#include <gudhi/Alpha_complex.h>
#include <gudhi/Simplex_tree.h>
#include <CGAL/Epick_d.h>
#include <iostream>
#include <string>
void usage(int nbArgs, char * const progName) {
  std::cerr << "Error: Number of arguments (" << nbArgs << ") is not correct\n";
  std::cerr << "Usage: " << progName << " filename.off alpha_square_max_value [ouput_file.txt]\n";
  std::cerr << "       i.e.: " << progName << " ../../data/points/alphacomplexdoc.off 60.0\n";
  exit(-1);
int main(int argc, char **argv) {
  if ((argc != 3) && (argc != 4)) usage(argc, (argv[0] - 1));
  std::string off_file_name {argv[1]};
  double alpha_square_max_value {atof(argv[2])};
  using Fast_kernel = CGAL::Epick_d<CGAL::Dynamic_dimension_tag>;
  std::streambuf* streambuffer;
  std::ofstream ouput_file_stream;
  if (argc == 4) {
    ouput_file_stream.open(std::string(argv[3]));
    streambuffer = ouput_file_stream.rdbuf();
  } else {
    streambuffer = std::clog.rdbuf();
  if (alpha_complex_from_file.create_complex(simplex, alpha_square_max_value)) {
    std::ostream output_stream(streambuffer);
    output_stream <<
"Alpha complex is of dimension " << simplex.
dimension() <<
    output_stream << "Iterator on alpha complex simplices in the filtration order, with [filtration value]:" <<
        std::endl;
      output_stream << "   ( ";
        output_stream << vertex << " ";
      output_stream <<
"[" << simplex.
filtration(f_simplex) <<
      output_stream << std::endl;
  ouput_file_stream.close();
  return 0;
Simplex Tree data structure for representing simplicial complexes.
Definition: Simplex_tree.h:81
Filtration_simplex_range const & filtration_simplex_range(Indexing_tag=Indexing_tag())
Returns a range over the simplices of the simplicial complex, in the order of the filtration.
Definition: Simplex_tree.h:273
Simplex_vertex_range simplex_vertex_range(Simplex_handle sh) const
Returns a range over the vertices of a simplex.
Definition: Simplex_tree.h:284
static Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
Definition: Simplex_tree.h:537
size_t num_vertices() const
Returns the number of vertices in the complex.
Definition: Simplex_tree.h:574
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:602
size_t num_simplices()
returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:580
Alpha complex data structure.
Definition: Alpha_complex.h:103
