10#ifndef POINTS_3D_OFF_IO_H_
   11#define POINTS_3D_OFF_IO_H_
   13#include <gudhi/Off_reader.h>
   25template<
typename Po
int_3>
   28  std::vector<Point_3> point_cloud_;
   42  void init(
int dim,
int num_vertices,
int num_faces,
int num_edges) {
   44    std::clog <<
"Points_3D_off_visitor_reader::init - dim=" << dim <<
" - num_vertices=" <<
   45        num_vertices <<
" - num_faces=" << num_faces <<
" - num_edges=" << num_edges << std::endl;
   51      std::cerr <<
"Points_3D_off_reader::Points_3D_off_reader cannot read OFF files in dimension " << dim <<
"\n";
   55      std::cerr <<
"Points_3D_off_visitor_reader::init faces are not taken into account from OFF file for Points.\n";
   58      std::cerr <<
"Points_3D_off_visitor_reader::init edges are not taken into account from OFF file for Points.\n";
   77      std::clog <<
"Points_3D_off_visitor_reader::point ";
   78      for (
auto coordinate :
point) {
   79        std::clog << coordinate <<
   81      std::clog << std::endl;
   90  void maximal_face(
const std::vector<int>& face) { }
  139template<
typename Po
int_3>
  151    std::ifstream stream(name_file);
  152    if (stream.is_open()) {
  155      valid_ = off_reader.
read(off_visitor);
  156      valid_ = valid_ && off_visitor.
is_valid();
  161      std::cerr <<
"Points_3D_off_reader::Points_3D_off_reader could not open file " << name_file <<
"\n";
  183  std::vector<Point_3> point_cloud;
OFF file reader top class visitor.
Definition: Off_reader.h:29
bool read(OffVisitor &off_visitor)
Read an OFF file and calls the following methods :
Definition: Off_reader.h:51
Definition: Points_3D_off_io.h:140
Points_3D_off_reader(const std::string &name_file)
Reads the OFF file and constructs a vector of points from the points that are in the OFF file.
Definition: Points_3D_off_io.h:149
bool is_valid() const
Returns if the OFF file read operation was successful or not.
Definition: Points_3D_off_io.h:169
const std::vector< Point_3 > & get_point_cloud() const
Point cloud getter.
Definition: Points_3D_off_io.h:177
OFF file visitor implementation according to Off_reader in order to read points from an OFF file.
Definition: Points_3D_off_io.h:26
Definition: Points_3D_off_io.h:108
Point cloud getter.
Definition: Points_3D_off_io.h:100
void init(int dim, int num_vertices, int num_faces, int num_edges)
Off_reader visitor init implementation.
Definition: Points_3D_off_io.h:42
void point(const std::vector< double > &point)
Off_reader visitor point implementation.
Definition: Points_3D_off_io.h:74
