#include <gudhi/Simplex_tree.h>
#include <gudhi/Points_off_io.h>
#include <CGAL/Epick_d.h>
#include <CGAL/Min_sphere_of_spheres_d.h>
#include <CGAL/Min_sphere_of_points_d_traits_d.h>
#include <boost/program_options.hpp>
#include <string>
#include <vector>
#include <limits>
#include <utility>
#include <map>
using Graph_t = boost::adjacency_list<boost::vecS, boost::vecS, boost::directedS,
                                      boost::property<Gudhi::vertex_filtration_t, Filtration_value>,
                                      boost::property<Gudhi::edge_filtration_t, Filtration_value> >;
using Edge_t = std::pair<Vertex_handle, Vertex_handle>;
using Kernel = CGAL::Epick_d<CGAL::Dimension_tag<3> >;
using Point = Kernel::Point_d;
using Traits = CGAL::Min_sphere_of_points_d_traits_d<Kernel, Filtration_value, 3>;
using Min_sphere = CGAL::Min_sphere_of_spheres_d<Traits>;
class Cech_blocker {
 public:
  bool operator()(Simplex_handle sh) {
    std::vector<Point> points;
#if DEBUG_TRACES
    std::clog << "Cech_blocker on [";
#endif
    for (auto vertex : simplex_tree_.simplex_vertex_range(sh)) {
      points.push_back(point_cloud_[vertex]);
#if DEBUG_TRACES
      std::clog << vertex << ", ";
#endif
    Min_sphere ms(points.begin(), points.end());
#if DEBUG_TRACES
    std::clog << "] - radius = " << radius << " - returns " << (radius > threshold_) << std::endl;
#endif
    simplex_tree_.assign_filtration(sh, radius);
    return (radius > threshold_);
      : simplex_tree_(simplex_tree), threshold_(threshold), point_cloud_(point_cloud) {}
 private:
  std::vector<Point> point_cloud_;
template <typename InputPointRange>
Graph_t compute_proximity_graph(InputPointRange& points,
Filtration_value threshold);
void program_options(
int argc,
char* argv[], std::string& off_file_points,
Filtration_value& threshold,
int& dim_max);
int main(int argc, char* argv[]) {
  std::string off_file_points;
  int dim_max;
  program_options(argc, argv, off_file_points, threshold, dim_max);
  Graph_t prox_graph = compute_proximity_graph(off_reader.get_point_cloud(), threshold);
  std::clog <<
"The complex contains " << st.
num_simplices() <<
" simplices \n";
  std::clog <<
"   and has dimension " << st.
dimension() <<
" \n";
#if DEBUG_TRACES
  std::clog << "********************************************************************\n";
  std::clog <<
"* The complex contains " << st.
num_simplices() <<
" simplices - dimension=" << st.
dimension() <<
"\n";
  std::clog << "* Iterator on Simplices in the filtration, with [filtration value]:\n";
    std::clog << "   "
      std::clog << static_cast<int>(vertex) << " ";
    std::clog << std::endl;
#endif
  return 0;
int argc,
int& dim_max) {
  namespace po = boost::program_options;
  po::options_description hidden("Hidden options");
  hidden.add_options()("input-file", po::value<std::string>(&off_file_points),
                       "Name of an OFF file containing a 3d point set.\n");
  po::options_description visible("Allowed options", 100);
  visible.add_options()("help,h", "produce help message")(
      "max-edge-length,r",
      po::value<Filtration_value>(&threshold)->default_value(std::numeric_limits<Filtration_value>::infinity()),
      "Maximal length of an edge for the Cech complex construction.")(
      "cpx-dimension,d", po::value<int>(&dim_max)->default_value(1),
      "Maximal dimension of the Cech complex we want to compute.");
  po::positional_options_description pos;
  pos.add("input-file", 1);
  po::options_description all;
  all.add(visible).add(hidden);
  po::variables_map vm;
  po::store(po::command_line_parser(argc, argv).options(all).positional(pos).run(), vm);
  po::notify(vm);
  if (vm.count("help") || !vm.count("input-file")) {
    std::clog << "Construct a Cech complex defined on a set of input points.\n \n";
    std::clog << "Usage: " << argv[0] << " [options] input-file" << std::endl << std::endl;
    std::clog << visible << std::endl;
    exit(-1);
Filtration_value threshold) {
  std::vector<Edge_t> edges;
  std::vector<Filtration_value> edges_fil;
  Kernel k;
  idx_u = 0;
  for (auto it_u = points.begin(); it_u != points.end(); ++it_u) {
    idx_v = idx_u + 1;
    for (auto it_v = it_u + 1; it_v != points.end(); ++it_v, ++idx_v) {
      fil = k.squared_distance_d_object()(*it_u, *it_v);
      fil = std::sqrt(fil) / 2.;
      if (fil <= threshold) {
        edges.emplace_back(idx_u, idx_v);
        edges_fil.push_back(fil);
    ++idx_u;
  Graph_t skel_graph(edges.begin(), edges.end(), edges_fil.begin(),
                     idx_u);
  auto vertex_prop = boost::get(Gudhi::vertex_filtration_t(), skel_graph);
  boost::graph_traits<Graph_t>::vertex_iterator vi, vi_end;
  for (std::tie(vi, vi_end) = boost::vertices(skel_graph); vi != vi_end; ++vi) {
    boost::put(vertex_prop, *vi, 0.);
  return skel_graph;
OFF file reader implementation in order to read points from an OFF file.
Definition: Points_off_io.h:122
Options::Filtration_value Filtration_value
Type for the value of the filtration function.
Definition: Simplex_tree.h:88
Dictionary::iterator Simplex_handle
Handle type to a simplex contained in the simplicial complex represented by the simplex tree.
Definition: Simplex_tree.h:154
Filtration_simplex_range const & filtration_simplex_range(Indexing_tag=Indexing_tag())
Returns a range over the simplices of the simplicial complex, in the order of the filtration.
Definition: Simplex_tree.h:273
Simplex_vertex_range simplex_vertex_range(Simplex_handle sh) const
Returns a range over the vertices of a simplex.
Definition: Simplex_tree.h:284
static Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
Definition: Simplex_tree.h:537
void expansion_with_blockers(int max_dim, Blocker block_simplex)
Expands a simplex tree containing only a graph. Simplices corresponding to cliques in the graph are a...
Definition: Simplex_tree.h:1282
Simplex_tree_siblings< Simplex_tree, Dictionary > Siblings
Set of nodes sharing a same parent in the simplex tree.
Definition: Simplex_tree.h:107
void initialize_filtration()
Initializes the filtration cache, i.e. sorts the simplices according to their order in the filtration...
Definition: Simplex_tree.h:916
Options::Vertex_handle Vertex_handle
Type for the vertex handle.
Definition: Simplex_tree.h:96
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:602
size_t num_simplices()
returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:580
void insert_graph(const OneSkeletonGraph &skel_graph)
Inserts a 1-skeleton in an empty Simplex_tree.
Definition: Simplex_tree.h:1110
Global distance functions.
Graph simplicial complex methods.
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
