11#ifndef SKELETON_BLOCKER_ITERATORS_SKELETON_BLOCKERS_BLOCKERS_ITERATORS_H_
   12#define SKELETON_BLOCKER_ITERATORS_SKELETON_BLOCKERS_BLOCKERS_ITERATORS_H_
   14#include <boost/iterator/iterator_facade.hpp>
   18namespace skeleton_blocker {
   26template<
typename MapIteratorType,
typename ReturnType>
   28Blocker_iterator_internal<MapIteratorType, ReturnType>,
   30boost::forward_traversal_tag,
   34  MapIteratorType current_position;
   35  MapIteratorType end_of_map;
   41      current_position(position), end_of_map(end_of_map_) { }
   44    return current_position == other.current_position;
   51  ReturnType dereference()
 const {
   52    return (current_position->second);
   61  void goto_next_blocker() {
   64    }
while (!(current_position == end_of_map) && !first_time_blocker_is_seen());
   67  bool first_time_blocker_is_seen()
 const {
   68    return current_position->first == current_position->second->first_vertex();
   78template<
   80Blocker_iterator_around_vertex_internal<MapIteratorType, ReturnType>,
   82boost::forward_traversal_tag,
   86  MapIteratorType current_position_;
   92      current_position_(position) { }
   95    this->current_position_ = other.current_position_;
  100    return current_position_ == other.current_position_;
  107  ReturnType dereference()
 const {
  108    return (current_position_->second);
  111  MapIteratorType current_position() {
  112    return this->current_position_;
  118namespace skbl = skeleton_blocker;
Iterator through the blockers of a vertex.
Definition: Skeleton_blockers_blockers_iterators.h:84
Definition: Skeleton_blockers_blockers_iterators.h:32
