#include <gudhi/Rips_complex.h>
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <string>
#include <vector>
#include <limits>
int main() {
  using Point = std::vector<double>;
  std::vector<Point> points;
  points.push_back({1.0, 1.0});
  points.push_back({7.0, 0.0});
  points.push_back({4.0, 6.0});
  points.push_back({9.0, 6.0});
  points.push_back({0.0, 14.0});
  points.push_back({2.0, 19.0});
  points.push_back({9.0, 17.0});
  double threshold = 12.0;
  std::clog <<
"Rips complex is of dimension " << stree.
dimension() <<
  std::clog << "Iterator on Rips complex simplices in the filtration order, with [filtration value]:" <<
               std::endl;
    std::clog << "   ( ";
      std::clog << vertex << " ";
    std::clog <<
"[" << stree.
filtration(f_simplex) <<
    std::clog << std::endl;
  return 0;
Compute the Euclidean distance between two Points given by a range of coordinates....
Definition: distance_functions.h:32
Options::Filtration_value Filtration_value
Type for the value of the filtration function.
Definition: Simplex_tree.h:88
Filtration_simplex_range const & filtration_simplex_range(Indexing_tag=Indexing_tag())
Returns a range over the simplices of the simplicial complex, in the order of the filtration.
Definition: Simplex_tree.h:273
Simplex_vertex_range simplex_vertex_range(Simplex_handle sh) const
Returns a range over the vertices of a simplex.
Definition: Simplex_tree.h:284
static Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
Definition: Simplex_tree.h:537
size_t num_vertices() const
Returns the number of vertices in the complex.
Definition: Simplex_tree.h:574
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:602
size_t num_simplices()
returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:580
Rips complex data structure.
Definition: Rips_complex.h:45
void create_complex(SimplicialComplexForRips &complex, int dim_max)
Initializes the simplicial complex from the Rips graph and expands it until a given maximal dimension...
Definition: Rips_complex.h:101
Global distance functions.
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
