12#ifndef TANGENTIAL_COMPLEX_H_
   13#define TANGENTIAL_COMPLEX_H_
   15#include <gudhi/Tangential_complex/config.h>
   16#include <gudhi/Tangential_complex/Simplicial_complex.h>
   17#include <gudhi/Tangential_complex/utilities.h>
   18#include <gudhi/Kd_tree_search.h>
   19#include <gudhi/console_color.h>
   20#include <gudhi/Clock.h>
   21#include <gudhi/Simplex_tree.h>
   22#include <gudhi/Debug_utils.h>
   24#include <CGAL/Default.h>
   25#include <CGAL/Dimension.h>
   26#include <CGAL/function_objects.h>
   27#include <CGAL/Epick_d.h>
   28#include <CGAL/Regular_triangulation_traits_adapter.h>
   29#include <CGAL/Regular_triangulation.h>
   30#include <CGAL/Delaunay_triangulation.h>
   31#include <CGAL/Combination_enumerator.h>
   32#include <CGAL/point_generators_d.h>
   33#include <CGAL/version.h>
   37#include <Eigen/src/Core/util/Macros.h>
   39#include <boost/iterator/transform_iterator.hpp>
   40#include <boost/range/adaptor/transformed.hpp>
   41#include <boost/range/counting_range.hpp>
   42#include <boost/math/special_functions/factorials.hpp>
   43#include <boost/container/flat_set.hpp>
   62#include <tbb/parallel_for.h>
   63#include <tbb/combinable.h>
   70#if CGAL_VERSION_NR < 1041101000
   71# error Tangential_complex is only available for CGAL >= 4.11
   74#if !EIGEN_VERSION_AT_LEAST(3,1,0)
   75# error Tangential_complex is only available for Eigen3 >= 3.1.0 installed with CGAL
   78namespace sps = Gudhi::spatial_searching;
   82namespace tangential_complex {
   84using namespace internal;
   88  Vertex_data(std::size_t data = (std::numeric_limits<std::size_t>::max)()) : m_data(data) {}
   90  operator std::size_t() {
return m_data; }
   92  operator std::size_t()
 const {
return m_data; }
  123template <
typename Kernel_,
  124          typename DimensionTag,
  125          typename Concurrency_tag = CGAL::Parallel_tag,
typename Triangulation_ = CGAL::Default>
  128  typedef typename K::FT FT;
  129  typedef typename K::Point_d Point;
  130  typedef typename K::Weighted_point_d Weighted_point;
  131  typedef typename K::Vector_d Vector;
  133  typedef typename CGAL::Default::Get<
  135      CGAL::Regular_triangulation<
  136          CGAL::Epick_d<DimensionTag>,
  137          CGAL::Triangulation_data_structure<
  138              typename CGAL::Epick_d<DimensionTag>::Dimension,
  139              CGAL::Triangulation_vertex<CGAL::Regular_triangulation_traits_adapter<CGAL::Epick_d<DimensionTag> >,
  141              CGAL::Triangulation_full_cell<
  142                  CGAL::Regular_triangulation_traits_adapter<CGAL::Epick_d<DimensionTag> > > > > >::type Triangulation;
  143  typedef typename Triangulation::Geom_traits Tr_traits;
  144  typedef typename Triangulation::Weighted_point Tr_point;
  145  typedef typename Tr_traits::Base::Point_d Tr_bare_point;
  146  typedef typename Triangulation::Vertex_handle Tr_vertex_handle;
  147  typedef typename Triangulation::Full_cell_handle Tr_full_cell_handle;
  148  typedef typename Tr_traits::Vector_d Tr_vector;
  150#if defined(GUDHI_USE_TBB)
  151  typedef std::mutex Mutex_for_perturb;
  152  typedef Vector Translation_for_perturb;
  153  typedef std::vector<Atomic_wrapper<FT> > Weights;
  155  typedef Vector Translation_for_perturb;
  156  typedef std::vector<FT> Weights;
  158  typedef std::vector<Translation_for_perturb> Translations_for_perturb;
  164    Tr_and_VH() : m_tr(NULL) {}
  166    Tr_and_VH(
int dim) : m_tr(
new Triangulation(dim)) {}
  168    ~Tr_and_VH() { destroy_triangulation(); }
  170    Triangulation &construct_triangulation(
int dim) {
  172      m_tr =
new Triangulation(dim);
  176    void destroy_triangulation() {
  181    Triangulation &tr() {
return *m_tr; }
  183    Triangulation
const &tr()
 const {
return *m_tr; }
  185    Tr_vertex_handle
const ¢er_vertex()
 const {
return m_center_vertex; }
  187    Tr_vertex_handle ¢er_vertex() {
  191    Tr_vertex_handle m_center_vertex;
  195  typedef Basis<K> Tangent_space_basis;
  196  typedef Basis<K> Orthogonal_space_basis;
  197  typedef std::vector<Tangent_space_basis> TS_container;
  198  typedef std::vector<Orthogonal_space_basis> OS_container;
  200  typedef std::vector<Point> Points;
  202  typedef boost::container::flat_set<std::size_t> Simplex;
  203  typedef std::set<Simplex> Simplex_set;
  210  typedef std::vector<Tr_and_VH> Tr_container;
  211  typedef std::vector<Vector> Vectors;
  215  typedef boost::container::flat_set<std::size_t> Incident_simplex;
  216  typedef std::vector<Incident_simplex> Star;
  217  typedef std::vector<Star> Stars_container;
  221  static const Tr_point &vertex_handle_to_point(Tr_vertex_handle vh) {
return vh->point(); }
  223  template <
typename P,
typename VH>
  224  static const P &vertex_handle_to_point(VH vh) {
  229  typedef internal::Simplicial_complex Simplicial_complex;
  240  template <
typename Po
int_range>
  242#ifdef GUDHI_TC_USE_ANOTHER_POINT_SET_FOR_TANGENT_SPACE_ESTIM
  243                     InputIterator first_for_tse, InputIterator last_for_tse,
  248        m_ambient_dim(points.empty() ? 0 : k.point_dimension_d_object()(*points.begin())),
  249        m_points(points.begin(), points.end()),
  250        m_weights(m_points.size(), FT(0))
  251#if defined(GUDHI_USE_TBB) && defined(GUDHI_TC_PERTURB_POSITION)
  253        m_p_perturb_mutexes(NULL)
  256        m_points_ds(m_points),
  257        m_last_max_perturb(0.),
  258        m_are_tangent_spaces_computed(m_points.size(), false),
  259        m_tangent_spaces(m_points.size(), Tangent_space_basis())
  260#ifdef GUDHI_TC_EXPORT_NORMALS
  262        m_orth_spaces(m_points.size(), Orthogonal_space_basis())
  264#ifdef GUDHI_TC_USE_ANOTHER_POINT_SET_FOR_TANGENT_SPACE_ESTIM
  266        m_points_for_tse(first_for_tse, last_for_tse),
  267        m_points_ds_for_tse(m_points_for_tse)
  274#if defined(GUDHI_USE_TBB) && defined(GUDHI_TC_PERTURB_POSITION)
  275    delete[] m_p_perturb_mutexes;
  285  Points
const &points()
 const {
return m_points; }
  292  Point
get_point(std::size_t vertex)
 const {
return m_points[vertex]; }
  305  void set_weights(
const Weights &weights) { m_weights = weights; }
  307  void set_tangent_planes(
const TS_container &tangent_spaces
  308#ifdef GUDHI_TC_EXPORT_NORMALS
  310                          const OS_container &orthogonal_spaces
  313#ifdef GUDHI_TC_EXPORT_NORMALS
  314    GUDHI_CHECK(m_points.size() == tangent_spaces.size() && m_points.size() == orthogonal_spaces.size(),
  315                std::logic_error(
"Wrong sizes"));
  317    GUDHI_CHECK(m_points.size() == tangent_spaces.size(), std::logic_error(
"Wrong sizes"));
  319    m_tangent_spaces = tangent_spaces;
  320#ifdef GUDHI_TC_EXPORT_NORMALS
  321    m_orth_spaces = orthogonal_spaces;
  323    for (std::size_t i = 0; i < m_points.size(); ++i) m_are_tangent_spaces_computed[i] =
true;
  332#ifdef GUDHI_TC_PERFORM_EXTRA_CHECKS
  333    std::cerr << red <<
"WARNING: GUDHI_TC_PERFORM_EXTRA_CHECKS is defined. "
  334              <<
"Computation might be slower than usual.\n"
  338#if defined(GUDHI_TC_PROFILING) && defined(GUDHI_USE_TBB)
  345    m_triangulations.resize(m_points.size());
  346    m_stars.resize(m_points.size());
  347    m_squared_star_spheres_radii_incl_margin.resize(m_points.size(), FT(-1));
  348#ifdef GUDHI_TC_PERTURB_POSITION
  349    if (m_points.empty()) {
  350      m_translations.clear();
  352      m_translations.resize(m_points.size(), m_k.construct_vector_d_object()(m_ambient_dim));
  354#if defined(GUDHI_USE_TBB)
  355    delete[] m_p_perturb_mutexes;
  356    m_p_perturb_mutexes =
new Mutex_for_perturb[m_points.size()];
  362    if (boost::is_convertible<Concurrency_tag, CGAL::Parallel_tag>::value) {
  363      tbb::parallel_for(tbb::blocked_range<size_t>(0, m_points.size()), Compute_tangent_triangulation(*
this));
  367      for (std::size_t i = 0; i < m_points.size(); ++i) compute_tangent_triangulation(i);
  372#if defined(GUDHI_TC_PROFILING) && defined(GUDHI_USE_TBB)
  374    std::cerr <<
"Tangential complex computed in " << t.num_seconds() <<
" seconds.\n";
  400    if (time_limit == 0.)
return info;
  404#ifdef GUDHI_TC_SHOW_DETAILED_STATS_FOR_INCONSISTENCIES
  407    if (std::get<1>(stats_before) == 0) {
  409      std::cerr <<
"Nothing to fix.\n";
  416    m_last_max_perturb = max_perturb;
  422#ifdef GUDHI_TC_SHOW_DETAILED_STATS_FOR_INCONSISTENCIES
  423      std::cerr <<
"\nBefore fix step:\n"
  424                <<
"  * Total number of simplices in stars (incl. duplicates): " << std::get<0>(stats_before) <<
"\n"
  425                <<
"  * Num inconsistent simplices in stars (incl. duplicates): " << red << std::get<1>(stats_before)
  426                << white <<
" (" << 100. * std::get<1>(stats_before) / std::get<0>(stats_before) <<
"%)\n"
  427                <<
"  * Number of stars containing inconsistent simplices: " << red << std::get<2>(stats_before)
  428                << white <<
" (" << 100. * std::get<2>(stats_before) / m_points.size() <<
"%)\n";
  431#if defined(DEBUG_TRACES) || defined(GUDHI_TC_PROFILING)
  432      std::cerr << yellow <<
"\nAttempt to fix inconsistencies using perturbations - step #" << info.
num_steps + 1
  436      std::size_t num_inconsistent_stars = 0;
  437      std::vector<std::size_t> updated_points;
  439#ifdef GUDHI_TC_PROFILING
  440      Gudhi::Clock t_fix_step;
  444#if defined(GUDHI_USE_TBB)
  445      if (boost::is_convertible<Concurrency_tag, CGAL::Parallel_tag>::value) {
  446        tbb::combinable<std::size_t> num_inconsistencies;
  447        tbb::combinable<std::vector<std::size_t> > tls_updated_points;
  448        tbb::parallel_for(tbb::blocked_range<size_t>(0, m_triangulations.size()),
  449                          Try_to_solve_inconsistencies_in_a_local_triangulation(*
this, max_perturb, num_inconsistencies,
  450        tls_updated_points));
  451        num_inconsistent_stars = num_inconsistencies.combine(std::plus<std::size_t>());
  453            tls_updated_points.combine([](std::vector<std::size_t>
const &x, std::vector<std::size_t>
const &y) {
  454              std::vector<std::size_t> res;
  455              res.reserve(x.size() + y.size());
  456              res.insert(res.end(), x.begin(), x.end());
  457              res.insert(res.end(), y.begin(), y.end());
  463        for (std::size_t i = 0; i < m_triangulations.size(); ++i) {
  464          num_inconsistent_stars +=
  465              try_to_solve_inconsistencies_in_a_local_triangulation(i, max_perturb, std::back_inserter(updated_points));
  467#if defined(GUDHI_USE_TBB)
  471#ifdef GUDHI_TC_PROFILING
  475#if defined(GUDHI_TC_SHOW_DETAILED_STATS_FOR_INCONSISTENCIES) || defined(DEBUG_TRACES)
  476      std::cerr <<
"\nEncountered during fix:\n"
  477                <<
"  * Num stars containing inconsistent simplices: " << red << num_inconsistent_stars << white <<
  478                << 100. * num_inconsistent_stars / m_points.size() <<
"%)\n";
  481#ifdef GUDHI_TC_PROFILING
  482      std::cerr << yellow <<
"done in " << t_fix_step.num_seconds() <<
" seconds.\n" << white;
  483#elif defined(DEBUG_TRACES)
  484      std::cerr << yellow <<
"done.\n" << white;
  487      if (num_inconsistent_stars > 0) refresh_tangential_complex(updated_points);
  489#ifdef GUDHI_TC_PERFORM_EXTRA_CHECKS
  492      refresh_tangential_complex();
  494      if (num_inc_1 != num_inc_2)
  495        std::cerr << red <<
"REFRESHMENT CHECK: FAILED. (" << num_inc_1 <<
" vs " << num_inc_2 <<
")\n" << white;
  497        std::cerr << green <<
"REFRESHMENT CHECK: PASSED.\n" << white;
  500#ifdef GUDHI_TC_SHOW_DETAILED_STATS_FOR_INCONSISTENCIES
  503      std::cerr <<
"\nAfter fix:\n"
  504                <<
"  * Total number of simplices in stars (incl. duplicates): " << std::get<0>(stats_after) <<
"\n"
  505                <<
"  * Num inconsistent simplices in stars (incl. duplicates): " << red << std::get<1>(stats_after)
  506                << white <<
" (" << 100. * std::get<1>(stats_after) / std::get<0>(stats_after) <<
"%)\n"
  507                <<
"  * Number of stars containing inconsistent simplices: " << red << std::get<2>(stats_after) << white
  508                <<
" (" << 100. * std::get<2>(stats_after) / m_points.size() <<
"%)\n";
  510      stats_before = stats_after;
  520      done = (num_inconsistent_stars == 0);
  523        if (time_limit > 0. && t.num_seconds() > time_limit) {
  525          std::cerr << red <<
"Time limit reached.\n" << white;
  534    std::cerr << green <<
"Fixed!\n" << white;
  563    for (std::size_t idx = 0; idx < m_points.size(); ++idx) {
  564      bool is_star_inconsistent =
false;
  567      Star::const_iterator it_inc_simplex = m_stars[idx].begin();
  568      Star::const_iterator it_inc_simplex_end = m_stars[idx].end();
  569      for (; it_inc_simplex != it_inc_simplex_end; ++it_inc_simplex) {
  571        if (is_infinite(*it_inc_simplex))
continue;
  573        Simplex c = *it_inc_simplex;
  576        if (!is_simplex_consistent(c)) {
  578          is_star_inconsistent =
true;
  587      std::cerr <<
"\n==========================================================\n"
  588                <<
"Inconsistencies:\n"
  589                <<
"  * Total number of simplices in stars (incl. duplicates): " << stats.
num_simplices <<
"\n"
  590                <<
"  * Number of inconsistent simplices in stars (incl. duplicates): "
  595                <<
"==========================================================\n";
  611  template <
typename Simplex_tree_>
  613                     bool export_inconsistent_simplices =
true
  616                     bool export_infinite_simplices =
false, Simplex_set *p_inconsistent_simplices = NULL
  619#if defined(DEBUG_TRACES) || defined(GUDHI_TC_PROFILING)
  620    std::cerr << yellow <<
"\nExporting the TC as a Simplex_tree... " << white;
  622#ifdef GUDHI_TC_PROFILING
  629    std::vector<typename Simplex_tree_::Vertex_handle> vertices(m_points.size());
  630    std::iota(vertices.begin(), vertices.end(), 0);
  631    tree.insert_batch_vertices(vertices);
  634    for (std::size_t idx = 0; idx < m_points.size(); ++idx) {
  636      Star::const_iterator it_inc_simplex = m_stars[idx].begin();
  637      Star::const_iterator it_inc_simplex_end = m_stars[idx].end();
  638      for (; it_inc_simplex != it_inc_simplex_end; ++it_inc_simplex) {
  639        Simplex c = *it_inc_simplex;
  642        if (!export_infinite_simplices && is_infinite(c))
continue;
  644        if (
static_cast<int>(c.size()) > max_dim) max_dim =
static_cast<int>(c.size());
  648        if (!export_inconsistent_simplices && !is_simplex_consistent(c))
continue;
  651        bool inserted = tree.insert_simplex_and_subfaces(c).second;
  654        if (p_inconsistent_simplices && inserted && !is_simplex_consistent(c)) {
  655          p_inconsistent_simplices->insert(c);
  660#ifdef GUDHI_TC_PROFILING
  662    std::cerr << yellow <<
"done in " << t.num_seconds() <<
  663#elif defined(DEBUG_TRACES)
  664    std::cerr << yellow <<
"done.\n" << white;
  680  int create_complex(Simplicial_complex &complex,
true,
  681                     bool export_infinite_simplices =
false,
int check_lower_and_higher_dim_simplices = 2,
  682                     Simplex_set *p_inconsistent_simplices = NULL)
 const {
  683#if defined(DEBUG_TRACES) || defined(GUDHI_TC_PROFILING)
  684    std::cerr << yellow <<
"\nExporting the TC as a Simplicial_complex... " << white;
  686#ifdef GUDHI_TC_PROFILING
  694    for (std::size_t idx = 0; idx < m_points.size(); ++idx) {
  696      Star::const_iterator it_inc_simplex = m_stars[idx].begin();
  697      Star::const_iterator it_inc_simplex_end = m_stars[idx].end();
  698      for (; it_inc_simplex != it_inc_simplex_end; ++it_inc_simplex) {
  699        Simplex c = *it_inc_simplex;
  702        if (!export_infinite_simplices && is_infinite(c))
continue;
  704        if (
  708        if (!export_inconsistent_simplices && !is_simplex_consistent(c))
continue;
  711        if (check_lower_and_higher_dim_simplices == 2 && max_dim != -1 &&
static_cast<int>(c.size()) != max_dim) {
  714                    <<
"Info: check_lower_and_higher_dim_simplices ACTIVATED. "
  715                       "Export might be take some time...\n"
  717          check_lower_and_higher_dim_simplices = 1;
  721        bool added = complex.add_simplex(c, check_lower_and_higher_dim_simplices == 1);
  724        if (p_inconsistent_simplices && added && !is_simplex_consistent(c)) {
  725          p_inconsistent_simplices->insert(c);
  730#ifdef GUDHI_TC_PROFILING
  732    std::cerr << yellow <<
  733#elif defined(DEBUG_TRACES)
  734    std::cerr << yellow <<
"done.\n" << white;
  740  template <
typename ProjectionFunctor = CGAL::Identity<Po
int> >
  741  std::ostream &export_to_off(
const Simplicial_complex &complex, std::ostream &os,
  742                              Simplex_set
const *p_simpl_to_color_in_red = NULL,
  743                              Simplex_set
const *p_simpl_to_color_in_green = NULL,
  744                              Simplex_set
const *p_simpl_to_color_in_blue = NULL,
  745                              ProjectionFunctor
const &point_projection = ProjectionFunctor())
 const {
  746    return export_to_off(os,
false, p_simpl_to_color_in_red, p_simpl_to_color_in_green, p_simpl_to_color_in_blue,
  747                         &complex, point_projection);
  750  template <
int> >
  751  std::ostream &export_to_off(std::ostream &os,
bool color_inconsistencies =
false,
  752                              Simplex_set
  753                              Simplex_set
  754                              Simplex_set
  755                              const Simplicial_complex *p_complex = NULL,
  756                              ProjectionFunctor
 const {
  757    if (m_points.empty())
return os;
  759    if (m_ambient_dim < 2) {
  760      std::cerr <<
"Error: export_to_off => ambient dimension should be >= 2.\n";
  761      os <<
  764    if (m_ambient_dim > 3) {
  765      std::cerr <<
"Warning: export_to_off => ambient dimension should be "
  766                   "<= 3. Only the first 3 coordinates will be exported.\n";
  769    if (m_intrinsic_dim < 1 || m_intrinsic_dim > 3) {
  770      std::cerr <<
"Error: export_to_off => intrinsic dimension should be "
  771                   "between 1 and 3.\n";
  772      os <<
  773            "between 1 and 3.\n";
  777    std::stringstream output;
  778    std::size_t num_simplices, num_vertices;
  779    export_vertices_to_off(output, num_vertices,
false, point_projection);
  781      export_simplices_to_off(*p_complex, output, num_simplices, p_simpl_to_color_in_red, p_simpl_to_color_in_green,
  782                              p_simpl_to_color_in_blue);
  784      export_simplices_to_off(output, num_simplices, color_inconsistencies, p_simpl_to_color_in_red,
  785                              p_simpl_to_color_in_green, p_simpl_to_color_in_blue);
  788#ifdef GUDHI_TC_EXPORT_NORMALS
  793       << num_vertices <<
" " << num_simplices <<
  801  void refresh_tangential_complex() {
  802#if defined(DEBUG_TRACES) || defined(GUDHI_TC_PROFILING)
  803    std::cerr << yellow <<
"\nRefreshing TC... " << white;
  806#ifdef GUDHI_TC_PROFILING
  811    if (boost::is_convertible<Concurrency_tag, CGAL::Parallel_tag>::value) {
  812      tbb::parallel_for(tbb::blocked_range<size_t>(0, m_points.size()), Compute_tangent_triangulation(*
this));
  816      for (std::size_t i = 0; i < m_points.size(); ++i) compute_tangent_triangulation(i);
  821#ifdef GUDHI_TC_PROFILING
  823    std::cerr << yellow <<
  824#elif defined(DEBUG_TRACES)
  825    std::cerr << yellow <<
"done.\n" << white;
  830  template <
typename Po
int_indices_range>
  831  void refresh_tangential_complex(Point_indices_range
const &perturbed_points_indices) {
  832#if defined(DEBUG_TRACES) || defined(GUDHI_TC_PROFILING)
  833    std::cerr << yellow <<
  836#ifdef GUDHI_TC_PROFILING
  841    Points_ds updated_pts_ds(m_points, perturbed_points_indices);
  845    if (boost::is_convertible<Concurrency_tag, CGAL::Parallel_tag>::value) {
  846      tbb::parallel_for(tbb::blocked_range<size_t>(0, m_points.size()),
  847                        Refresh_tangent_triangulation(*
this, updated_pts_ds));
  851      for (std::size_t i = 0; i < m_points.size(); ++i) refresh_tangent_triangulation(i, updated_pts_ds);
  856#ifdef GUDHI_TC_PROFILING
  858    std::cerr << yellow <<
  859#elif defined(DEBUG_TRACES)
  860    std::cerr << yellow <<
"done.\n" << white;
  864  void export_inconsistent_stars_to_OFF_files(std::string
const &filename_base)
 const {
  866    for (std::size_t idx = 0; idx < m_points.size(); ++idx) {
  868      Simplicial_complex sc;
  870      bool is_inconsistent =
false;
  871      Star::const_iterator it_inc_simplex = m_stars[idx].begin();
  872      Star::const_iterator it_inc_simplex_end = m_stars[idx].end();
  873      for (; it_inc_simplex != it_inc_simplex_end; ++it_inc_simplex) {
  875        if (is_infinite(*it_inc_simplex))
continue;
  877        Simplex c = *it_inc_simplex;
  883        if (!is_inconsistent && !is_simplex_consistent(c)) is_inconsistent =
true;
  886      if (is_inconsistent) {
  888        std::stringstream output_filename;
  889        output_filename << filename_base <<
"_" << idx <<
".off";
  890        std::ofstream off_stream(output_filename.str().c_str());
  891        export_to_off(sc, off_stream);
  896  class Compare_distance_to_ref_point {
  898    Compare_distance_to_ref_point(Point
const &ref, K
const &k) : m_ref(ref), m_k(k) {}
  900    bool operator()(Point
const &p1, Point
const &p2) {
  901      typename K::Squared_distance_d sqdist = m_k.squared_distance_d_object();
  902      return sqdist(p1, m_ref) < sqdist(p2, m_ref);
  912  class Compute_tangent_triangulation {
  913    Tangential_complex &m_tc;
  917    Compute_tangent_triangulation(Tangential_complex &tc) : m_tc(tc) {}
  920    Compute_tangent_triangulation(
const Compute_tangent_triangulation &ctt) : m_tc(ctt.m_tc) {}
  923    void operator()(
const tbb::blocked_range<size_t> &r)
 const {
  924      for (
size_t i = r.begin(); i != r.end(); ++i) m_tc.compute_tangent_triangulation(i);
  929  class Refresh_tangent_triangulation {
  930    Tangential_complex &m_tc;
  931    Points_ds
const &m_updated_pts_ds;
  935    Refresh_tangent_triangulation(Tangential_complex &tc, Points_ds
const &updated_pts_ds)
  936        : m_tc(tc), m_updated_pts_ds(updated_pts_ds) {}
  939    Refresh_tangent_triangulation(
const Refresh_tangent_triangulation &ctt)
  940        : m_tc(ctt.m_tc), m_updated_pts_ds(ctt.m_updated_pts_ds) {}
  943    void operator()(
 const {
  944      for (
size_t i = r.begin(); i != r.end(); ++i) m_tc.refresh_tangent_triangulation(i, m_updated_pts_ds);
  949  bool is_infinite(Simplex
const &s)
 const {
return *s.rbegin() == (std::numeric_limits<std::size_t>::max)(); }
  954  Tr_vertex_handle compute_star(std::size_t i,
const Point ¢er_pt,
const Tangent_space_basis &tsb,
  955                                Triangulation &triangulation,
bool verbose =
false) {
  956    int tangent_space_dim = tsb.dimension();
  957    const Tr_traits &local_tr_traits = triangulation.geom_traits();
  960    typename K::Squared_distance_d k_sqdist = m_k.squared_distance_d_object();
  963    typename Tr_traits::Compute_weight_d point_weight = local_tr_traits.compute_weight_d_object();
  964#if CGAL_VERSION_NR < 1050200000
  965    typename Tr_traits::Power_center_d power_center = local_tr_traits.power_center_d_object();
  967    typename Tr_traits::Construct_power_sphere_d power_center = local_tr_traits.construct_power_sphere_d_object();
  977    if (i == tsb.origin()) {
  979      proj_wp = local_tr_traits.construct_weighted_point_d_object()(
  980          local_tr_traits.construct_point_d_object()(tangent_space_dim, CGAL::ORIGIN), m_weights[i]);
  982      const Weighted_point &wp = compute_perturbed_weighted_point(i);
  983      proj_wp = project_point_and_compute_weight(wp, tsb, local_tr_traits);
  986    Tr_vertex_handle center_vertex = triangulation.insert(proj_wp);
  987    center_vertex->data() = i;
  988    if (verbose) std::cerr <<
"* Inserted point #" << i <<
"\n";
  990#ifdef GUDHI_TC_VERY_VERBOSE
  991    std::size_t num_attempts_to_insert_points = 1;
  992    std::size_t num_inserted_points = 1;
 1004    std::optional<FT> squared_star_sphere_radius_plus_margin = m_max_squared_edge_length;
 1007    for (
auto nn_it = ins_range.begin(); nn_it != ins_range.end(); ++nn_it) {
 1008      std::size_t neighbor_point_idx = nn_it->first;
 1011      if (neighbor_point_idx != i) {
 1016        compute_perturbed_weighted_point(neighbor_point_idx, neighbor_pt, neighbor_weight);
 1017        GUDHI_CHECK(!m_max_squared_edge_length ||
 1018                    squared_star_sphere_radius_plus_margin.value() <= m_max_squared_edge_length.value(),
 1019                    std::invalid_argument(
"Tangential_complex::compute_star - set a bigger value with set_max_squared_edge_length."));
 1020        if (squared_star_sphere_radius_plus_margin &&
 1021            k_sqdist(center_pt, neighbor_pt) > squared_star_sphere_radius_plus_margin.value()) {
 1022          GUDHI_CHECK(triangulation.current_dimension() >= tangent_space_dim,
 1023                      std::invalid_argument(
"Tangential_complex::compute_star - Dimension of the star is only " + \
 1024                                            std::to_string(triangulation.current_dimension())));
 1028        Tr_point proj_pt = project_point_and_compute_weight(neighbor_pt, neighbor_weight, tsb, local_tr_traits);
 1030#ifdef GUDHI_TC_VERY_VERBOSE
 1031        ++num_attempts_to_insert_points;
 1034        Tr_vertex_handle vh = triangulation.insert_if_in_star(proj_pt, center_vertex);
 1036        if (vh != Tr_vertex_handle() && vh->data() == (std::numeric_limits<std::size_t>::max)()) {
 1037#ifdef GUDHI_TC_VERY_VERBOSE
 1038          ++num_inserted_points;
 1040          if (verbose) std::cerr <<
"* Inserted point #" << neighbor_point_idx <<
"\n";
 1042          vh->data() = neighbor_point_idx;
 1045          if (triangulation.current_dimension() >= tangent_space_dim) {
 1046            squared_star_sphere_radius_plus_margin = std::nullopt;
 1048            std::vector<Tr_full_cell_handle> incident_cells;
 1049            triangulation.incident_full_cells(center_vertex, std::back_inserter(incident_cells));
 1050            for (
typename std::vector<Tr_full_cell_handle>::iterator cit = incident_cells.begin();
 1051                 cit != incident_cells.end(); ++cit) {
 1052              Tr_full_cell_handle cell = *cit;
 1053              if (triangulation.is_infinite(cell)) {
 1054                squared_star_sphere_radius_plus_margin = std::nullopt;
 1060                    power_center(boost::make_transform_iterator(cell->vertices_begin(),
 1061        vertex_handle_to_point<Tr_point, Tr_vertex_handle>),
 1062                                 boost::make_transform_iterator(cell->vertices_end(),
 1063        vertex_handle_to_point<Tr_point, Tr_vertex_handle>));
 1065                FT sq_power_sphere_diam = 4 * point_weight(c);
 1067                if (!squared_star_sphere_radius_plus_margin ||
 1068                    sq_power_sphere_diam > squared_star_sphere_radius_plus_margin.value()) {
 1069                  squared_star_sphere_radius_plus_margin = sq_power_sphere_diam;
 1076            if (squared_star_sphere_radius_plus_margin) {
 1078              squared_star_sphere_radius_plus_margin =
 1079                  CGAL::square(std::sqrt(squared_star_sphere_radius_plus_margin.value()) + 2 * m_last_max_perturb);
 1082              if (m_max_squared_edge_length && squared_star_sphere_radius_plus_margin.value() > m_max_squared_edge_length.value()) {
 1083                squared_star_sphere_radius_plus_margin = m_max_squared_edge_length.value();
 1087              m_squared_star_spheres_radii_incl_margin[i] = squared_star_sphere_radius_plus_margin.value();
 1089              if (m_max_squared_edge_length) {
 1090                squared_star_sphere_radius_plus_margin = m_max_squared_edge_length.value();
 1091                m_squared_star_spheres_radii_incl_margin[i] = m_max_squared_edge_length.value();
 1093                m_squared_star_spheres_radii_incl_margin[i] = FT(-1);
 1101    return center_vertex;
 1104  void refresh_tangent_triangulation(std::size_t i, Points_ds
const &updated_pts_ds,
bool verbose =
false) {
 1105    if (verbose) std::cerr <<
"** Refreshing tangent tri #" << i <<
" **\n";
 1107    if (m_squared_star_spheres_radii_incl_margin[i] == FT(-1))
return compute_tangent_triangulation(i, verbose);
 1109    Point center_point = compute_perturbed_point(i);
 1111    std::size_t closest_pt_index = updated_pts_ds.k_nearest_neighbors(center_point, 1,
false).begin()->first;
 1113    typename K::Construct_weighted_point_d k_constr_wp = m_k.construct_weighted_point_d_object();
 1114#if CGAL_VERSION_NR < 1050200000
 1115    typename K::Power_distance_d k_power_dist = m_k.power_distance_d_object();
 1117    typename K::Compute_power_product_d k_power_dist = m_k.compute_power_product_d_object();
 1121    Weighted_point star_sphere = k_constr_wp(compute_perturbed_point(i), m_squared_star_spheres_radii_incl_margin[i]);
 1122    Weighted_point closest_updated_point = compute_perturbed_weighted_point(closest_pt_index);
 1125    if (k_power_dist(star_sphere, closest_updated_point) <= FT(0)) compute_tangent_triangulation(i, verbose);
 1128  void compute_tangent_triangulation(std::size_t i,
bool verbose =
false) {
 1129    if (verbose) std::cerr <<
"** Computing tangent tri #" << i <<
" **\n";
 1134    const Point center_pt = compute_perturbed_point(i);
 1135    Tangent_space_basis &tsb = m_tangent_spaces[i];
 1138    if (!m_are_tangent_spaces_computed[i]) {
 1139#ifdef GUDHI_TC_EXPORT_NORMALS
 1140      tsb = compute_tangent_space(center_pt, i,
true , &m_orth_spaces[i]);
 1142      tsb = compute_tangent_space(center_pt, i);
 1146#if defined(GUDHI_TC_PROFILING) && defined(GUDHI_TC_VERY_VERBOSE)
 1149    int tangent_space_dim = tangent_basis_dim(i);
 1150    Triangulation &local_tr = m_triangulations[i].construct_triangulation(tangent_space_dim);
 1152    m_triangulations[i].center_vertex() = compute_star(i, center_pt, tsb, local_tr, verbose);
 1154#if defined(GUDHI_TC_PROFILING) && defined(GUDHI_TC_VERY_VERBOSE)
 1156    std::cerr <<
"  - triangulation construction: " << t.num_seconds() <<
" s.\n";
 1160#ifdef GUDHI_TC_VERY_VERBOSE
 1161    std::cerr <<
"Inserted " << num_inserted_points <<
" points / " << num_attempts_to_insert_points
 1162              <<
" attempts to compute the star\n";
 1167#if defined(GUDHI_TC_PROFILING) && defined(GUDHI_TC_VERY_VERBOSE)
 1169    std::cerr <<
"  - update_star: " << t.num_seconds() <<
" s.\n";
 1175  void update_star(std::size_t i) {
 1176    Star &star = m_stars[i];
 1178    Triangulation &local_tr = m_triangulations[i].tr();
 1179    Tr_vertex_handle center_vertex = m_triangulations[i].center_vertex();
 1180    int cur_dim_plus_1 = local_tr.current_dimension() + 1;
 1182    std::vector<Tr_full_cell_handle> incident_cells;
 1183    local_tr.incident_full_cells(center_vertex, std::back_inserter(incident_cells));
 1185    typename std::vector<Tr_full_cell_handle>::const_iterator it_c = incident_cells.begin();
 1186    typename std::vector<Tr_full_cell_handle>::const_iterator it_c_end = incident_cells.end();
 1188    for (; it_c != it_c_end; ++it_c) {
 1190      Incident_simplex incident_simplex;
 1191      for (
int j = 0; j < cur_dim_plus_1; ++j) {
 1192        std::size_t index = (*it_c)->vertex(j)->data();
 1193        if (index != i) incident_simplex.insert(index);
 1195      GUDHI_CHECK(incident_simplex.size() == cur_dim_plus_1 - 1,
 1196                  std::logic_error(
"update_star: wrong size of incident simplex"));
 1197      star.push_back(incident_simplex);
 1203  Tangent_space_basis compute_tangent_space(
const Point &p,
const std::size_t i,
bool normalize_basis =
true,
 1204                                            Orthogonal_space_basis *p_orth_space_basis = NULL) {
 1205    unsigned int num_pts_for_pca =
 1206        (std::min)(
static_cast<unsigned int>(std::pow(GUDHI_TC_BASE_VALUE_FOR_PCA, m_intrinsic_dim)),
 1207                   static_cast<unsigned int>(m_points.size()));
 1210    typename K::Construct_vector_d constr_vec = m_k.construct_vector_d_object();
 1211    typename K::Compute_coordinate_d coord = m_k.compute_coordinate_d_object();
 1213#ifdef GUDHI_TC_USE_ANOTHER_POINT_SET_FOR_TANGENT_SPACE_ESTIM
 1214    KNS_range kns_range = m_points_ds_for_tse.k_nearest_neighbors(p, num_pts_for_pca,
false);
 1215    const Points &points_for_pca = m_points_for_tse;
 1218    const Points &points_for_pca = m_points;
 1222    Eigen::MatrixXd mat_points(num_pts_for_pca, m_ambient_dim);
 1223    auto nn_it = kns_range.begin();
 1224    for (
unsigned int j = 0; j < num_pts_for_pca && nn_it != kns_range.end(); ++j, ++nn_it) {
 1225      for (
int i = 0; i < m_ambient_dim; ++i) {
 1226        mat_points(j, i) = CGAL::to_double(coord(points_for_pca[nn_it->first], i));
 1229    Eigen::MatrixXd centered = mat_points.rowwise() - mat_points.colwise().mean();
 1230    Eigen::MatrixXd cov = centered.adjoint() * centered;
 1231    Eigen::SelfAdjointEigenSolver<Eigen::MatrixXd> eig(cov);
 1233    Tangent_space_basis tsb(i);
 1237    for (
int j = m_ambient_dim - 1; j >= m_ambient_dim - m_intrinsic_dim; --j) {
 1238      if (normalize_basis) {
 1239        Vector v = constr_vec(m_ambient_dim, eig.eigenvectors().col(j).data(),
 1240                              eig.eigenvectors().col(j).data() + m_ambient_dim);
 1241        tsb.push_back(normalize_vector(v, m_k));
 1243        tsb.push_back(constr_vec(m_ambient_dim, eig.eigenvectors().col(j).data(),
 1244                                 eig.eigenvectors().col(j).data() + m_ambient_dim));
 1248    if (p_orth_space_basis) {
 1249      p_orth_space_basis->set_origin(i);
 1250      for (
int j = m_ambient_dim - m_intrinsic_dim - 1; j >= 0; --j) {
 1251        if (normalize_basis) {
 1252          Vector v = constr_vec(m_ambient_dim, eig.eigenvectors().col(j).data(),
 1253                                eig.eigenvectors().col(j).data() + m_ambient_dim);
 1254          p_orth_space_basis->push_back(normalize_vector(v, m_k));
 1256          p_orth_space_basis->push_back(constr_vec(m_ambient_dim, eig.eigenvectors().col(j).data(),
 1257                                                   eig.eigenvectors().col(j).data() + m_ambient_dim));
 1262    m_are_tangent_spaces_computed[i] =
true;
 1272  Tangent_space_basis compute_tangent_space(
const Simplex &s,
true) {
 1273    unsigned int num_pts_for_pca =
 1274        (std::min)(
 1275                   static_cast<unsigned int>(m_points.size()));
 1278    typename K::Construct_vector_d constr_vec = m_k.construct_vector_d_object();
 1279    typename K::Compute_coordinate_d coord = m_k.compute_coordinate_d_object();
 1280    typename K::Squared_length_d sqlen = m_k.squared_length_d_object();
 1281    typename K::Scaled_vector_d scaled_vec = m_k.scaled_vector_d_object();
 1282    typename K::Scalar_product_d scalar_pdct = m_k.scalar_product_d_object();
 1283    typename K::Difference_of_vectors_d diff_vec = m_k.difference_of_vectors_d_object();
 1286    Eigen::MatrixXd mat_points(s.size() * num_pts_for_pca, m_ambient_dim);
 1287    unsigned int current_row = 0;
 1289    for (Simplex::const_iterator it_index = s.begin(); it_index != s.end(); ++it_index) {
 1290      const Point &p = m_points[*it_index];
 1292#ifdef GUDHI_TC_USE_ANOTHER_POINT_SET_FOR_TANGENT_SPACE_ESTIM
 1293      KNS_range kns_range = m_points_ds_for_tse.k_nearest_neighbors(p, num_pts_for_pca,
false);
 1294      const Points &points_for_pca = m_points_for_tse;
 1297      const Points &points_for_pca = m_points;
 1300      auto nn_it = kns_range.begin();
 1301      for (; current_row < num_pts_for_pca && nn_it != kns_range.end(); ++current_row, ++nn_it) {
 1302        for (
 1303          mat_points(current_row, i) = CGAL::to_double(coord(points_for_pca[nn_it->first], i));
 1307    Eigen::MatrixXd centered = mat_points.rowwise() - mat_points.colwise().mean();
 1308    Eigen::MatrixXd cov = centered.adjoint() * centered;
 1309    Eigen::SelfAdjointEigenSolver<Eigen::MatrixXd> eig(cov);
 1311    Tangent_space_basis tsb;
 1315    for (
 1316      if (normalize_basis) {
 1317        Vector v = constr_vec(m_ambient_dim, eig.eigenvectors().col(j).data(),
 1318                              eig.eigenvectors().col(j).data() + m_ambient_dim);
 1319        tsb.push_back(normalize_vector(v, m_k));
 1321        tsb.push_back(constr_vec(m_ambient_dim, eig.eigenvectors().col(j).data(),
 1322                                 eig.eigenvectors().col(j).data() + m_ambient_dim));
 1331  int tangent_basis_dim(std::size_t i)
 const {
return m_tangent_spaces[i].dimension(); }
 1333  Point compute_perturbed_point(std::size_t pt_idx)
 const {
 1334#ifdef GUDHI_TC_PERTURB_POSITION
 1335    return m_k.translated_point_d_object()(m_points[pt_idx], m_translations[pt_idx]);
 1337    return m_points[pt_idx];
 1341  void compute_perturbed_weighted_point(std::size_t pt_idx, Point &p, FT &w)
 const {
 1342#ifdef GUDHI_TC_PERTURB_POSITION
 1343    p = m_k.translated_point_d_object()(m_points[pt_idx], m_translations[pt_idx]);
 1345    p = m_points[pt_idx];
 1347    w = m_weights[pt_idx];
 1350  Weighted_point compute_perturbed_weighted_point(std::size_t pt_idx)
 const {
 1351    typename K::Construct_weighted_point_d k_constr_wp = m_k.construct_weighted_point_d_object();
 1353    Weighted_point wp = k_constr_wp(
 1354#ifdef GUDHI_TC_PERTURB_POSITION
 1355        m_k.translated_point_d_object()(m_points[pt_idx], m_translations[pt_idx]),
 1364  Point unproject_point(
const Tr_point &p,
const Tr_traits &tr_traits)
 const {
 1365    typename K::Translated_point_d k_transl = m_k.translated_point_d_object();
 1366    typename K::Scaled_vector_d k_scaled_vec = m_k.scaled_vector_d_object();
 1367    typename Tr_traits::Compute_coordinate_d coord = tr_traits.compute_coordinate_d_object();
 1369    Point global_point = compute_perturbed_point(tsb.origin());
 1370    for (
int i = 0; i < m_intrinsic_dim; ++i) global_point = k_transl(global_point, k_scaled_vec(tsb[i], coord(p, i)));
 1372    return global_point;
 1377  Tr_bare_point project_point(
const Point &p,
 const {
 1378    typename K::Scalar_product_d scalar_pdct = m_k.scalar_product_d_object();
 1379    typename K::Difference_of_points_d diff_points = m_k.difference_of_points_d_object();
 1381    Vector v = diff_points(p, compute_perturbed_point(tsb.origin()));
 1383    std::vector<FT> coords;
 1385    coords.reserve(tsb.dimension());
 1386    for (std::size_t i = 0; i < m_intrinsic_dim; ++i) {
 1388      FT coord = scalar_pdct(v, tsb[i]);
 1389      coords.push_back(coord);
 1392    return tr_traits.construct_point_d_object()(
static_cast<int>(coords.size()), coords.begin(), coords.end());
 1399  Tr_point project_point_and_compute_weight(
const Weighted_point &wp,
 1400                                            const Tr_traits &tr_traits)
 const {
 1401    typename K::Point_drop_weight_d k_drop_w = m_k.point_drop_weight_d_object();
 1402    typename K::Compute_weight_d k_point_weight = m_k.compute_weight_d_object();
 1403    return project_point_and_compute_weight(k_drop_w(wp), k_point_weight(wp), tsb, tr_traits);
 1407  Tr_point project_point_and_compute_weight(
const Point &p,
const FT w,
 1408                                            const Tr_traits &tr_traits)
 const {
 1409    const int point_dim = m_k.point_dimension_d_object()(p);
 1411    typename K::Construct_point_d constr_pt = m_k.construct_point_d_object();
 1412    typename K::Scalar_product_d scalar_pdct = m_k.scalar_product_d_object();
 1413    typename K::Difference_of_points_d diff_points = m_k.difference_of_points_d_object();
 1414    typename K::Compute_coordinate_d coord = m_k.compute_coordinate_d_object();
 1415    typename K::Construct_cartesian_const_iterator_d ccci = m_k.construct_cartesian_const_iterator_d_object();
 1417    Point origin = compute_perturbed_point(tsb.origin());
 1418    Vector v = diff_points(p, origin);
 1421    bool same_dim = (point_dim == tsb.dimension());
 1423    std::vector<FT> coords;
 1425    std::vector<FT> p_proj(ccci(origin), ccci(origin, 0));
 1426    coords.reserve(tsb.dimension());
 1427    for (
int i = 0; i < tsb.dimension(); ++i) {
 1429      FT c = scalar_pdct(v, tsb[i]);
 1430      coords.push_back(c);
 1434        for (
int j = 0; j < point_dim; ++j) p_proj[j] += c * coord(tsb[i], j);
 1439    FT sq_dist_to_proj_pt = 0;
 1441      Point projected_pt = constr_pt(point_dim, p_proj.begin(), p_proj.end());
 1442      sq_dist_to_proj_pt = m_k.squared_distance_d_object()(p, projected_pt);
 1445    return tr_traits.construct_weighted_point_d_object()(
 1446        tr_traits.construct_point_d_object()(
static_cast<int>(coords.size()), coords.begin(), coords.end()),
 1447        w - sq_dist_to_proj_pt);
 1452  template <
typename Indexed_po
int_range>
 1453  std::vector<Tr_point> project_points_and_compute_weights(
const Indexed_point_range &point_indices,
 1454                                                           const Tangent_space_basis &tsb,
 1455                                                           const Tr_traits &tr_traits)
 const {
 1456    std::vector<Tr_point> ret;
 1457    for (
typename Indexed_point_range::const_iterator it = point_indices.begin(), it_end = point_indices.end();
 1458         it != it_end; ++it) {
 1459      ret.push_back(project_point_and_compute_weight(compute_perturbed_weighted_point(*it), tsb, tr_traits));
 1466  bool is_simplex_consistent(Tr_full_cell_handle fch,
int cur_dim)
 const {
 1468    for (
int i = 0; i < cur_dim + 1; ++i) {
 1469      std::size_t data = fch->vertex(i)->data();
 1472    return is_simplex_consistent(c);
 1478  bool is_simplex_consistent(Simplex
const &simplex)
 const {
 1480    Simplex::const_iterator it_point_idx = simplex.begin();
 1483    for (; it_point_idx != simplex.end(); ++it_point_idx) {
 1484      std::size_t point_idx = *it_point_idx;
 1486      if (point_idx == (std::numeric_limits<std::size_t>::max)())
continue;
 1488      Star
const &star = m_stars[point_idx];
 1491      Incident_simplex is_to_find = simplex;
 1492      is_to_find.erase(point_idx);
 1495      if (std::find(star.begin(), star.end(), is_to_find) == star.end())
return false;
 1507  template <
typename OutputIterator>
 1508  bool is_simplex_consistent(std::size_t center_point,
 1509                             Incident_simplex
const &s,
 1510                             OutputIterator points_whose_star_does_not_contain_s,
 1511                             bool check_also_in_non_maximal_faces =
false)
 const {
 1512    Simplex full_simplex = s;
 1513    full_simplex.insert(center_point);
 1516    Incident_simplex::const_iterator it_point_idx = s.begin();
 1519    for (; it_point_idx != s.end(); ++it_point_idx) {
 1520      std::size_t point_idx = *it_point_idx;
 1522      if (point_idx == (std::numeric_limits<std::size_t>::max)())
continue;
 1524      Star
 1527      Incident_simplex is_to_find = full_simplex;
 1528      is_to_find.erase(point_idx);
 1530      if (check_also_in_non_maximal_faces) {
 1534        for (Star::const_iterator is = star.begin(), is_end = star.end(); !found && is != is_end; ++is) {
 1535          if (std::includes(is->begin(), is->end(), is_to_find.begin(), is_to_find.end())) found =
true;
 1538        if (!found) *points_whose_star_does_not_contain_s++ = point_idx;
 1541        if (std::find(star.begin(), star.end(), is_to_find) == star.end())
 1542          *points_whose_star_does_not_contain_s++ = point_idx;
 1552  bool is_simplex_in_star(std::size_t p, Incident_simplex
const &s,
true)
 const {
 1553    Star
const &star = m_stars[p];
 1555    if (check_also_in_non_maximal_faces) {
 1559      for (Star::const_iterator is = star.begin(), is_end = star.end(); !found && is != is_end; ++is) {
 1560        if (std::includes(is->begin(), is->end(), s.begin(), s.end())) found =
true;
 1565      return !(std::find(star.begin(), star.end(), s) == star.end());
 1571  class Try_to_solve_inconsistencies_in_a_local_triangulation {
 1572    Tangential_complex &m_tc;
 1573    double m_max_perturb;
 1574    tbb::combinable<std::size_t> &m_num_inconsistencies;
 1575    tbb::combinable<std::vector<std::size_t> > &m_updated_points;
 1579    Try_to_solve_inconsistencies_in_a_local_triangulation(Tangential_complex &tc,
double max_perturb,
 1580                                                          tbb::combinable<std::size_t> &num_inconsistencies,
 1581                                                          tbb::combinable<std::vector<std::size_t> > &updated_points)
 1583          m_max_perturb(max_perturb),
 1584          m_num_inconsistencies(num_inconsistencies),
 1585          m_updated_points(updated_points) {}
 1588    Try_to_solve_inconsistencies_in_a_local_triangulation(
 1589        const Try_to_solve_inconsistencies_in_a_local_triangulation &tsilt)
 1591          m_max_perturb(tsilt.m_max_perturb),
 1592          m_num_inconsistencies(tsilt.m_num_inconsistencies),
 1593          m_updated_points(tsilt.m_updated_points) {}
 1596    void operator()(
 const {
 1597      for (
size_t i = r.begin(); i != r.end(); ++i) {
 1598        m_num_inconsistencies.local() += m_tc.try_to_solve_inconsistencies_in_a_local_triangulation(
 1599            i, m_max_perturb, std::back_inserter(m_updated_points.local()));
 1605  void perturb(std::size_t point_idx,
double max_perturb) {
 1606    const Tr_traits &local_tr_traits = m_triangulations[point_idx].tr().geom_traits();
 1607    typename Tr_traits::Compute_coordinate_d coord = local_tr_traits.compute_coordinate_d_object();
 1608    typename K::Translated_point_d k_transl = m_k.translated_point_d_object();
 1609    typename K::Construct_vector_d k_constr_vec = m_k.construct_vector_d_object();
 1610    typename K::Scaled_vector_d k_scaled_vec = m_k.scaled_vector_d_object();
 1612    CGAL::Random_points_in_ball_d<Tr_bare_point> tr_point_in_ball_generator(
 1613        m_intrinsic_dim, m_random_generator.get_double(0., max_perturb));
 1615    Tr_point local_random_transl =
 1616        local_tr_traits.construct_weighted_point_d_object()(*tr_point_in_ball_generator++, 0);
 1617    Translation_for_perturb global_transl = k_constr_vec(m_ambient_dim);
 1618    const Tangent_space_basis &tsb = m_tangent_spaces[point_idx];
 1619    for (
int i = 0; i < m_intrinsic_dim; ++i) {
 1620      global_transl = k_transl(global_transl, k_scaled_vec(tsb[i], coord(local_random_transl, i)));
 1623#if defined(GUDHI_USE_TBB)
 1624    m_p_perturb_mutexes[point_idx].lock();
 1625    m_translations[point_idx] = global_transl;
 1626    m_p_perturb_mutexes[point_idx].unlock();
 1629    m_translations[point_idx] = global_transl;
 1634  template <
typename OutputIt>
 1635  bool try_to_solve_inconsistencies_in_a_local_triangulation(
 1636      std::size_t tr_index,
double max_perturb, OutputIt perturbed_pts_indices = CGAL::Emptyset_iterator()) {
 1637    bool is_inconsistent =
false;
 1639    Star
const &star = m_stars[tr_index];
 1642    Star::const_iterator it_inc_simplex = star.begin();
 1643    Star::const_iterator it_inc_simplex_end = star.end();
 1644    for (; it_inc_simplex != it_inc_simplex_end; ++it_inc_simplex) {
 1645      const Incident_simplex &incident_simplex = *it_inc_simplex;
 1648      if (is_infinite(incident_simplex))
continue;
 1650      Simplex c = incident_simplex;
 1654      if (!is_simplex_consistent(c)) {
 1655        is_inconsistent =
true;
 1657        std::size_t idx = tr_index;
 1659        perturb(tr_index, max_perturb);
 1660        *perturbed_pts_indices++ = idx;
 1667    return is_inconsistent;
 1672  std::ostream &export_point_set(std::ostream &os,
bool use_perturbed_points =
false,
 1673                                 const char *coord_separator =
 const {
 1674    if (use_perturbed_points) {
 1675      std::vector<Point> perturbed_points;
 1676      perturbed_points.reserve(m_points.size());
 1677      for (std::size_t i = 0; i < m_points.size(); ++i) perturbed_points.push_back(compute_perturbed_point(i));
 1679      return export_point_set(m_k, perturbed_points, os, coord_separator);
 1681      return export_point_set(m_k, m_points, os, coord_separator);
 1685  template <
int> >
 1686  std::ostream &export_vertices_to_off(std::ostream &os, std::size_t &num_vertices,
false,
 1687                                       ProjectionFunctor
 const {
 1688    if (m_points.empty()) {
 1696    const int N = (m_intrinsic_dim == 1 ? 2 : 1);
 1699    typename K::Compute_coordinate_d coord = m_k.compute_coordinate_d_object();
 1701#ifdef GUDHI_TC_EXPORT_ALL_COORDS_IN_OFF
 1702    int num_coords = m_ambient_dim;
 1704    int num_coords = (std::min)(m_ambient_dim, 3);
 1707#ifdef GUDHI_TC_EXPORT_NORMALS
 1708    OS_container::const_iterator it_os = m_orth_spaces.begin();
 1710    typename Points::const_iterator it_p = m_points.begin();
 1711    typename Points::const_iterator it_p_end = m_points.end();
 1713    for (std::size_t i = 0; it_p != it_p_end; ++it_p, ++i) {
 1714      Point p = point_projection(use_perturbed_points ? compute_perturbed_point(i) : *it_p);
 1715      for (
int ii = 0; ii < N; ++ii) {
 1717        for (; j < num_coords; ++j) os << CGAL::to_double(coord(p, j)) <<
 1718        if (j == 2) os <<
"0";
 1720#ifdef GUDHI_TC_EXPORT_NORMALS
 1721        for (j = 0; j < num_coords; ++j) os <<
" " << CGAL::to_double(coord(*it_os->begin(), j));
 1725#ifdef GUDHI_TC_EXPORT_NORMALS
 1730    num_vertices = N * m_points.size();
 1734  std::ostream &export_simplices_to_off(std::ostream &os, std::size_t &num_OFF_simplices,
 1735                                        bool color_inconsistencies =
false,
 1736                                        Simplex_set
 1737                                        Simplex_set
 1738                                        Simplex_set
const *p_simpl_to_color_in_blue = NULL)
 const {
 1741    num_OFF_simplices = 0;
 1742    std::size_t num_maximal_simplices = 0;
 1743    std::size_t num_inconsistent_maximal_simplices = 0;
 1744    std::size_t num_inconsistent_stars = 0;
 1745    typename Tr_container::const_iterator it_tr = m_triangulations.begin();
 1746    typename Tr_container::const_iterator it_tr_end = m_triangulations.end();
 1748    for (std::size_t idx = 0; it_tr != it_tr_end; ++it_tr, ++idx) {
 1749      bool is_star_inconsistent =
false;
 1751      Triangulation
const &tr = it_tr->tr();
 1753      if (tr.current_dimension() < m_intrinsic_dim)
continue;
 1756      std::stringstream color;
 1758      color << 128 <<
" " << 128 <<
" " << 128;
 1761      typedef std::vector<std::pair<Simplex, int> > Star_using_triangles;
 1762      Star_using_triangles star_using_triangles;
 1765      Star::const_iterator it_inc_simplex = m_stars[idx].begin();
 1766      Star::const_iterator it_inc_simplex_end = m_stars[idx].end();
 1767      for (; it_inc_simplex != it_inc_simplex_end; ++it_inc_simplex) {
 1768        Simplex c = *it_inc_simplex;
 1770        std::size_t num_vertices = c.size();
 1771        ++num_maximal_simplices;
 1773        int color_simplex = -1;
 1774        if (color_inconsistencies && !is_simplex_consistent(c)) {
 1775          ++num_inconsistent_maximal_simplices;
 1777          is_star_inconsistent =
true;
 1779          if (p_simpl_to_color_in_red && std::find(p_simpl_to_color_in_red->begin(), p_simpl_to_color_in_red->end(),
 1780                                                   c) != p_simpl_to_color_in_red->end()) {
 1782          }
else if (p_simpl_to_color_in_green &&
 1783                     std::find(p_simpl_to_color_in_green->begin(), p_simpl_to_color_in_green->end(), c) !=
 1784                         p_simpl_to_color_in_green->end()) {
 1786          }
else if (p_simpl_to_color_in_blue &&
 1787                     std::find(p_simpl_to_color_in_blue->begin(), p_simpl_to_color_in_blue->end(), c) !=
 1788                         p_simpl_to_color_in_blue->end()) {
 1797        if (m_intrinsic_dim == 1) {
 1799          Simplex::iterator it = c.begin();
 1800          for (; it != c.end(); ++it) tmp_c.insert(*it * 2);
 1801          if (num_vertices == 2) tmp_c.insert(*tmp_c.rbegin() + 1);
 1806        if (num_vertices <= 3) {
 1807          star_using_triangles.push_back(std::make_pair(c, color_simplex));
 1810          std::vector<bool> booleans(num_vertices,
false);
 1811          std::fill(booleans.begin() + num_vertices - 3, booleans.end(),
true);
 1814            Simplex::iterator it = c.begin();
 1815            for (
int i = 0; it != c.end(); ++i, ++it) {
 1816              if (booleans[i]) triangle.insert(*it);
 1818            star_using_triangles.push_back(std::make_pair(triangle, color_simplex));
 1819          }
while (std::next_permutation(booleans.begin(), booleans.end()));
 1824      Star_using_triangles::const_iterator it_simplex = star_using_triangles.begin();
 1825      Star_using_triangles::const_iterator it_simplex_end = star_using_triangles.end();
 1826      for (; it_simplex != it_simplex_end; ++it_simplex) {
 1827        const Simplex &c = it_simplex->first;
 1830        if (is_infinite(c))
continue;
 1832        int color_simplex = it_simplex->second;
 1834        std::stringstream sstr_c;
 1836        Simplex::const_iterator it_point_idx = c.begin();
 1837        for (; it_point_idx != c.end(); ++it_point_idx) {
 1838          sstr_c << *it_point_idx <<
 1841        os << 3 <<
" " << sstr_c.str();
 1842        if (color_inconsistencies || p_simpl_to_color_in_red || p_simpl_to_color_in_green || p_simpl_to_color_in_blue) {
 1843          switch (color_simplex) {
 1857              os <<
" " << color.str();
 1861        ++num_OFF_simplices;
 1864      if (is_star_inconsistent) ++num_inconsistent_stars;
 1868    std::cerr <<
 1869              <<
"Export from list of stars to OFF:\n"
 1870              <<
"  * Number of vertices: " << m_points.size() <<
"\n"
 1871              <<
"  * Total number of maximal simplices: " << num_maximal_simplices <<
"\n";
 1872    if (color_inconsistencies) {
 1873      std::cerr <<
"  * Number of inconsistent stars: " << num_inconsistent_stars <<
 1874                << (m_points.size() > 0 ? 100. * num_inconsistent_stars / m_points.size() : 0.) <<
"%)\n"
 1875                <<
"  * Number of inconsistent maximal simplices: " << num_inconsistent_maximal_simplices <<
 1876                << (num_maximal_simplices > 0 ? 100. * num_inconsistent_maximal_simplices / num_maximal_simplices : 0.)
 1879    std::cerr <<
 1886  std::ostream &export_simplices_to_off(
 1887                                        std::size_t &num_OFF_simplices,
 1888                                        Simplex_set
 1889                                        Simplex_set
 1890                                        Simplex_set
 const {
 1891    typedef Simplicial_complex::Simplex Simplex;
 1892    typedef Simplicial_complex::Simplex_set Simplex_set;
 1896    num_OFF_simplices = 0;
 1897    std::size_t num_maximal_simplices = 0;
 1899    typename Simplex_set::const_iterator it_s = complex.simplex_range().begin();
 1900    typename Simplex_set::const_iterator it_s_end = complex.simplex_range().end();
 1902    for (; it_s != it_s_end; ++it_s) {
 1904      ++num_maximal_simplices;
 1906      int color_simplex = -1;
 1907      if (p_simpl_to_color_in_red && std::find(p_simpl_to_color_in_red->begin(), p_simpl_to_color_in_red->end(), c) !=
 1908                                         p_simpl_to_color_in_red->end()) {
 1910      }
 1911                 std::find(p_simpl_to_color_in_green->begin(), p_simpl_to_color_in_green->end(), c) !=
 1912                     p_simpl_to_color_in_green->end()) {
 1914      }
 1915                 std::find(p_simpl_to_color_in_blue->begin(), p_simpl_to_color_in_blue->end(), c) !=
 1916                     p_simpl_to_color_in_blue->end()) {
 1921      typedef std::vector<Simplex> Triangles;
 1922      Triangles triangles;
 1924      int num_vertices =
 1926      if (num_vertices < m_intrinsic_dim + 1)
continue;
 1932      if (m_intrinsic_dim == 1) {
 1934        Simplex::iterator it = c.begin();
 1935        for (; it != c.end(); ++it) tmp_c.insert(*it * 2);
 1936        if (num_vertices == 2) tmp_c.insert(*tmp_c.rbegin() + 1);
 1941      if (num_vertices <= 3) {
 1942        triangles.push_back(c);
 1945        std::vector<bool> booleans(num_vertices,
false);
 1946        std::fill(booleans.begin() + num_vertices - 3, booleans.end(),
true);
 1949          Simplex::iterator it = c.begin();
 1950          for (
 1951            if (booleans[i]) triangle.insert(*it);
 1953          triangles.push_back(triangle);
 1954        }
 1958      Triangles::const_iterator it_tri = triangles.begin();
 1959      Triangles::const_iterator it_tri_end = triangles.end();
 1960      for (; it_tri != it_tri_end; ++it_tri) {
 1962        if (is_infinite(*it_tri))
continue;
 1965        Simplex::const_iterator it_point_idx = it_tri->begin();
 1966        for (; it_point_idx != it_tri->end(); ++it_point_idx) {
 1967          os << *it_point_idx <<
 1970        if (p_simpl_to_color_in_red || p_simpl_to_color_in_green || p_simpl_to_color_in_blue) {
 1971          switch (color_simplex) {
 1985              os <<
" 128 128 128";
 1990        ++num_OFF_simplices;
 1996    std::cerr <<
 1997              <<
"Export from complex to OFF:\n"
 1998              <<
"\n"
 1999              <<
"\n"
 2000              <<
 2017  const int m_intrinsic_dim;
 2018  const int m_ambient_dim;
 2022#ifdef GUDHI_TC_PERTURB_POSITION
 2023  Translations_for_perturb m_translations;
 2024#if defined(GUDHI_USE_TBB)
 2025  Mutex_for_perturb *m_p_perturb_mutexes;
 2029  Points_ds m_points_ds;
 2030  double m_last_max_perturb;
 2031  std::vector<bool> m_are_tangent_spaces_computed;
 2032  TS_container m_tangent_spaces;
 2033#ifdef GUDHI_TC_EXPORT_NORMALS
 2034  OS_container m_orth_spaces;
 2036  Tr_container m_triangulations;
 2038  Stars_container m_stars;
 2039  std::vector<FT> m_squared_star_spheres_radii_incl_margin;
 2040  std::optional<FT> m_max_squared_edge_length;
 2042#ifdef GUDHI_TC_USE_ANOTHER_POINT_SET_FOR_TANGENT_SPACE_ESTIM
 2043  Points m_points_for_tse;
 2044  Points_ds m_points_ds_for_tse;
 2047  mutable CGAL::Random m_random_generator;
Spatial tree data structure to perform (approximate) nearest and furthest neighbor search.
Definition: Kd_tree_search.h:70
K_neighbor_search KNS_range
The range returned by a k-nearest or k-furthest neighbor search. Its value type is std::pair<std::siz...
Definition: Kd_tree_search.h:104
INS_range incremental_nearest_neighbors(Point const &p, FT eps=FT(0)) const
Search incrementally for the nearest neighbors from a query point.
Definition: Kd_tree_search.h:271
KNS_range k_nearest_neighbors(Point const &p, unsigned int k, bool sorted=true, FT eps=FT(0)) const
Search for the k-nearest neighbors from a query point.
Definition: Kd_tree_search.h:245
Incremental_neighbor_search INS_range
The range returned by an incremental nearest or furthest neighbor search. Its value type is std::pair...
Definition: Kd_tree_search.h:112
Tangential complex data structure.
Definition: Tangential_complex.h:126
Tangential_complex(Point_range points, int intrinsic_dimension, const K &k=K())
Constructor from a range of points. Points are copied into the instance, and a search data structure ...
Definition: Tangential_complex.h:241
Fix_inconsistencies_info fix_inconsistencies_using_perturbation(double max_perturb, double time_limit=-1.)
Attempts to fix inconsistencies by perturbing the point positions.
Definition: Tangential_complex.h:397
void compute_tangential_complex()
Computes the tangential complex.
Definition: Tangential_complex.h:331
int intrinsic_dimension() const
Returns the intrinsic dimension of the manifold.
Definition: Tangential_complex.h:280
Point get_perturbed_point(std::size_t vertex) const
Returns the perturbed position of the point corresponding to the vertex given as parameter.
Definition: Tangential_complex.h:299
void set_max_squared_edge_length(FT max_squared_edge_length)
Sets the maximal possible squared edge length for the edges in the triangulations.
Definition: Tangential_complex.h:2013
Point get_point(std::size_t vertex) const
Returns the point corresponding to the vertex given as parameter.
Definition: Tangential_complex.h:292
Num_inconsistencies number_of_inconsistent_simplices(bool verbose=false) const
Definition: Tangential_complex.h:553
int ambient_dimension() const
Returns the ambient dimension.
Definition: Tangential_complex.h:283
std::size_t number_of_vertices() const
Returns the number of vertices.
Definition: Tangential_complex.h:303
int create_complex(Simplex_tree_ &tree, bool export_inconsistent_simplices=true) const
Exports the complex into a Simplex_tree.
Definition: Tangential_complex.h:612
~Tangential_complex()
Destructor.
Definition: Tangential_complex.h:273
Type returned by Tangential_complex::fix_inconsistencies_using_perturbation.
Definition: Tangential_complex.h:379
std::size_t final_num_inconsistent_stars
final number of inconsistent stars
Definition: Tangential_complex.h:389
bool success
true if all inconsistencies could be removed, false if the time limit has been reached before
Definition: Tangential_complex.h:381
unsigned int num_steps
number of steps performed
Definition: Tangential_complex.h:383
std::size_t best_num_inconsistent_stars
best number of inconsistent stars during the process
Definition: Tangential_complex.h:387
std::size_t initial_num_inconsistent_stars
initial number of inconsistent stars
Definition: Tangential_complex.h:385
Type returned by Tangential_complex::number_of_inconsistent_simplices.
Definition: Tangential_complex.h:541
std::size_t num_inconsistent_simplices
Number of inconsistent simplices.
Definition: Tangential_complex.h:545
Number of stars containing at least one inconsistent simplex.
Definition: Tangential_complex.h:547
Total number of simplices in stars (including duplicates that appear in several stars)
Definition: Tangential_complex.h:543
