a first parameter of the "
            << "procedure please provide the dimension of persistence you want to use."
            << "If in your files there are only birth-death pairs of the same dimension, set the first parameter to "
            << "-1.\n"
            << "The remaining parameters are the names of files with persistence diagrams. \n";
  if (argc < 3) {
    std::clog << "Wrong parameter list, the program will now terminate \n";
    return 1;
  std::clog << "The remaining parameters are the names of files with persistence diagrams. \n";
  int dim = atoi(argv[1]);
  unsigned dimension = std::numeric_limits<unsigned>::max();
  if (dim >= 0) {
    dimension = (unsigned)dim;
  std::vector<const char*> filenames;
  for (int i = 2; i < argc; ++i) {
    filenames.push_back(argv[i]);
  for (size_t i = 0; i != filenames.size(); ++i) {
    std::cerr << "Creating persistence vectors based on a file : " << filenames[i] << std::endl;
    std::stringstream ss;
    ss << filenames[i] << ".vect";
  return 0;
Compute the Euclidean distance between two Points given by a range of coordinates....
Definition: distance_functions.h:32
A class implementing persistence vectors.
Definition: Persistence_vectors.h:54
void print_to_file(const char *filename) const
Definition: Persistence_vectors.h:107
