#include <gudhi/Bitmap_cubical_complex.h>
#include <gudhi/Persistent_cohomology.h>
#include <iostream>
#include <string>
#include <vector>
#include <cstddef>
int main(int argc, char** argv) {
  std::clog
      << "This program computes persistent homology, by using bitmap_cubical_complex class, of cubical "
      << "complexes provided in text files in Perseus style (the only numbered in the first line is a dimension D of a"
      << "bitmap. In the lines I between 2 and D+1 there are numbers of top dimensional cells in the direction I. Let "
      << "N denote product of the numbers in the lines between 2 and D. In the lines D+2 to D+2+N there are "
      << "filtrations of top dimensional cells. We assume that the cells are in the lexicographical order. See "
      << "CubicalOneSphere.txt or CubicalTwoSphere.txt for example.\n"
      << std::endl;
  if (argc != 2) {
    std::cerr << "Wrong number of parameters. Please provide the name of a file with a Perseus style bitmap at "
              << "the input. The program will now terminate.\n";
    return 1;
  Bitmap_cubical_complex b(argv[1]);
  int p = 11;
  double min_persistence = 0;
  std::string output_file_name(argv[1]);
  output_file_name += "_persistence";
  std::size_t last_in_path = output_file_name.find_last_of("/\\");
  if (last_in_path != std::string::npos) {
    output_file_name = output_file_name.substr(last_in_path + 1);
  std::ofstream out(output_file_name.c_str());
  out.close();
  std::clog << "Result in file: " << output_file_name << "\n";
  return 0;
Cubical complex represented as a bitmap, class with basic implementation.
Definition: Bitmap_cubical_complex_base.h:53
Cubical complex represented as a bitmap.
Definition: Bitmap_cubical_complex.h:48
Structure representing the coefficient field .
Definition: Field_Zp.h:27
Computes the persistent cohomology of a filtered complex.
Definition: Persistent_cohomology.h:52
void output_diagram(std::ostream &ostream=std::cout)
Output the persistence diagram in ostream.
Definition: Persistent_cohomology.h:561
void compute_persistent_cohomology(Filtration_value min_interval_length=0)
Compute the persistent homology of the filtered simplicial complex.
Definition: Persistent_cohomology.h:172
void init_coefficients(int charac)
Initializes the coefficient field.
Definition: Persistent_cohomology.h:156
This file includes common file reader for GUDHI.
