#include <gudhi/Rips_complex.h>
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <string>
#include <vector>
#include <limits>
int main() {
  using Distance_matrix = std::vector<std::vector<Filtration_value>>;
  Distance_matrix correlations;
  correlations.push_back({});
  correlations.push_back({0.06});
  correlations.push_back({0.23, 0.74});
  correlations.push_back({0.01, 0.01, 0.72});
  correlations.push_back({0.89, 0.61, 0.03, 0.7});
  double threshold = 0;
  for (size_t i = 0; i != correlations.size(); ++i) {
    for (size_t j = 0; j != correlations[i].size(); ++j) {
      if ((correlations[i][j] < -1) || (correlations[i][j] > 1)) {
        std::cerr << "The input matrix is not a correlation matrix. The program will now terminate.\n";
        throw "The input matrix is not a correlation matrix. The program will now terminate.\n";
      correlations[i][j] = 1 - correlations[i][j];
      if (correlations[i][j] > threshold) threshold = correlations[i][j];
  Distance_matrix distances = correlations;
  Rips_complex rips_complex_from_points(distances, threshold);
  std::clog <<
"Rips complex is of dimension " << stree.
dimension() <<
" - " << stree.
num_simplices() <<
" simplices - "
  std::clog << "Iterator on Rips complex simplices in the filtration order, with [filtration value]:" << std::endl;
    std::clog << "   ( ";
      std::clog << vertex << " ";
    std::clog << ") -> "
    std::clog << std::endl;
  return 0;
Options::Filtration_value Filtration_value
Type for the value of the filtration function.
Definition: Simplex_tree.h:88
Filtration_simplex_range const & filtration_simplex_range(Indexing_tag=Indexing_tag())
Returns a range over the simplices of the simplicial complex, in the order of the filtration.
Definition: Simplex_tree.h:273
Simplex_vertex_range simplex_vertex_range(Simplex_handle sh) const
Returns a range over the vertices of a simplex.
Definition: Simplex_tree.h:284
static Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
Definition: Simplex_tree.h:537
size_t num_vertices() const
Returns the number of vertices in the complex.
Definition: Simplex_tree.h:574
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:602
size_t num_simplices()
returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:580
Rips complex data structure.
Definition: Rips_complex.h:45
void create_complex(SimplicialComplexForRips &complex, int dim_max)
Initializes the simplicial complex from the Rips graph and expands it until a given maximal dimension...
Definition: Rips_complex.h:101
Global distance functions.
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
