Toplex_map
#include <gudhi/pick_n_random_points.h>
#include <CGAL/Epick_d.h>
#include <CGAL/Random.h>
#include <iostream>
#include <vector>
#include <iterator>
int main(void) {
  typedef CGAL::Epick_d<CGAL::Dimension_tag<4> > K;
  typedef typename K::Point_d Point_d;
  CGAL::Random rd;
  std::vector<Point_d> points;
  for (int i = 0; i < 500; ++i)
    points.push_back(Point_d(rd.get_double(-1., 1), rd.get_double(-1., 1),
                             rd.get_double(-1., 1), rd.get_double(-1., 1)));
  K k;
  std::vector<Point_d> results;
  std::clog << "Before sparsification: " << points.size() << " points.\n";
  std::clog << "After  sparsification: " << results.size() << " points.\n";
  return 0;
void pick_n_random_points(Point_container const &points, std::size_t final_size, OutputIterator output_it)
Subsample a point set by picking random vertices.
Definition: pick_n_random_points.h:42
