11#ifndef CONCEPT_ALPHA_COMPLEX_SIMPLICIAL_COMPLEX_FOR_ALPHA_H_
   12#define CONCEPT_ALPHA_COMPLEX_SIMPLICIAL_COMPLEX_FOR_ALPHA_H_
   16namespace alpha_complex {
The concept SimplicialComplexForAlpha describes the requirements for a type to implement a simplicial...
Definition: SimplicialComplexForAlpha.h:21
Skeleton_simplex_range skeleton_simplex_range
Returns a range over the simplices of the skeleton of the simplicial complex, for a given dimension.
Definition: SimplicialComplexForAlpha.h:70
int assign_filtration(Simplex_handle simplex, Filtration_value filtration)
std::size_t num_vertices()
int dimension(Simplex_handle simplex)
Boundary_simplex_range boundary_simplex_range(Simplex_handle const &simplex)
Returns a range over boundaries of a given simplex.
void prune_above_filtration(Filtration_value filtration)
Simplex_key null_key()
Returns a constant dummy number that is either negative, or at least as large as the number of simpli...
void make_filtration_non_decreasing()
void assign_key(Simplex_handle sh, Simplex_key n)
Store a number for a simplex, which can later be retrieved with key().
Simplex_vertex_range simplex_vertex_range(Simplex_handle const &simplex)
Returns a range over vertices of a given simplex.
void insert_simplex_and_subfaces(std::vector< Vertex_handle > const &vertex_range, Filtration_value filtration)
Inserts a simplex with vertices from a given simplex (represented by a vector of Vertex_handle) in th...
Simplex_key key(Simplex_handle sh)
Returns the number stored for a simplex by assign_key().
unspecified Boundary_simplex_range
Iterator over the boundaries of the complex, in an arbitrary order.
Definition: SimplicialComplexForAlpha.h:59
unspecified Skeleton_simplex_range
Iterator over the simplices of the skeleton of the complex, for a given dimension.
Definition: SimplicialComplexForAlpha.h:67
unspecified Simplex_key
Data stored for each simplex.
Definition: SimplicialComplexForAlpha.h:82
unspecified Simplex_handle
Definition: SimplicialComplexForAlpha.h:23
unspecified Simplex_vertex_range
Iterator over vertices of a simplex.
Definition: SimplicialComplexForAlpha.h:51
unspecified Vertex_handle
Definition: SimplicialComplexForAlpha.h:25
unspecified Filtration_value
Definition: SimplicialComplexForAlpha.h:27
unspecified Insertion_result_type
Return type of an insertion of a simplex.
Definition: SimplicialComplexForAlpha.h:74
