#include <gudhi/Tangential_complex.h>
#include <gudhi/sparsify_point_set.h>
#include <gudhi/Simplex_tree.h>
#include <CGAL/Epick_d.h>
#include <CGAL/Random.h>
#include <array>
#include <vector>
namespace subsampl = Gudhi::subsampling;
namespace tc = Gudhi::tangential_complex;
typedef CGAL::Epick_d<CGAL::Dimension_tag < 3 >> Kernel;
typedef Kernel::FT FT;
typedef Kernel::Point_d Point;
typedef Kernel::Vector_d Vector;
Kernel, CGAL::Dimension_tag<2>,
int main(void) {
  const int INTRINSIC_DIM = 2;
  const int AMBIENT_DIM = 3;
  const int NUM_POINTS = 50;
  Kernel k;
  CGAL::Random_points_on_sphere_d<Point> generator(AMBIENT_DIM, 3.);
  std::vector<Point> points;
  points.reserve(NUM_POINTS);
  for (int i = 0; i < NUM_POINTS; ++i)
    points.push_back(*generator++);
  std::vector<Point> sparsified_points;
                               std::back_inserter(sparsified_points));
  sparsified_points.swap(points);
  TC tc(points, INTRINSIC_DIM, k);
  return 0;
Simplex Tree data structure for representing simplicial complexes.
Definition: Simplex_tree.h:81
Tangential complex data structure.
Definition: Tangential_complex.h:126
Fix_inconsistencies_info fix_inconsistencies_using_perturbation(double max_perturb, double time_limit=-1.)
Attempts to fix inconsistencies by perturbing the point positions.
Definition: Tangential_complex.h:397
void compute_tangential_complex()
Computes the tangential complex.
Definition: Tangential_complex.h:331
int create_complex(Simplex_tree_ &tree, bool export_inconsistent_simplices=true) const
Exports the complex into a Simplex_tree.
Definition: Tangential_complex.h:612
void sparsify_point_set(const Kernel &k, Point_range const &input_pts, typename Kernel::FT min_squared_dist, OutputIterator output_it)
Outputs a subset of the input points so that the squared distance between any two points is greater t...
Definition: sparsify_point_set.h:50
