12#ifndef ALPHA_COMPLEX_H_
   13#define ALPHA_COMPLEX_H_
   15#include <gudhi/Alpha_complex/Alpha_kernel_d.h>
   16#include <gudhi/Debug_utils.h>
   18#include <gudhi/Points_off_io.h>
   24#include <CGAL/Delaunay_triangulation.h>
   25#include <CGAL/Regular_triangulation.h>
   26#include <CGAL/Epeck_d.h>
   27#include <CGAL/Epick_d.h>
   28#include <CGAL/Spatial_sort_traits_adapter_d.h>
   29#include <CGAL/property_map.h>
   30#include <CGAL/version.h>
   31#include <CGAL/NT_converter.h>
   33#include <Eigen/src/Core/util/Macros.h>
   35#include <boost/range/size.hpp>
   36#include <boost/range/combine.hpp>
   37#include <boost/range/adaptor/transformed.hpp>
   50#if CGAL_VERSION_NR < 1041101000
   51# error Alpha_complex is only available for CGAL >= 4.11
   54#if !EIGEN_VERSION_AT_LEAST(3,1,0)
   55# error Alpha_complex is only available for Eigen3 >= 3.1.0 installed with CGAL
   60namespace alpha_complex {
   62template<
typename D>
struct Is_Epeck_D {
static const bool value =
false; };
   63template<
typename D>
struct Is_Epeck_D<CGAL::Epeck_d<D>> {
true; };
  102template<
class Kernel = CGAL::Epeck_d<CGAL::Dynamic_dimension_tag>,
bool Weighted = false>
  106  using Internal_vertex_handle = std::ptrdiff_t;
  110  using Geom_traits = std::conditional_t<Weighted, CGAL::Regular_triangulation_traits_adapter<Kernel>, Kernel>;
  113  using TDS = CGAL::Triangulation_data_structure<
typename Geom_traits::Dimension,
  114                                                 CGAL::Triangulation_vertex<Geom_traits, Internal_vertex_handle>,
  115                                                 CGAL::Triangulation_full_cell<Geom_traits> >;
  118  using Triangulation = std::conditional_t<Weighted, CGAL::Regular_triangulation<Kernel, TDS>,
  119                                                     CGAL::Delaunay_triangulation<Kernel, TDS>>;
  125  using FT =
typename A_kernel_d::FT;
  130  using Sphere =
typename A_kernel_d::Sphere;
  133  using Point_d =
typename Geom_traits::Point_d;
  137  using CGAL_vertex_iterator =
typename Triangulation::Vertex_iterator;
  140  using Vector_vertex_iterator = std::vector< CGAL_vertex_iterator >;
  145  Vector_vertex_iterator vertex_handle_to_iterator_;
  147  std::unique_ptr<Triangulation> triangulation_;
  153  std::vector<Internal_vertex_handle> vertices_;
  156  std::vector<Sphere> cache_, old_cache_;
  171      std::cerr <<
"Alpha_complex - Unable to read file " << off_file_name <<
"\n";
  188  template<
typename InputPo
intRange >
  190    init_from_range(points);
  205  template <
typename InputPo
intRange,
typename WeightRange>
  207    static_assert(Weighted,
"This constructor is not available for non-weighted versions of Alpha_complex");
  209    GUDHI_CHECK(boost::size(weights) == boost::size(points),
  210                std::invalid_argument(
"Points number in range different from weights range number"));
  211    auto weighted_points = boost::range::combine(points, weights)
  212      | boost::adaptors::transformed([](
auto const&t){
return Point_d(boost::get<0>(t), boost::get<1>(t));});
  213    init_from_range(weighted_points);
  225    if (triangulation_ ==
nullptr)
  228      return triangulation_->number_of_vertices();
  238    auto it = vertex_handle_to_iterator_.at(vertex);
  239    if (it ==
nullptr)
throw std::out_of_range(
"This vertex is missing, maybe hidden by a duplicate or another heavier point.");
  244  template<
typename InputPo
intRange >
  245  void init_from_range(
const InputPointRange& points) {
  246    #if CGAL_VERSION_NR < 1050000000
  247    if (Is_Epeck_D<Kernel>::value)
  248      std::cerr <<
"It is strongly advised to use a CGAL version >= 5.0 with Epeck_d Kernel for performance reasons."
  252#if CGAL_VERSION_NR < 1050101000
  254    static_assert(!Weighted,
"Weighted Alpha_complex is only available for CGAL >= 5.1");
  257    auto first = std::begin(points);
  258    auto last = std::end(points);
  262      triangulation_ = std::make_unique<Triangulation>(kernel_.get_dimension(*first));
  264      std::vector<Point_d> point_cloud(first, last);
  267      std::vector<Internal_vertex_handle> indices(boost::counting_iterator<Internal_vertex_handle>(0),
  268                                                  boost::counting_iterator<Internal_vertex_handle>(point_cloud.size()));
  270      using Point_property_map = boost::iterator_property_map<typename std::vector<Point_d>::iterator,
  271                                                              CGAL::Identity_property_map<Internal_vertex_handle>>;
  272      using Search_traits_d = CGAL::Spatial_sort_traits_adapter_d<Geom_traits, Point_property_map>;
  274      CGAL::spatial_sort(indices.begin(), indices.end(), Search_traits_d(std::begin(point_cloud)));
  276      typename Triangulation::Full_cell_handle hint;
  277      for (
auto index : indices) {
  278        typename Triangulation::Vertex_handle pos = triangulation_->insert(point_cloud[index], hint);
  279        if (pos !=
nullptr) {
  282          hint = pos->full_cell();
  288      vertex_handle_to_iterator_.resize(point_cloud.size());
  291      vertices_.reserve(triangulation_->number_of_vertices());
  293      for (CGAL_vertex_iterator vit = triangulation_->vertices_begin(); vit != triangulation_->vertices_end(); ++vit) {
  294        if (!triangulation_->is_infinite(*vit)) {
  296          std::clog <<
"Vertex insertion - " << vit->data() <<
" -> " << vit->point() << std::endl;
  298          vertex_handle_to_iterator_[vit->data()] = vit;
  299          vertices_.push_back(vit->data());
  302      std::sort(vertices_.begin(), vertices_.end());
  313  const Point_d& get_point_(std::size_t vertex)
 const {
  314    return vertex_handle_to_iterator_[vertex]->point();
  318  template<
class SimplicialComplexForAlpha>
  320    auto k = cplx.key(s);
  321    if(k==cplx.null_key()){
  323      cplx.assign_key(s, k);
  325      thread_local std::vector<Point_d> v;
  327      for (
auto vertex : cplx.simplex_vertex_range(s))
  328        v.push_back(get_point_(vertex));
  329      cache_.emplace_back(kernel_.get_sphere(v.cbegin(), v.cend()));
  335  template<
  337    auto k = cplx.key(s);
  338    if(k!=cplx.null_key())
  339      return kernel_.get_squared_radius(old_cache_[k]);
  341    thread_local std::vector<Point_d> v;
  343    for (
  344      v.push_back(get_point_(vertex));
  345    return kernel_.get_squared_radius(v.cbegin(), v.cend());
  372  template <
typename SimplicialComplexForAlpha,
  375                      Filtration_value max_alpha_square = std::numeric_limits<Filtration_value>::infinity(),
  377                      bool default_filtration_value =
false) {
  379    static_assert(std::numeric_limits<Filtration_value>::has_quiet_NaN);
  386    using Vector_vertex = std::vector<Vertex_handle>;
  388    if (triangulation_ ==
nullptr) {
  389      std::cerr <<
"Alpha_complex cannot create_complex from a NULL triangulation\n";
  392    if (triangulation_->maximal_dimension() < 1) {
  393      std::cerr <<
"Alpha_complex cannot create_complex from a zero-dimension triangulation\n";
  397      std::cerr <<
"Alpha_complex create_complex - complex is not empty\n";
  404      std::vector<Vertex_handle> one_vertex(1);
  405      for (
auto vertex : vertices_) {
  407        std::clog <<
"SimplicialComplex insertion " << vertex << std::endl;
  409        one_vertex[0] = vertex;
  413      for (
auto cit = triangulation_->finite_full_cells_begin();
  414           cit != triangulation_->finite_full_cells_end();
  416        Vector_vertex vertexVector;
  418        std::clog <<
"SimplicialComplex insertion ";
  420        for (
auto vit = cit->vertices_begin(); vit != cit->vertices_end(); ++vit) {
  421          if (*vit !=
nullptr) {
  423            std::clog <<
" " << (*vit)->data();
  426            vertexVector.push_back((*vit)->data());
  430        std::clog << std::endl;
  438    if (!default_filtration_value) {
  439      CGAL::NT_converter<FT, Filtration_value> cgal_converter;
  442      for (
int decr_dim = triangulation_->maximal_dimension(); decr_dim >= 0; decr_dim--) {
  445          int f_simplex_dim = complex.
dimension(f_simplex);
  446          if (decr_dim == f_simplex_dim) {
  448            if (isnan(complex.filtration(f_simplex))) {
  451              if (Weighted || f_simplex_dim > 0) {
  452                auto const& sqrad = radius(complex, f_simplex);
  453#if CGAL_VERSION_NR >= 1050000000
  454                if(exact) CGAL::exact(sqrad);
  456                alpha_complex_filtration = cgal_converter(sqrad);
  460              std::clog <<
"filt(Sigma) is NaN : filt(Sigma) =" << complex.filtration(f_simplex) << std::endl;
  464            if (decr_dim > !Weighted)
  465              propagate_alpha_filtration(complex, f_simplex);
  468        old_cache_ = std::move(cache_);
  486  template <
typename Simplex_handle>
  494    for (
auto face_opposite_vertex : complex.boundary_opposite_vertex_simplex_range(f_simplex)) {
  495      auto f_boundary = face_opposite_vertex.first;
  497      std::clog <<
" | --------------------------------------------------\n";
  498      std::clog <<
" | Tau ";
  500        std::clog << vertex <<
  502      std::clog <<
"is a face of Sigma\n";
  503      std::clog <<
" | isnan(complex.filtration(Tau)=" << isnan(complex.filtration(f_boundary)) << std::endl;
  506      if (!isnan(complex.filtration(f_boundary))) {
  508        Filtration_value alpha_complex_filtration = fmin(complex.filtration(f_boundary),
  509        complex.filtration(f_simplex));
  512        std::clog <<
" | filt(Tau) = fmin(filt(Tau), filt(Sigma)) = " << complex.filtration(f_boundary) << std::endl;
  516        auto const& cache=get_cache(complex, f_boundary);
  517        bool is_gab = kernel_.is_gabriel(cache, get_point_(face_opposite_vertex.second));
  519        std::clog <<
" | Tau is_gabriel(Sigma)=" << is_gab <<
" - vertexForGabriel=" << face_opposite_vertex.second << std::endl;
  522        if (
false == is_gab) {
  527          std::clog <<
" | filt(Tau) = filt(Sigma) = " << complex.filtration(f_boundary) << std::endl;
  537namespace alphacomplex = alpha_complex;
OFF file reader implementation in order to read points from an OFF file.
Definition: Points_off_io.h:122
const std::vector< Point_d > & get_point_cloud() const
Point cloud getter.
Definition: Points_off_io.h:158
bool is_valid() const
Returns if the OFF file read operation was successful or not.
Definition: Points_off_io.h:150
Alpha complex data structure.
Definition: Alpha_complex.h:103
bool create_complex(SimplicialComplexForAlpha &complex, Filtration_value max_alpha_square=std::numeric_limits< Filtration_value >::infinity(), bool exact=false, bool default_filtration_value=false)
Inserts all Delaunay triangulation into the simplicial complex. It also computes the filtration value...
Definition: Alpha_complex.h:374
std::conditional_t< Weighted, CGAL::Regular_triangulation< Kernel, TDS >, CGAL::Delaunay_triangulation< Kernel, TDS > > Triangulation
A (Weighted or not) Delaunay triangulation of a set of points in .
Definition: Alpha_complex.h:119
typename A_kernel_d::Sphere Sphere
Sphere is a std::pair<Kernel::Point_d, Kernel::FT> (aka. circurmcenter and squared radius)....
Definition: Alpha_complex.h:130
Alpha_complex(const InputPointRange &points, WeightRange weights)
Alpha_complex constructor from a list of points and weights.
Definition: Alpha_complex.h:206
std::conditional_t< Weighted, CGAL::Regular_triangulation_traits_adapter< Kernel >, Kernel > Geom_traits
Geometric traits class that provides the geometric types and predicates needed by the triangulations.
Definition: Alpha_complex.h:110
const Point_d & get_point(std::size_t vertex) const
get_point returns the point corresponding to the vertex given as parameter.
Definition: Alpha_complex.h:237
Alpha_complex(const std::string &off_file_name)
Alpha_complex constructor from an OFF file name.
Definition: Alpha_complex.h:168
typename Geom_traits::Point_d Point_d
A point, or a weighted point in Euclidean space.
Definition: Alpha_complex.h:133
std::size_t num_vertices() const
Returns the number of finite vertices in the triangulation.
Definition: Alpha_complex.h:224
Alpha_complex(const InputPointRange &points)
Alpha_complex constructor from a list of points.
Definition: Alpha_complex.h:189
Alpha complex kernel container.
Definition: Alpha_kernel_d.h:42
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
The concept SimplicialComplexForAlpha describes the requirements for a type to implement a simplicial...
Definition: SimplicialComplexForAlpha.h:21
Skeleton_simplex_range skeleton_simplex_range
Returns a range over the simplices of the skeleton of the simplicial complex, for a given dimension.
Definition: SimplicialComplexForAlpha.h:70
int assign_filtration(Simplex_handle simplex, Filtration_value filtration)
int dimension(Simplex_handle simplex)
void prune_above_filtration(Filtration_value filtration)
void make_filtration_non_decreasing()
Simplex_vertex_range simplex_vertex_range(Simplex_handle const &simplex)
Returns a range over vertices of a given simplex.
void insert_simplex_and_subfaces(std::vector< Vertex_handle > const &vertex_range, Filtration_value filtration)
Inserts a simplex with vertices from a given simplex (represented by a vector of Vertex_handle) in th...
unspecified Simplex_handle
Definition: SimplicialComplexForAlpha.h:23
unspecified Vertex_handle
Definition: SimplicialComplexForAlpha.h:25
unspecified Filtration_value
Definition: SimplicialComplexForAlpha.h:27
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
