#include <sys/types.h>
#include <sys/stat.h>
#include <gudhi/Simplex_tree.h>
#include <gudhi/Euclidean_witness_complex.h>
#include <gudhi/pick_n_random_points.h>
#include <gudhi/choose_n_farthest_points.h>
#include <gudhi/Points_off_io.h>
#include <CGAL/Epick_d.h>
#include <iostream>
#include <fstream>
#include <ctime>
#include <string>
#include <vector>
using K = CGAL::Epick_d<CGAL::Dynamic_dimension_tag>;
using Point_d = K::Point_d;
using Point_vector = std::vector< Point_d >;
int main(int argc, char * const argv[]) {
  if (argc != 5) {
    std::cerr << "Usage: " << argv[0]
        << " path_to_point_file number_of_landmarks max_squared_alpha limit_dimension\n";
    return 0;
  std::string file_name = argv[1];
  int nbL = atoi(argv[2]), lim_dim = atoi(argv[4]);
  double alpha2 = atof(argv[3]);
  clock_t start, end;
  Point_vector point_vector, landmarks;
      std::cerr << "Witness complex - Unable to read file " << file_name << "\n";
      exit(-1);
  std::clog << "Successfully read " << point_vector.size() << " points.\n";
  std::clog << "Ambient dimension is " << point_vector[0].dimension() << ".\n";
  start = clock();
                                  point_vector);
  end = clock();
  std::clog << "Witness complex took "
      << static_cast<double>(end - start) / CLOCKS_PER_SEC << " s. \n";
  std::clog <<
"Number of simplices is: " << simplex_tree.
num_simplices() <<
"\n";
OFF file reader implementation in order to read points from an OFF file.
Definition: Points_off_io.h:122
const std::vector< Point_d > & get_point_cloud() const
Point cloud getter.
Definition: Points_off_io.h:158
bool is_valid() const
Returns if the OFF file read operation was successful or not.
Definition: Points_off_io.h:150
Simplex Tree data structure for representing simplicial complexes.
Definition: Simplex_tree.h:81
size_t num_simplices()
returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:580
Constructs strong witness complex for given sets of witnesses and landmarks in Euclidean space.
Definition: Euclidean_strong_witness_complex.h:51
Constructs (weak) witness complex for given sets of witnesses and landmarks in Euclidean space.
Definition: Euclidean_witness_complex.h:53
bool create_complex(SimplicialComplexForWitness &complex, double max_alpha_square, Landmark_id limit_dimension=std::numeric_limits< Landmark_id >::max()) const
Outputs the strong witness complex of relaxation 'max_alpha_square' in a simplicial complex data stru...
Definition: Strong_witness_complex.h:87
void choose_n_farthest_points(Distance dist, Point_range const &input_pts, std::size_t final_size, std::size_t starting_point, PointOutputIterator output_it, DistanceOutputIterator dist_it={})
Subsample by a greedy strategy of iteratively adding the farthest point from the current chosen point...
Definition: choose_n_farthest_points.h:69
@ random_starting_point
Definition: choose_n_farthest_points.h:34
