#include <gudhi/sparsify_point_set.h>
#include <CGAL/Epick_d.h>
#include <CGAL/Random.h>
#include <iostream>
#include <vector>
#include <iterator>
int main(void) {
  typedef CGAL::Epick_d<CGAL::Dimension_tag<4> > K;
  typedef typename K::Point_d Point_d;
  CGAL::Random rd;
  std::vector<Point_d> points;
  for (int i = 0; i < 500; ++i)
    points.push_back(Point_d(rd.get_double(-1., 1), rd.get_double(-1., 1),
                             rd.get_double(-1., 1), rd.get_double(-1., 1)));
  K k;
  std::vector<Point_d> results;
  std::clog << "Before sparsification: " << points.size() << " points.\n";
  std::clog << "After  sparsification: " << results.size() << " points.\n";
  return 0;
void sparsify_point_set(const Kernel &k, Point_range const &input_pts, typename Kernel::FT min_squared_dist, OutputIterator output_it)
Outputs a subset of the input points so that the squared distance between any two points is greater t...
Definition: sparsify_point_set.h:50
