#include <gudhi/Bitmap_cubical_complex.h>
#include <gudhi/Persistent_cohomology.h>
#include <iostream>
#include <sstream>
#include <vector>
int main(int argc, char** argv) {
  srand(time(0));
  std::clog
      << "This program computes persistent homology, by using bitmap_cubical_complex class, of cubical "
      << "complexes. The first parameter of the program is the dimension D of the bitmap. The next D parameters are "
      << "number of top dimensional cubes in each dimension of the bitmap. The program will create random cubical "
      << "complex of that sizes and compute persistent homology of it." << std::endl;
  int p = 2;
  double min_persistence = 0;
  if (argc < 3) {
    std::cerr << "Wrong number of parameters, the program will now terminate\n";
    return 1;
  size_t dimensionOfBitmap = (size_t)atoi(argv[1]);
  std::vector<unsigned> sizes;
  size_t multipliers = 1;
  for (size_t dim = 0; dim != dimensionOfBitmap; ++dim) {
    unsigned sizeInThisDimension = (unsigned)atoi(argv[2 + dim]);
    sizes.push_back(sizeInThisDimension);
    multipliers *= sizeInThisDimension;
  std::vector<double> data;
  for (size_t i = 0; i != multipliers; ++i) {
    data.push_back(rand() / static_cast<double>(RAND_MAX));
  Bitmap_cubical_complex b(sizes, data);
  std::stringstream ss;
  ss << "randomComplex_persistence";
  std::ofstream out(ss.str().c_str());
  out.close();
  return 0;
Cubical complex represented as a bitmap, class with basic implementation.
Definition: Bitmap_cubical_complex_base.h:53
Cubical complex represented as a bitmap.
Definition: Bitmap_cubical_complex.h:48
Structure representing the coefficient field .
Definition: Field_Zp.h:27
Computes the persistent cohomology of a filtered complex.
Definition: Persistent_cohomology.h:52
void output_diagram(std::ostream &ostream=std::cout)
Output the persistence diagram in ostream.
Definition: Persistent_cohomology.h:561
void compute_persistent_cohomology(Filtration_value min_interval_length=0)
Compute the persistent homology of the filtered simplicial complex.
Definition: Persistent_cohomology.h:172
void init_coefficients(int charac)
Initializes the coefficient field.
Definition: Persistent_cohomology.h:156
This file includes common file reader for GUDHI.
