#include <gudhi/Rips_complex.h>
#include <gudhi/Simplex_tree.h>
#include <gudhi/Persistent_cohomology.h>
#include <gudhi/writing_persistence_to_file.h>
#include <boost/program_options.hpp>
#include <string>
#include <vector>
#include <limits>
#include <algorithm>
using Correlation_matrix = std::vector<std::vector<Filtration_value>>;
void program_options(int argc, char* argv[], std::string& csv_matrix_file, std::string& filediag,
int main(int argc, char* argv[]) {
  std::string csv_matrix_file;
  std::string filediag;
  int dim_max;
  int p;
  program_options(argc, argv, csv_matrix_file, filediag, correlation_min, dim_max, p, min_persistence);
  Correlation_matrix correlations =
      Gudhi::read_lower_triangular_matrix_from_csv_file<Filtration_value>(csv_matrix_file);
  for (size_t i = 0; i != correlations.size(); ++i) {
    for (size_t j = 0; j != correlations[i].size(); ++j) {
      correlations[i][j] = 1 - correlations[i][j];
      if ((correlations[i][j] < -1) || (correlations[i][j] > 1)) {
        std::cerr << "The input matrix is not a correlation matrix. The program will now terminate. \n";
        throw "The input matrix is not a correlation matrix. The program will now terminate. \n";
      if (correlations[i][j] > threshold) threshold = correlations[i][j];
  Rips_complex rips_complex_from_file(correlations, threshold);
  rips_complex_from_file.create_complex(simplex_tree, dim_max);
  std::clog <<
"The complex contains " << simplex_tree.
num_simplices() <<
" simplices \n";
  std::clog <<
"   and has dimension " << simplex_tree.
dimension() <<
" \n";
  pcoh.init_coefficients(p);
  pcoh.compute_persistent_cohomology(min_persistence);
  auto pairs = pcoh.get_persistent_pairs();
  std::vector<intervals_common> processed_persistence_intervals;
  processed_persistence_intervals.reserve(pairs.size());
  for (auto pair : pairs) {
    double birth = 1 - simplex_tree.
filtration(get<0>(pair));
    double death = 1 - simplex_tree.
filtration(get<1>(pair));
    unsigned dimension = (unsigned)simplex_tree.
dimension(get<0>(pair));
    int field = get<2>(pair);
    processed_persistence_intervals.push_back(
intervals_common(birth, death, dimension, field));
  std::sort(processed_persistence_intervals.begin(), processed_persistence_intervals.end());
  if (filediag.empty()) {
    write_persistence_intervals_to_stream(processed_persistence_intervals);
  } else {
    std::ofstream out(filediag);
    write_persistence_intervals_to_stream(processed_persistence_intervals, out);
  return 0;
  namespace po = boost::program_options;
  po::options_description hidden("Hidden options");
  hidden.add_options()(
      "input-file", po::value<std::string>(&csv_matrix_file),
      "Name of file containing a corelation matrix. Can be square or lower triangular matrix. Separator is ';'.");
  po::options_description visible("Allowed options", 100);
  visible.add_options()("help,h", "produce help message")(
      "output-file,o", po::value<std::string>(&filediag)->default_value(std::string()),
      "Name of file in which the persistence diagram is written. Default print in standard output")(
      "min-edge-corelation,c", po::value<Filtration_value>(&correlation_min)->default_value(0),
      "Minimal corelation of an edge for the Rips complex construction.")(
      "cpx-dimension,d", po::value<int>(&dim_max)->default_value(1),
      "Maximal dimension of the Rips complex we want to compute.")(
      "field-charac,p", po::value<int>(&p)->default_value(11),
      "Characteristic p of the coefficient field Z/pZ for computing homology.")(
      "min-persistence,m", po::value<Filtration_value>(&min_persistence),
      "Minimal lifetime of homology feature to be recorded. Default is 0. Enter a negative value to see zero length "
      "intervals");
  po::positional_options_description pos;
  pos.add("input-file", 1);
  po::options_description all;
  all.add(visible).add(hidden);
  po::variables_map vm;
  po::store(po::command_line_parser(argc, argv).options(all).positional(pos).run(), vm);
  po::notify(vm);
  if (vm.count("help") || !vm.count("input-file")) {
    std::clog << std::endl;
    std::clog << "Compute the persistent homology with coefficient field Z/pZ \n";
    std::clog << "of a Rips complex defined on a corelation matrix.\n \n";
    std::clog << "The output diagram contains one bar per line, written with the convention: \n";
    std::clog << "   p   dim b d \n";
    std::clog << "where dim is the dimension of the homological feature,\n";
    std::clog << "b and d are respectively the birth and death of the feature and \n";
    std::clog << "p is the characteristic of the field Z/pZ used for homology coefficients." << std::endl << std::endl;
    std::clog << "Usage: " << argv[0] << " [options] input-file" << std::endl << std::endl;
    std::clog << visible << std::endl;
    exit(-1);
Definition: writing_persistence_to_file.h:26
Options::Filtration_value Filtration_value
Type for the value of the filtration function.
Definition: Simplex_tree.h:88
static Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
Definition: Simplex_tree.h:537
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:602
size_t num_simplices()
returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:580
Structure representing the coefficient field .
Definition: Field_Zp.h:27
Computes the persistent cohomology of a filtered complex.
Definition: Persistent_cohomology.h:52
Rips complex data structure.
Definition: Rips_complex.h:45
This file includes common file reader for GUDHI.
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
