#include <gudhi/Alpha_complex.h>
#include <gudhi/Simplex_tree.h>
#include <CGAL/Epeck_d.h>
#include <iostream>
#include <vector>
using Kernel = CGAL::Epeck_d< CGAL::Dimension_tag<3> >;
using Bare_point = Kernel::Point_d;
using Weighted_point = Kernel::Weighted_point_d;
using Vector_of_points = std::vector<Weighted_point>;
int main() {
  Vector_of_points points;
  points.emplace_back(Bare_point(1, -1, -1), 4.);
  points.emplace_back(Bare_point(-1, 1, -1), 4.);
  points.emplace_back(Bare_point(-1, -1, 1), 4.);
  points.emplace_back(Bare_point(1, 1, 1),   4.);
  points.emplace_back(Bare_point(2, 2, 2),   1.);
    std::clog <<
"Weighted alpha complex is of dimension " << simplex.
dimension() <<
    std::clog << "Iterator on weighted alpha complex simplices in the filtration order, with [filtration value]:" << std::endl;
      std::clog << "   ( ";
        std::clog << vertex << " ";
      std::clog <<
"[" << simplex.
filtration(f_simplex) <<
      std::clog << std::endl;
  return 0;
Simplex Tree data structure for representing simplicial complexes.
Definition: Simplex_tree.h:81
Filtration_simplex_range const & filtration_simplex_range(Indexing_tag=Indexing_tag())
Returns a range over the simplices of the simplicial complex, in the order of the filtration.
Definition: Simplex_tree.h:273
Simplex_vertex_range simplex_vertex_range(Simplex_handle sh) const
Returns a range over the vertices of a simplex.
Definition: Simplex_tree.h:284
static Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
Definition: Simplex_tree.h:537
size_t num_vertices() const
Returns the number of vertices in the complex.
Definition: Simplex_tree.h:574
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:602
size_t num_simplices()
returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:580
Alpha complex data structure.
Definition: Alpha_complex.h:103
bool create_complex(SimplicialComplexForAlpha &complex, Filtration_value max_alpha_square=std::numeric_limits< Filtration_value >::infinity(), bool exact=false, bool default_filtration_value=false)
Inserts all Delaunay triangulation into the simplicial complex. It also computes the filtration value...
Definition: Alpha_complex.h:372
