#include <gudhi/Flag_complex_edge_collapser.h>
#include <gudhi/Simplex_tree.h>
#include <gudhi/Persistent_cohomology.h>
#include <boost/program_options.hpp>
#include <boost/range/adaptor/transformed.hpp>
using Filtered_edge = std::tuple<Vertex_handle, Vertex_handle, Filtration_value>;
using Distance_matrix = std::vector<std::vector<Filtration_value>>;
void program_options(int argc, char* argv[], std::string& csv_matrix_file, std::string& filediag,
int main(int argc, char* argv[]) {
  std::string csv_matrix_file;
  std::string filediag;
  int dim_max = 2;
  int p;
  int edge_collapse_iter_nb;
  program_options(argc, argv, csv_matrix_file, filediag, threshold, dim_max, p, edge_collapse_iter_nb,
                  min_persistence);
  Distance_matrix distances = Gudhi::read_lower_triangular_matrix_from_csv_file<Filtration_value>(csv_matrix_file);
  std::cout << "Read the distance matrix successfully, of size: " << distances.size() << std::endl;
  Proximity_graph proximity_graph = Gudhi::compute_proximity_graph<Simplex_tree>(boost::irange((size_t)0,
        distances.size()),
        threshold,
        [&distances](size_t i, size_t j) {
        return distances[j][i];
  auto edges_from_graph = boost::adaptors::transform(edges(proximity_graph), [&](auto&&edge){
        return std::make_tuple(source(edge, proximity_graph),
                               target(edge, proximity_graph),
                               get(Gudhi::edge_filtration_t(), proximity_graph, edge));
  std::vector<Filtered_edge> edges_list(edges_from_graph.begin(), edges_from_graph.end());
  std::vector<Filtered_edge> remaining_edges;
  for (int iter = 0; iter < edge_collapse_iter_nb; iter++) {
    auto remaining_edges = Gudhi::collapse::flag_complex_collapse_edges(edges_list);
    edges_list = std::move(remaining_edges);
    remaining_edges.clear();
  for (
Vertex_handle vertex = 0;
static_cast<std::size_t
>(vertex) < distances.size(); vertex++) {
  for (auto filtered_edge : edges_list) {
    stree.
insert_simplex({std::get<0>(filtered_edge), std::get<1>(filtered_edge)}, std::get<2>(filtered_edge));
  std::cout <<
"The complex contains " << stree.
num_simplices() <<
" simplices  after collapse. \n";
  std::cout <<
"   and has dimension " << stree.
dimension() <<
" \n";
  pcoh.init_coefficients(3);
  pcoh.compute_persistent_cohomology(min_persistence);
  if (filediag.empty()) {
    pcoh.output_diagram();
  } else {
    std::ofstream out(filediag);
    pcoh.output_diagram(out);
    out.close();
  return 0;
  namespace po = boost::program_options;
  po::options_description hidden("Hidden options");
  hidden.add_options()(
      "input-file", po::value<std::string>(&csv_matrix_file),
      "Name of file containing a distance matrix. Can be square or lower triangular matrix. Separator is ';'.");
  po::options_description visible("Allowed options", 100);
  visible.add_options()("help,h", "produce help message")(
      "output-file,o", po::value<std::string>(&filediag)->default_value(std::string()),
      "Name of file in which the persistence diagram is written. Default print in standard output")(
      "max-edge-length,r",
      po::value<Filtration_value>(&threshold)->default_value(std::numeric_limits<Filtration_value>::infinity()),
      "Maximal length of an edge for the Rips complex construction.")(
      "cpx-dimension,d", po::value<int>(&dim_max)->default_value(1),
      "Maximal dimension of the Rips complex we want to compute.")(
      "field-charac,p", po::value<int>(&p)->default_value(11),
      "Characteristic p of the coefficient field Z/pZ for computing homology.")(
      "edge-collapse-iterations,i", po::value<int>(&edge_collapse_iter_nb)->default_value(1),
      "Number of iterations edge collapse is performed.")(
      "min-persistence,m", po::value<Filtration_value>(&min_persistence),
      "Minimal lifetime of homology feature to be recorded. Default is 0. Enter a negative value to see zero length "
      "intervals");
  po::positional_options_description pos;
  pos.add("input-file", 1);
  po::options_description all;
  all.add(visible).add(hidden);
  po::variables_map vm;
  po::store(po::command_line_parser(argc, argv).options(all).positional(pos).run(), vm);
  po::notify(vm);
  if (vm.count("help") || !vm.count("input-file")) {
    std::cout << std::endl;
    std::cout << "Compute the persistent homology with coefficient field Z/pZ \n";
    std::cout << "of a Rips complex after edge collapse defined on a set of distance matrix.\n \n";
    std::cout << "The output diagram contains one bar per line, written with the convention: \n";
    std::cout << "   p   dim b d \n";
    std::cout << "where dim is the dimension of the homological feature,\n";
    std::cout << "b and d are respectively the birth and death of the feature and \n";
    std::cout << "p is the characteristic of the field Z/pZ used for homology coefficients." << std::endl << std::endl;
    std::cout << "Usage: " << argv[0] << " [options] input-file" << std::endl << std::endl;
    std::cout << visible << std::endl;
    exit(-1);
Options::Filtration_value Filtration_value
Type for the value of the filtration function.
Definition: Simplex_tree.h:88
std::pair< Simplex_handle, bool > insert_simplex(const InputVertexRange &simplex, Filtration_value filtration=0)
Insert a simplex, represented by a range of Vertex_handles, in the simplicial complex.
Definition: Simplex_tree.h:782
void initialize_filtration()
Initializes the filtration cache, i.e. sorts the simplices according to their order in the filtration...
Definition: Simplex_tree.h:916
Options::Vertex_handle Vertex_handle
Type for the vertex handle.
Definition: Simplex_tree.h:96
void expansion(int max_dim)
Expands the Simplex_tree containing only its one skeleton until dimension max_dim.
Definition: Simplex_tree.h:1185
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:602
size_t num_simplices()
returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:580
Structure representing the coefficient field .
Definition: Field_Zp.h:27
Computes the persistent cohomology of a filtered complex.
Definition: Persistent_cohomology.h:52
Graph simplicial complex methods.
typename boost::adjacency_list< boost::vecS, boost::vecS, boost::directedS, boost::property< vertex_filtration_t, typename SimplicialComplexForProximityGraph::Filtration_value >, boost::property< edge_filtration_t, typename SimplicialComplexForProximityGraph::Filtration_value > > Proximity_graph
Proximity_graph contains the vertices and edges with their filtration values in order to store the re...
Definition: graph_simplicial_complex.h:45
This file includes common file reader for GUDHI.
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
