11#ifndef SKELETON_BLOCKER_SKELETON_BLOCKER_SIMPLEX_H_
   12#define SKELETON_BLOCKER_SKELETON_BLOCKER_SIMPLEX_H_
   18#include <initializer_list>
   24namespace skeleton_blocker {
   40  std::set<T> simplex_set;
   43  typedef typename T::boost_vertex_handle boost_vertex_handle;
   45  typedef T Vertex_handle;
   47  typedef typename std::set<T>::const_iterator Simplex_vertex_const_iterator;
   48  typedef typename std::set<T>::iterator Simplex_vertex_iterator;
   59    std::for_each(list.begin(), list.end(), [&] (T
const& elt) {
   64  template<
typename ... Args>
   66    add_vertices(args...);
   69  template<
typename ... Args>
   70  void add_vertices(T v, Args ... args) {
   72    add_vertices(args...);
   75  void add_vertices(T v) {
   79  void add_vertices() { }
   86    if ((token[0] ==
'{') && (token[token.size() - 1] ==
   88      token.erase(token.size() - 1, 1);
   89      while (token.size() != 0) {
   90        int coma_position = token.find_first_of(
   92        std::string n = token.substr(0, coma_position);
   94        token.erase(0, n.size() + 1);
  111    simplex_set.insert(v);
  118    simplex_set.erase(v);
  126    v.reserve((std::min)(simplex_set.size(), a.simplex_set.size()));
  128    set_intersection(simplex_set.begin(), simplex_set.end(),
  129                     a.simplex_set.begin(), a.simplex_set.end(),
  130                     std::back_inserter(v));
  133      simplex_set.insert(i);
  141    v.reserve(simplex_set.size());
  143    set_difference(simplex_set.begin(), simplex_set.end(),
  144                   a.simplex_set.begin(), a.simplex_set.end(),
  145                   std::back_inserter(v));
  149      simplex_set.insert(i);
  157    v.reserve(simplex_set.size() + a.simplex_set.size());
  159    set_union(simplex_set.begin(), simplex_set.end(), a.simplex_set.begin(),
  160              a.simplex_set.end(), std::back_inserter(v));
  162    simplex_set.insert(v.begin(), v.end());
  165  typename std::set<T>::const_iterator begin()
 const {
  166    return simplex_set.cbegin();
  169  typename std::set<T>::const_iterator end()
 const {
  170    return simplex_set.cend();
  173  typename std::set<T>::const_reverse_iterator rbegin()
 const {
  174    return simplex_set.crbegin();
  177  typename std::set<T>::const_reverse_iterator rend()
 const {
  178    return simplex_set.crend();
  181  typename std::set<T>::iterator begin() {
  182    return simplex_set.begin();
  185  typename std::set<T>::iterator end() {
  186    return simplex_set.end();
  198    return (simplex_set.size() - 1);
  202    return simplex_set.empty();
  222    return *(simplex_set.rbegin());
  229    return includes(simplex_set.cbegin(), simplex_set.cend(),
  230                    a.simplex_set.cbegin(), a.simplex_set.cend());
  238    auto first1 = begin();
  241    auto first2 = a.begin();
  242    auto last2 = a.end();
  244    while (first2 != last2) {
  249        if ((first1 == last1) || (*first2 < *first1))
  251        if (!(*first1 < *first2))
  263    auto first1 = begin();
  266    auto first2 = a.begin();
  267    auto last2 = a.end();
  269    while (first2 != last2) {
  274        if ((first1 == last1) || (*first2 < *first1))
  276        if (!(*first1 < *first2))
  288    auto first1 = begin();
  291    auto first2 = a.begin();
  292    auto last2 = a.end();
  294    while (first2 != last2) {
  296      if (x == *first2 || y == *first2) {
  299        if ((first1 == last1) || (*first2 < *first1))
  301        if (!(*first1 < *first2))
  310    return (simplex_set.find(v) != simplex_set.end());
  313  bool disjoint(
const Skeleton_blocker_simplex& a)
 const {
  315    v.reserve(std::min(simplex_set.size(), a.simplex_set.size()));
  317    set_intersection(simplex_set.cbegin(), simplex_set.cend(),
  318                     a.simplex_set.cbegin(), a.simplex_set.cend(),
  319                     std::back_inserter(v));
  321    return (v.size() == 0);
  324  bool operator==(
const Skeleton_blocker_simplex& other)
 const {
  325    return (this->simplex_set == other.simplex_set);
  328  bool operator!=(
 const {
  329    return (this->simplex_set != other.simplex_set);
  332  bool operator<(
 const {
  333    return (std::lexicographical_compare(this->simplex_set.begin(),
  334                                         this->simplex_set.end(), other.begin(),
  340  friend std::ostream& operator<<(std::ostream& o,
  341                                  const Skeleton_blocker_simplex & sigma) {
  344    for (
auto i : sigma) {
  358namespace skbl = skeleton_blocker;
Abstract simplex used in Skeleton blockers data-structure.
Definition: Skeleton_blocker_simplex.h:38
T first_vertex() const
Definition: Skeleton_blocker_simplex.h:210
bool contains_difference(const Skeleton_blocker_simplex &a, T x, T y) const
Definition: Skeleton_blocker_simplex.h:287
void union_vertices(const Skeleton_blocker_simplex &a)
Definition: Skeleton_blocker_simplex.h:155
bool contains(const Skeleton_blocker_simplex &a) const
Definition: Skeleton_blocker_simplex.h:228
void intersection(const Skeleton_blocker_simplex &a)
Definition: Skeleton_blocker_simplex.h:124
Skeleton_blocker_simplex(std::string token)
Definition: Skeleton_blocker_simplex.h:84
T last_vertex() const
Definition: Skeleton_blocker_simplex.h:220
void remove_vertex(T v)
Definition: Skeleton_blocker_simplex.h:117
bool contains_difference(const Skeleton_blocker_simplex &a, T x) const
Definition: Skeleton_blocker_simplex.h:262
bool contains_difference(const Skeleton_blocker_simplex &a, const Skeleton_blocker_simplex &b) const
Definition: Skeleton_blocker_simplex.h:236
void difference(const Skeleton_blocker_simplex &a)
Definition: Skeleton_blocker_simplex.h:139
int dimension() const
Definition: Skeleton_blocker_simplex.h:197
void add_vertex(T v)
Definition: Skeleton_blocker_simplex.h:110
