#include <gudhi/GIC.h>
#include <string>
#include <vector>
void usage(int nbArgs, char *const progName) {
  std::cerr << "Error: Number of arguments (" << nbArgs << ") is not correct\n";
  std::cerr << "Usage: " << progName << " filename.off N [-v] \n";
  std::cerr << "       i.e.: " << progName << " ../../data/points/human.off 100 -v \n";
  exit(-1);
int main(int argc, char **argv) {
  if ((argc != 3) && (argc != 4)) usage(argc, argv[0]);
  using Point = std::vector<float>;
  std::string off_file_name(argv[1]);
  int m = atoi(argv[2]);
  bool verb = 0;
  if (argc == 4) verb = 1;
  if (!check) {
    std::clog << "Incorrect OFF file." << std::endl;
  } else {
    if (verb) {
" simplices - " << stree.
num_vertices() <<
" vertices." << std::endl;
      std::clog << "Iterator on graph induced complex simplices" << std::endl;
          std::clog << vertex << " ";
        std::clog << std::endl;
  return 0;
Compute the Euclidean distance between two Points given by a range of coordinates....
Definition: distance_functions.h:32
Simplex Tree data structure for representing simplicial complexes.
Definition: Simplex_tree.h:81
Filtration_simplex_range const & filtration_simplex_range(Indexing_tag=Indexing_tag())
Returns a range over the simplices of the simplicial complex, in the order of the filtration.
Definition: Simplex_tree.h:273
Simplex_vertex_range simplex_vertex_range(Simplex_handle sh) const
Returns a range over the vertices of a simplex.
Definition: Simplex_tree.h:284
size_t num_vertices() const
Returns the number of vertices in the complex.
Definition: Simplex_tree.h:574
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:602
size_t num_simplices()
returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:580
Cover complex data structure.
Definition: GIC.h:92
void set_cover_from_Voronoi(Distance distance, int m=100)
Creates the cover C from the Voronoï cells of a subsampling of the point cloud.
Definition: GIC.h:878
void create_complex(SimplicialComplex &complex)
Creates the simplicial complex.
Definition: GIC.h:1304
void set_type(const std::string &t)
Specifies whether the type of the output simplicial complex.
Definition: GIC.h:181
void find_simplices()
Computes the simplices of the simplicial complex.
Definition: GIC.h:1318
void plot_OFF()
Creates a .off file called SC.off for 3D visualization, which contains the 2-skeleton of the GIC....
Definition: GIC.h:1096
void set_color_from_coordinate(int k=0)
Computes the function used to color the nodes of the simplicial complex from the k-th coordinate.
Definition: GIC.h:980
void set_graph_from_OFF()
Creates a graph G from the triangulation given by the input .OFF file.
Definition: GIC.h:337
bool read_point_cloud(const std::string &off_file_name)
Reads and stores the input point cloud from .(n)OFF file.
Definition: GIC.h:237
void set_verbose(bool verb=false)
Specifies whether the program should display information or not.
Definition: GIC.h:189
