#include <boost/program_options.hpp>
#include <boost/variant.hpp>
#include <gudhi/Alpha_complex_3d.h>
#include <gudhi/Simplex_tree.h>
#include <gudhi/Persistent_cohomology.h>
#include <gudhi/Points_3D_off_io.h>
#include <fstream>
#include <string>
#include <vector>
#include <limits>
void program_options(int argc, char *argv[], std::string &off_file_points, bool &exact, bool &safe,
                     std::string &weight_file, std::string &cuboid_file, std::string &output_file_diag,
bool read_weight_file(const std::string &weight_file, std::vector<double> &weights) {
  std::ifstream weights_ifstr(weight_file);
  if (weights_ifstr.good()) {
    double weight = 0.0;
    while (weights_ifstr >> weight) {
      weights.push_back(weight);
  } else {
    return false;
  return true;
bool read_cuboid_file(const std::string &cuboid_file, double &x_min, double &y_min, double &z_min, double &x_max,
                      double &y_max, double &z_max) {
  std::ifstream iso_cuboid_str(cuboid_file);
  if (iso_cuboid_str.is_open()) {
    if (!(iso_cuboid_str >> x_min >> y_min >> z_min >> x_max >> y_max >> z_max)) {
      return false;
  } else {
    return false;
  return true;
template <typename AlphaComplex3d>
std::vector<typename AlphaComplex3d::Bare_point_3> read_off(const std::string &off_file_points) {
  if (!off_reader.is_valid()) {
    std::cerr << "Unable to read OFF file " << off_file_points << std::endl;
    exit(-1);
  return off_reader.get_point_cloud();
int main(int argc, char **argv) {
  std::string off_file_points;
  std::string weight_file;
  std::string cuboid_file;
  std::string output_file_diag;
  int coeff_field_characteristic = 0;
  bool exact_version = false;
  bool fast_version = false;
  bool weighted_version = false;
  bool periodic_version = false;
  program_options(argc, argv, off_file_points, exact_version, fast_version, weight_file, cuboid_file, output_file_diag,
                  alpha_square_max_value, coeff_field_characteristic, min_persistence);
  std::vector<double> weights;
  if (weight_file != std::string()) {
    if (!read_weight_file(weight_file, weights)) {
      std::cerr << "Unable to read weights file " << weight_file << std::endl;
      exit(-1);
    weighted_version = true;
  double x_min = 0., y_min = 0., z_min = 0., x_max = 0., y_max = 0., z_max = 0.;
  std::ifstream iso_cuboid_str(argv[3]);
  if (cuboid_file != std::string()) {
    if (!read_cuboid_file(cuboid_file, x_min, y_min, z_min, x_max, y_max, z_max)) {
      std::cerr << "Unable to read cuboid file " << cuboid_file << std::endl;
      exit(-1);
    periodic_version = true;
  if (exact_version) {
    if (fast_version) {
      std::cerr << "You cannot set the exact and the fast version." << std::endl;
      exit(-1);
  if (fast_version) {
  switch (complexity) {
      if (weighted_version) {
        if (periodic_version) {
          auto points = read_off<Alpha_complex_3d>(off_file_points);
          Alpha_complex_3d alpha_complex(points, weights, x_min, y_min, z_min, x_max, y_max, z_max);
          alpha_complex.create_complex(simplex_tree, alpha_square_max_value);
        } else {
      } else {
          Alpha_complex_3d alpha_complex(points, x_min, y_min, z_min, x_max, y_max, z_max);
        } else {
      break;
        } else {
      } else {
        } else {
      break;
        } else {
      } else {
        } else {
      break;
    default:
      std::cerr << "Unknown complexity value " << std::endl;
      exit(-1);
      break;
  std::clog <<
"Simplex_tree dim: " << simplex_tree.
dimension() << std::endl;
  pcoh.init_coefficients(coeff_field_characteristic);
  pcoh.compute_persistent_cohomology(min_persistence);
  if (output_file_diag.empty()) {
    pcoh.output_diagram();
  } else {
    std::clog << "Result in file: " << output_file_diag << std::endl;
    std::ofstream out(output_file_diag);
    pcoh.output_diagram(out);
    out.close();
  return 0;
void program_options(int argc, char *argv[], std::string &off_file_points, bool &exact, bool &fast,
  namespace po = boost::program_options;
  po::options_description hidden("Hidden options");
  hidden.add_options()("input-file", po::value<std::string>(&off_file_points),
                       "Name of file containing a point set. Format is one point per line:   X1 ... Xd ");
  po::options_description visible("Allowed options", 100);
  visible.add_options()("help,h", "produce help message")(
      "exact,e", po::bool_switch(&exact),
      "To activate exact version of Alpha complex 3d (default is false, not available if fast is set)")(
      "fast,f", po::bool_switch(&fast),
      "To activate fast version of Alpha complex 3d (default is false, not available if exact is set)")(
      "weight-file,w", po::value<std::string>(&weight_file)->default_value(std::string()),
      "Name of file containing a point weights. Format is one weight per line:\n  W1\n  ...\n  Wn ")(
      "cuboid-file,c", po::value<std::string>(&cuboid_file),
      "Name of file describing the periodic domain. Format is:\n  min_hx min_hy min_hz\n  max_hx max_hy max_hz")(
      "output-file,o", po::value<std::string>(&output_file_diag)->default_value(std::string()),
      "Name of file in which the persistence diagram is written. Default print in standard output")(
      "max-alpha-square-value,r",
      po::value<Filtration_value>(&alpha_square_max_value)
          ->default_value(std::numeric_limits<Filtration_value>::infinity()),
      "Maximal alpha square value for the Alpha complex construction.")(
      "field-charac,p", po::value<int>(&coeff_field_characteristic)->default_value(11),
      "Characteristic p of the coefficient field Z/pZ for computing homology.")(
      "min-persistence,m", po::value<Filtration_value>(&min_persistence),
      "Minimal lifetime of homology feature to be recorded. Default is 0. Enter a negative value to see zero length "
      "intervals");
  po::positional_options_description pos;
  pos.add("input-file", 1);
  po::options_description all;
  all.add(visible).add(hidden);
  po::variables_map vm;
  po::store(po::command_line_parser(argc, argv).options(all).positional(pos).run(), vm);
  po::notify(vm);
  if (vm.count("help") || !vm.count("input-file") || !vm.count("weight-file")) {
    std::clog << std::endl;
    std::clog << "Compute the persistent homology with coefficient field Z/pZ \n";
    std::clog << "of a 3D Alpha complex defined on a set of input points.\n";
    std::clog << "3D Alpha complex can be safe (by default) exact or fast, weighted and/or periodic\n\n";
    std::clog << "The output diagram contains one bar per line, written with the convention: \n";
    std::clog << "   p   dim b d \n";
    std::clog << "where dim is the dimension of the homological feature,\n";
    std::clog << "b and d are respectively the birth and death of the feature and \n";
    std::clog << "p is the characteristic of the field Z/pZ used for homology coefficients.\n\n";
    std::clog << "Usage: " << argv[0] << " [options] input-file weight-file\n\n";
    std::clog << visible << std::endl;
    exit(-1);
Definition: Points_3D_off_io.h:140
Options::Filtration_value Filtration_value
Type for the value of the filtration function.
Definition: Simplex_tree.h:88
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:602
Alpha complex data structure for 3d specific case.
Definition: Alpha_complex_3d.h:118
Computes the persistent cohomology of a filtered complex.
Definition: Persistent_cohomology.h:52
complexity
Alpha complex complexity template parameter possible values.
Definition: Alpha_complex_options.h:23
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
