11#ifndef HASSE_DIAGRAM_CELL_H
   12#define HASSE_DIAGRAM_CELL_H
   22namespace Hasse_diagram {
   24template <
typename Cell_type>
   48template <
typename Inc
idence_type_,
typename Filtration_type_,
typename Additional_information_ =
void>
   51  typedef Incidence_type_ Incidence_type;
   52  typedef Filtration_type_ Filtration_type;
   53  typedef Additional_information_ Additional_information;
   54  using Cell_range = std::vector<std::pair<Hasse_diagram_cell*, Incidence_type> >;
   70      : dimension(dim), position(0), deleted_(false), filtration(filt_) {}
   76      : dimension(dim), boundary(boundary_), position(0), deleted_(false) {}
   82      : dimension(dim), boundary(boundary_), coBoundary(coboundary_), position(0), deleted_(false) {}
   88  Hasse_diagram_cell(
const Cell_range& boundary_,
const Cell_range& coboundary_,
const Additional_information& ai,
   92        coBoundary(coboundary_),
  101      : dimension(dim), additional_info(ai), position(0), deleted_(false) {}
  140    return this->filtration;
  148  inline bool deleted() {
return this->deleted_; }
  150  template <
typename Cell_type>
  151  friend class Hasse_diagram;
  153  template <
typename Cell_type>
  154  friend class is_before_in_filtration;
  156  template <
typename Complex_type,
typename Cell_type>
  157  friend std::vector<Cell_type*> convert_to_vector_of_Cell_type(Complex_type& cmplx);
  164    Cell_range new_boundary;
  165    new_boundary.reserve(this->boundary.size());
  166    for (std::size_t bd = 0; bd != this->boundary.size(); ++bd) {
  167      if (!this->boundary[bd].first->deleted()) {
  168        new_boundary.push_back(this->boundary[bd]);
  171    this->boundary.swap(new_boundary);
  173    Cell_range new_coBoundary;
  174    new_coBoundary.reserve(this->coBoundary.size());
  175    for (std::size_t cbd = 0; cbd != this->coBoundary.size(); ++cbd) {
  176      if (!this->coBoundary[cbd].first->deleted()) {
  177        new_coBoundary.push_back(this->coBoundary[cbd]);
  180    this->coBoundary.swap(new_coBoundary);
  190    out << c.position <<
" " << c.dimension <<
" " << c.filtration << std::endl;
  191    for (std::size_t bd = 0; bd != c.boundary.size(); ++bd) {
  193      if (c.boundary[bd].first->deleted())
continue;
  194      out << c.boundary[bd].first->position <<
" " << c.boundary[bd].second <<
  204    std::vector<Hasse_diagram_cell*> result;
  205    std::size_t size_of_boundary = this->boundary.size();
  206    result.reserve(size_of_boundary);
  207    for (std::size_t bd = 0; bd != size_of_boundary; ++bd) {
  208      result.push_back(this->boundary[bd].first);
  217    std::vector<unsigned> result;
  218    std::size_t size_of_boundary = this->boundary.size();
  219    result.reserve(size_of_boundary);
  220    for (std::size_t bd = 0; bd != size_of_boundary; ++bd) {
  221      result.push_back(this->boundary[bd].first->position);
  232    result +=
"dimension: ";
  233    result += std::to_string(this->dimension);
  234    result +=
" filtration: ";
  235    result += std::to_string(this->filtration);
  236    result +=
" position: ";
  237    result += std::to_string(this->position);
  238    result +=
" deleted_: ";
  239    result += std::to_string(this->deleted_);
  243    if (std::is_same<Additional_information, void>::value) {
  244      result +=
" Additional_information: ";
  245      result += std::to_string(this->additional_info);
  247    result +=
" boundary ";
  248    for (std::size_t bd = 0; bd != this->boundary.size(); ++bd) {
  249      result +=
"( " + std::to_string(this->boundary[bd].first->position);
  250      result +=
" " + std::to_string(this->boundary[bd].second);
  254    result +=
" coBoundary ";
  255    for (std::size_t cbd = 0; cbd != this->coBoundary.size(); ++cbd) {
  256      result +=
"( " + std::to_string(this->coBoundary[cbd].first->position);
  257      result +=
" " + std::to_string(this->coBoundary[cbd].second);
  266  Cell_range coBoundary;
  268  Additional_information additional_info;
  271  Filtration_type filtration;
  279  void delete_cell() { this->deleted_ =
true; }
Data structure to store a cell in a Hasse diagram.
Definition: Hasse_diagram_cell.h:49
Filtration_type & get_filtration()
Definition: Hasse_diagram_cell.h:138
Additional_information & get_additional_information()
Definition: Hasse_diagram_cell.h:125
bool deleted()
Definition: Hasse_diagram_cell.h:148
Cell_range & get_coBoundary()
Definition: Hasse_diagram_cell.h:115
std::vector< unsigned > get_list_of_positions_of_boundary_elements()
Definition: Hasse_diagram_cell.h:216
Hasse_diagram_cell(int dim)
Definition: Hasse_diagram_cell.h:64
Hasse_diagram_cell(int dim, Filtration_type filt_)
Definition: Hasse_diagram_cell.h:69
void remove_deleted_elements_from_boundary_and_coboundary()
Definition: Hasse_diagram_cell.h:163
Hasse_diagram_cell(Additional_information ai, int dim)
Definition: Hasse_diagram_cell.h:100
Hasse_diagram_cell()
Definition: Hasse_diagram_cell.h:59
Cell_range & get_boundary()
Definition: Hasse_diagram_cell.h:108
Hasse_diagram_cell(const Cell_range &boundary_, const Cell_range &coboundary_, const Additional_information &ai, int dim)
Definition: Hasse_diagram_cell.h:88
int & get_dimension()
Definition: Hasse_diagram_cell.h:120
friend std::ostream & operator<<(std::ostream &out, const Hasse_diagram_cell< Incidence_type, Filtration_type, Additional_information > &c)
Definition: Hasse_diagram_cell.h:186
Hasse_diagram_cell(const Cell_range &boundary_, int dim)
Definition: Hasse_diagram_cell.h:75
std::vector< Hasse_diagram_cell * > get_list_of_boundary_elements()
Definition: Hasse_diagram_cell.h:203
unsigned & get_position()
Definition: Hasse_diagram_cell.h:133
Hasse_diagram_cell(const Cell_range &boundary_, const Cell_range &coboundary_, int dim)
Definition: Hasse_diagram_cell.h:81
std::string full_signature_of_the_structure()
Definition: Hasse_diagram_cell.h:230
