11#ifndef BITMAP_CUBICAL_COMPLEX_BASE_H_
   12#define BITMAP_CUBICAL_COMPLEX_BASE_H_
   14#include <gudhi/Bitmap_cubical_complex/counter.h>
   16#include <boost/config.hpp>
   31namespace cubical_complex {
   55  typedef T filtration_type;
  145    std::vector<unsigned> coface_counter = this->compute_counter_for_given_cell(coface);
  146    std::vector<unsigned> face_counter = this->compute_counter_for_given_cell(face);
  149    int number_of_position_in_which_counters_do_not_agree = -1;
  150    std::size_t number_of_full_faces_that_comes_before = 0;
  151    for (std::size_t i = 0; i != coface_counter.size(); ++i) {
  152      if ((coface_counter[i] % 2 == 1) && (number_of_position_in_which_counters_do_not_agree == -1)) {
  153        ++number_of_full_faces_that_comes_before;
  155      if (coface_counter[i] != face_counter[i]) {
  156        if (number_of_position_in_which_counters_do_not_agree != -1) {
  157          std::cerr <<
"Cells given to compute_incidence_between_cells procedure do not form a pair of coface-face.\n";
  158          throw std::logic_error(
  159              "Cells given to compute_incidence_between_cells procedure do not form a pair of coface-face.");
  161        number_of_position_in_which_counters_do_not_agree = i;
  166    if (number_of_full_faces_that_comes_before % 2) incidence = -1;
  168    if (coface_counter[number_of_position_in_which_counters_do_not_agree] + 1 ==
  169        face_counter[number_of_position_in_which_counters_do_not_agree]) {
  207  inline unsigned dimension()
 const {
return sizes.size(); }
  212  inline std::size_t
size()
 const {
return this->data.size(); }
  218  template <
typename K>
  256    typedef std::input_iterator_tag iterator_category;
  257    typedef std::size_t value_type;
  258    typedef std::ptrdiff_t difference_type;
  259    typedef value_type* pointer;
  260    typedef value_type reference;
  282      if (this->
counter != rhs.counter)
return false;
  295    std::size_t operator*() {
return this->
counter; }
  315    a.counter = this->data.size();
  340  typedef typename std::vector<std::size_t> Boundary_range;
  352  typedef typename std::vector<std::size_t> Coboundary_range;
  366    typedef std::input_iterator_tag iterator_category;
  367    typedef std::size_t value_type;
  368    typedef std::ptrdiff_t difference_type;
  369    typedef value_type* pointer;
  370    typedef value_type reference;
  380      while ((dim != this->b.
dimension()) && (this->counter[dim] == this->b.sizes[dim] - 1)) ++dim;
  384        for (std::size_t i = 0; i != dim; ++i) {
  406      if (&this->b != &rhs.b)
return false;
  407      if (this->
counter.size() != rhs.counter.size())
return false;
  408      for (std::size_t i = 0; i != this->
  409        if (this->
counter[i] != rhs.counter[i])
return false;
  423    std::size_t operator*() {
return this->compute_index_in_bitmap(); }
  425    std::size_t compute_index_in_bitmap()
 const {
  426      std::size_t index = 0;
  427      for (std::size_t i = 0; i != this->
  428        index += (2 * this->
counter[i] + 1) * this->b.multipliers[i];
  433    void print_counter()
 const {
  434      for (std::size_t i = 0; i != this->
  435        std::clog << this->
counter[i] <<
  441    std::vector<std::size_t>
counter;
  458    for (std::size_t i = 0; i != this->
dimension(); ++i) {
  459      a.counter[i] = this->sizes[i] - 1;
  487  inline std::size_t number_cells()
 const {
return this->total_number_of_cells; }
  495  std::vector<unsigned> sizes;
  496  std::vector<unsigned> multipliers;
  498  std::size_t total_number_of_cells;
  500  void set_up_containers(
const std::vector<unsigned>& sizes) {
  501    unsigned multiplier = 1;
  502    for (std::size_t i = 0; i != sizes.size(); ++i) {
  503      this->sizes.push_back(sizes[i]);
  504      this->multipliers.push_back(multiplier);
  505      multiplier *= 2 * sizes[i] + 1;
  507    this->data = std::vector<T>(multiplier, std::numeric_limits<T>::infinity());
  508    this->total_number_of_cells = multiplier;
  511  std::size_t compute_position_in_bitmap(
const std::vector<unsigned>& counter) {
  512    std::size_t position = 0;
  513    for (std::size_t i = 0; i != this->multipliers.size(); ++i) {
  514      position += this->multipliers[i] * counter[i];
  519  std::vector<unsigned> compute_counter_for_given_cell(std::size_t cell)
 const {
  520    std::vector<unsigned> counter;
  521    counter.reserve(this->sizes.size());
  522    for (std::size_t dim = this->sizes.size(); dim != 0; --dim) {
  523      counter.push_back(cell / this->multipliers[dim - 1]);
  524      cell = cell % this->multipliers[dim - 1];
  526    std::reverse(counter.begin(), counter.end());
  529  void read_perseus_style_file(
const char* perseus_style_file);
  530  void setup_bitmap_based_on_top_dimensional_cells_list(
const std::vector<unsigned>& sizes_in_following_directions,
  531                                                        const std::vector<T>& top_dimensional_cells);
  535                              std::vector<bool> directions);
  542  std::pair<T, T> min_max = this->min_max_filtration();
  543  T dx = (min_max.second - min_max.first) / (T)number_of_bins;
  546  for (std::size_t i = 0; i != this->data.size(); ++i) {
  548      std::clog <<
"Before binning : " << this->data[i] << std::endl;
  550    this->data[i] = min_max.first + dx * (this->data[i] - min_max.first) / number_of_bins;
  552      std::clog <<
"After binning : " << this->data[i] << std::endl;
  560  std::pair<T, T> min_max = this->min_max_filtration();
  562  std::size_t number_of_bins = (min_max.second - min_max.first) / diameter_of_bin;
  564  for (std::size_t i = 0; i != this->data.size(); ++i) {
  566      std::clog <<
  568    this->data[i] = min_max.first + diameter_of_bin * (this->data[i] - min_max.first) / number_of_bins;
  570      std::clog <<
  577  std::pair<T, T> min_max(std::numeric_limits<T>::infinity(), -std::numeric_limits<T>::infinity());
  578  for (std::size_t i = 0; i != this->data.size(); ++i) {
  579    if (this->data[i] < min_max.first) min_max.first = this->data[i];
  580    if (this->data[i] > min_max.second) min_max.second = this->data[i];
  588       it != b.all_cells_const_end(); ++it) {
  596  this->set_up_containers(sizes);
  601    const std::vector<unsigned>& sizes_in_following_directions,
const std::vector<T>& top_dimensional_cells) {
  602  this->set_up_containers(sizes_in_following_directions);
  604  std::size_t number_of_top_dimensional_elements = 1;
  605  for (std::size_t i = 0; i != sizes_in_following_directions.size(); ++i) {
  606    number_of_top_dimensional_elements *= sizes_in_following_directions[i];
  608  if (number_of_top_dimensional_elements != top_dimensional_cells.size()) {
  609    std::cerr <<
"Error in constructor Bitmap_cubical_complex_base ( std::vector<std::size_t> "
  610              <<
"sizes_in_following_directions, std::vector<T> top_dimensional_cells ). Number of top dimensional "
  611              <<
"elements that follow from sizes_in_following_directions vector is different than the size of "
  612              <<
"top_dimensional_cells vector."
  615        "Error in constructor Bitmap_cubical_complex_base( std::vector<std::size_t> sizes_in_following_directions,"
  616        "std::vector<T> top_dimensional_cells ). Number of top dimensional elements that follow from "
  617        "sizes_in_following_directions vector is different than the size of top_dimensional_cells vector.");
  620  Bitmap_cubical_complex_base<T>::Top_dimensional_cells_iterator it(*
this);
  621  std::size_t index = 0;
  622  for (it = this->top_dimensional_cells_iterator_begin(); it != this->top_dimensional_cells_iterator_end(); ++it) {
  623    this->get_cell_data(*it) = top_dimensional_cells[index];
  626  this->impose_lower_star_filtration();
  631  if (this->get_dimension_of_a_cell(splx) == this->dimension()){
return splx;}
  633    for (
auto v : this->get_coboundary_of_a_cell(splx)){
  634      if(this->get_cell_data(v) == this->get_cell_data(splx)){
  635        return this->get_top_dimensional_coface_of_a_cell(v);
  639  BOOST_UNREACHABLE_RETURN(-2);
  644                                                            const std::vector<T>& top_dimensional_cells) {
  645  this->setup_bitmap_based_on_top_dimensional_cells_list(sizes_in_following_directions, top_dimensional_cells);
  651  std::ifstream inFiltration;
  652  inFiltration.open(perseus_style_file);
  653  unsigned dimensionOfData;
  654  inFiltration >> dimensionOfData;
  657    std::clog <<
"dimensionOfData : " << dimensionOfData << std::endl;
  660  std::vector<unsigned> sizes;
  661  sizes.reserve(dimensionOfData);
  663  std::size_t dimensions = 1;
  664  for (std::size_t i = 0; i != dimensionOfData; ++i) {
  665    unsigned size_in_this_dimension;
  666    inFiltration >> size_in_this_dimension;
  667    sizes.push_back(size_in_this_dimension);
  668    dimensions *= size_in_this_dimension;
  670      std::clog <<
"size_in_this_dimension : " << size_in_this_dimension << std::endl;
  673  this->set_up_containers(sizes);
  675  Bitmap_cubical_complex_base<T>::Top_dimensional_cells_iterator it(*
this);
  676  it = this->top_dimensional_cells_iterator_begin();
  678  T filtrationLevel = 0.;
  679  std::size_t filtration_counter = 0;
  680  while (!inFiltration.eof()) {
  682    getline(inFiltration, line);
  683    if (line.length() != 0) {
  684      int n = sscanf(line.c_str(),
"%lf", &filtrationLevel);
  686        std::string perseus_error(
"Bad Perseus file format. This line is incorrect : " + line);
  687        throw std::ios_base::failure(perseus_error.c_str());
  691        std::clog <<
"Cell of an index : " << it.compute_index_in_bitmap()
  692                  <<
" and dimension: " << this->get_dimension_of_a_cell(it.compute_index_in_bitmap())
  693                  <<
" get the value : " << filtrationLevel << std::endl;
  695      this->get_cell_data(*it) = filtrationLevel;
  697      ++filtration_counter;
  701  if (filtration_counter != dimensions) {
  702    std::string perseus_error(
"Bad Perseus file format. Read " + std::to_string(filtration_counter) +
" expected " + \
  703      std::to_string(dimensions) +
" values");
  704    throw std::ios_base::failure(perseus_error.c_str());
  707  inFiltration.close();
  708  this->impose_lower_star_filtration();
  713                                                            std::vector<bool> directions) {
  717  this->read_perseus_style_file(perseus_style_file);
  722                                                            std::vector<bool> directions) {
  726  this->set_up_containers(sizes);
  731                                                            const std::vector<T>& top_dimensional_cells,
  732                                                            std::vector<bool> directions) {
  736  this->setup_bitmap_based_on_top_dimensional_cells_list(dimensions, top_dimensional_cells);
  741  this->read_perseus_style_file(perseus_style_file);
  746  std::vector<std::size_t> boundary_elements;
  749  boundary_elements.reserve(this->dimension() * 2);
  751  std::size_t sum_of_dimensions = 0;
  752  std::size_t cell1 = cell;
  753  for (std::size_t i = this->multipliers.size(); i != 0; --i) {
  754    unsigned position = cell1 / this->multipliers[i - 1];
  755    if (position % 2 == 1) {
  756      if (sum_of_dimensions % 2) {
  757        boundary_elements.push_back(cell + this->multipliers[i - 1]);
  758        boundary_elements.push_back(cell - this->multipliers[i - 1]);
  760        boundary_elements.push_back(cell - this->multipliers[i - 1]);
  761        boundary_elements.push_back(cell + this->multipliers[i - 1]);
  765    cell1 = cell1 % this->multipliers[i - 1];
  768  return boundary_elements;
  773  std::vector<unsigned>
counter = this->compute_counter_for_given_cell(cell);
  774  std::vector<std::size_t> coboundary_elements;
  775  std::size_t cell1 = cell;
  776  for (std::size_t i = this->multipliers.size(); i != 0; --i) {
  777    unsigned position = cell1 / this->multipliers[i - 1];
  778    if (position % 2 == 0) {
  779      if ((cell > this->multipliers[i - 1]) && (
counter[i - 1] != 0)) {
  780        coboundary_elements.push_back(cell - this->multipliers[i - 1]);
  782      if ((cell + this->multipliers[i - 1] < this->data.size()) && (
counter[i - 1] != 2 * this->sizes[i - 1])) {
  783        coboundary_elements.push_back(cell + this->multipliers[i - 1]);
  786    cell1 = cell1 % this->multipliers[i - 1];
  788  return coboundary_elements;
  794  if (dbg) std::clog <<
"\n\n\n Computing position o a cell of an index : " << cell << std::endl;
  795  unsigned dimension = 0;
  796  for (std::size_t i = this->multipliers.size(); i != 0; --i) {
  797    unsigned position = cell / this->multipliers[i - 1];
  800      std::clog <<
"i-1 :" << i - 1 << std::endl;
  801      std::clog <<
"cell : " << cell << std::endl;
  802      std::clog <<
"position : " << position << std::endl;
  803      std::clog <<
"multipliers[" << i - 1 <<
"] = " << this->multipliers[i - 1] << std::endl;
  806    if (position % 2 == 1) {
  807      if (dbg) std::clog <<
"Nonzero length in this direction \n";
  810    cell = cell % this->multipliers[i - 1];
  817  return this->data[cell];
  825  std::vector<bool> is_this_cell_considered(this->data.size(),
false);
  827  std::size_t size_to_reserve = 1;
  828  for (std::size_t i = 0; i != this->multipliers.size(); ++i) {
  829    size_to_reserve *= (std::size_t)((this->multipliers[i] - 1) / 2);
  832  std::vector<std::size_t> indices_to_consider;
  833  indices_to_consider.reserve(size_to_reserve);
  837  for (it = this->top_dimensional_cells_iterator_begin(); it != this->top_dimensional_cells_iterator_end(); ++it) {
  838    indices_to_consider.push_back(it.compute_index_in_bitmap());
  841  while (indices_to_consider.size()) {
  843      std::clog <<
"indices_to_consider in this iteration \n";
  844      for (std::size_t i = 0; i != indices_to_consider.size(); ++i) {
  845        std::clog << indices_to_consider[i] <<
  848    std::vector<std::size_t> new_indices_to_consider;
  849    for (std::size_t i = 0; i != indices_to_consider.size(); ++i) {
  850      std::vector<std::size_t> bd = this->get_boundary_of_a_cell(indices_to_consider[i]);
  851      for (std::size_t boundaryIt = 0; boundaryIt != bd.size(); ++boundaryIt) {
  853          std::clog <<
"filtration of a cell : " << bd[boundaryIt] <<
" is : " << this->data[bd[boundaryIt]]
  854                    <<
" while of a cell: " << indices_to_consider[i] <<
" is: " << this->data[indices_to_consider[i]]
  857        if (this->data[bd[boundaryIt]] > this->data[indices_to_consider[i]]) {
  858          this->data[bd[boundaryIt]] = this->data[indices_to_consider[i]];
  860            std::clog <<
"Setting the value of a cell : " << bd[boundaryIt]
  861                      <<
" to : " << this->data[indices_to_consider[i]] << std::endl;
  864        if (is_this_cell_considered[bd[boundaryIt]] ==
false) {
  865          new_indices_to_consider.push_back(bd[boundaryIt]);
  866          is_this_cell_considered[bd[boundaryIt]] =
true;
  870    indices_to_consider.swap(new_indices_to_consider);
  875bool compareFirstElementsOfTuples(
const std::pair<std::pair<T, std::size_t>,
char>& first,
  876                                  const std::pair<std::pair<T, std::size_t>,
char>& second) {
  877  if (first.first.first < second.first.first) {
  880    if (first.first.first > second.first.first) {
  884    return first.second < second.second;
  890namespace Cubical_complex = cubical_complex;
Iterator through all cells in the complex (in order they appear in the structure – i....
Definition: Bitmap_cubical_complex_base.h:254
All_cells_range class provides ranges for All_cells_iterator.
Definition: Bitmap_cubical_complex_base.h:322
Iterator through top dimensional cells of the complex. The cells appear in order they are stored in t...
Definition: Bitmap_cubical_complex_base.h:364
Top_dimensional_cells_iterator_range class provides ranges for Top_dimensional_cells_iterator_range.
Definition: Bitmap_cubical_complex_base.h:468
Cubical complex represented as a bitmap, class with basic implementation.
Definition: Bitmap_cubical_complex_base.h:53
All_cells_iterator all_cells_iterator_end()
Definition: Bitmap_cubical_complex_base.h:313
std::vector< std::size_t >::const_iterator Coboundary_iterator
Definition: Bitmap_cubical_complex_base.h:351
Bitmap_cubical_complex_base()
Definition: Bitmap_cubical_complex_base.h:60
void put_data_to_bins(std::size_t number_of_bins)
Definition: Bitmap_cubical_complex_base.h:539
void impose_lower_star_filtration()
Definition: Bitmap_cubical_complex_base.h:821
std::size_t size() const
Definition: Bitmap_cubical_complex_base.h:212
All_cells_iterator all_cells_iterator_begin()
Definition: Bitmap_cubical_complex_base.h:305
virtual std::vector< std::size_t > get_coboundary_of_a_cell(std::size_t cell) const
Definition: Bitmap_cubical_complex_base.h:772
unsigned get_dimension_of_a_cell(std::size_t cell) const
Definition: Bitmap_cubical_complex_base.h:792
unsigned dimension() const
Definition: Bitmap_cubical_complex_base.h:207
Top_dimensional_cells_iterator top_dimensional_cells_iterator_begin()
Definition: Bitmap_cubical_complex_base.h:448
friend std::ostream & operator<<(std::ostream &os, const Bitmap_cubical_complex_base< K > &b)
Definition: Bitmap_cubical_complex_base.h:586
virtual std::vector< std::size_t > get_boundary_of_a_cell(std::size_t cell) const
Definition: Bitmap_cubical_complex_base.h:745
Coboundary_range coboundary_range(std::size_t sh)
Definition: Bitmap_cubical_complex_base.h:358
std::pair< T, T > min_max_filtration()
Definition: Bitmap_cubical_complex_base.h:576
Top_dimensional_cells_iterator top_dimensional_cells_iterator_end()
Definition: Bitmap_cubical_complex_base.h:456
std::vector< std::size_t >::const_iterator Boundary_iterator
Definition: Bitmap_cubical_complex_base.h:339
size_t get_top_dimensional_coface_of_a_cell(size_t splx)
Definition: Bitmap_cubical_complex_base.h:630
T & get_cell_data(std::size_t cell)
Definition: Bitmap_cubical_complex_base.h:816
Boundary_range boundary_range(std::size_t sh)
Definition: Bitmap_cubical_complex_base.h:346
virtual int compute_incidence_between_cells(std::size_t coface, std::size_t face) const
Definition: Bitmap_cubical_complex_base.h:143
virtual ~Bitmap_cubical_complex_base()
Definition: Bitmap_cubical_complex_base.h:84
This is an implementation of a counter being a vector of integers.
Definition: counter.h:32
