#include <gudhi/Rips_complex.h>
#include <gudhi/Simplex_tree.h>
#include <gudhi/Persistent_cohomology.h>
#include <gudhi/Persistent_cohomology/Multi_field.h>
#include <gudhi/Points_off_io.h>
#include <boost/program_options.hpp>
#include <string>
#include <vector>
using Point = std::vector<double>;
void program_options(int argc, char * argv[]
                     , std::string & off_file_points
                     , std::string & filediag
                     , int & dim_max
                     , int & min_p
                     , int & max_p
int main(int argc, char * argv[]) {
  std::string off_file_points;
  std::string filediag;
  int dim_max;
  int min_p;
  int max_p;
  program_options(argc, argv, off_file_points, filediag, threshold, dim_max, min_p, max_p, min_persistence);
  rips_complex_from_file.create_complex(simplex_tree, dim_max);
  std::clog <<
"The complex contains " << simplex_tree.
num_simplices() <<
" simplices \n";
  std::clog <<
"   and has dimension " << simplex_tree.
dimension() <<
" \n";
  pcoh.init_coefficients(min_p, max_p);
  pcoh.compute_persistent_cohomology(min_persistence);
  if (filediag.empty()) {
    pcoh.output_diagram();
  } else {
    std::ofstream out(filediag);
    pcoh.output_diagram(out);
    out.close();
  return 0;
                     , int & dim_max
                     , int & min_p
                     , int & max_p
  namespace po = boost::program_options;
  po::options_description hidden("Hidden options");
  hidden.add_options()
      ("input-file", po::value<std::string>(&off_file_points),
       "Name of an OFF file containing a point set.\n");
  po::options_description visible("Allowed options");
  visible.add_options()
      ("help,h", "produce help message")
      ("output-file,o", po::value<std::string>(&filediag)->default_value(std::string()),
       "Name of file in which the persistence diagram is written. Default print in standard output")
      ("max-edge-length,r", po::value<Filtration_value>(&threshold)->default_value(0),
       "Maximal length of an edge for the Rips complex construction.")
      ("cpx-dimension,d", po::value<int>(&dim_max)->default_value(1),
       "Maximal dimension of the Rips complex we want to compute.")
      ("min-field-charac,p", po::value<int>(&min_p)->default_value(2),
       "Minimal characteristic p of the coefficient field Z/pZ.")
      ("max-field-charac,q", po::value<int>(&max_p)->default_value(1223),
       "Maximal characteristic q of the coefficient field Z/pZ.")
      ("min-persistence,m", po::value<Filtration_value>(&min_persistence),
       "Minimal lifetime of homology feature to be recorded. Default is 0");
  po::positional_options_description pos;
  pos.add("input-file", 1);
  po::options_description all;
  all.add(visible).add(hidden);
  po::variables_map vm;
  po::store(po::command_line_parser(argc, argv).
            options(all).positional(pos).run(), vm);
  po::notify(vm);
  if (vm.count("help") || !vm.count("input-file")) {
    std::clog << std::endl;
    std::clog << "Compute the persistent homology with various coefficient fields \n";
    std::clog << "of a Rips complex defined on a set of input points. The coefficient \n";
    std::clog << "fields are all the Z/rZ for a prime number r contained in the \n";
    std::clog << "specified range [p,q]\n \n";
    std::clog << "The output diagram contains one bar per line, written with the convention: \n";
    std::clog << "   p1*...*pr   dim b d \n";
    std::clog << "where dim is the dimension of the homological feature,\n";
    std::clog << "b and d are respectively the birth and death of the feature and \n";
    std::clog << "p1*...*pr is the product of prime numbers pi such that the homology \n";
    std::clog << "feature exists in homology with Z/piZ coefficients." << std::endl << std::endl;
    std::clog << "Usage: " << argv[0] << " [options] input-file" << std::endl << std::endl;
    std::clog << visible << std::endl;
    exit(-1);
Compute the Euclidean distance between two Points given by a range of coordinates....
Definition: distance_functions.h:32
OFF file reader implementation in order to read points from an OFF file.
Definition: Points_off_io.h:122
Options::Filtration_value Filtration_value
Type for the value of the filtration function.
Definition: Simplex_tree.h:88
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:602
size_t num_simplices()
returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:580
Structure representing coefficients in a set of finite fields simultaneously using the chinese remain...
Definition: Multi_field.h:31
Computes the persistent cohomology of a filtered complex.
Definition: Persistent_cohomology.h:52
Rips complex data structure.
Definition: Rips_complex.h:45
Global distance functions.
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
