11#ifndef BITMAP_CUBICAL_COMPLEX_H_
   12#define BITMAP_CUBICAL_COMPLEX_H_
   14#include <gudhi/Bitmap_cubical_complex_base.h>
   15#include <gudhi/Bitmap_cubical_complex_periodic_boundary_conditions_base.h>
   18#include <tbb/parallel_sort.h>
   30namespace cubical_complex {
   33const bool globalDbg =
false;
   36class is_before_in_filtration;
   53  typedef std::size_t Simplex_key;
   54  typedef typename T::filtration_type Filtration_value;
   55  typedef Simplex_key Simplex_handle;
   70      : T(perseus_style_file), key_associated_to_simplex(this->total_number_of_cells + 1) {
   72      std::clog <<
"Bitmap_cubical_complex( const char* perseus_style_file )\n";
   74    for (std::size_t i = 0; i != this->total_number_of_cells; ++i) {
   75      this->key_associated_to_simplex[i] = i;
   89                         const std::vector<Filtration_value>& top_dimensional_cells)
   90      : T(dimensions, top_dimensional_cells), key_associated_to_simplex(this->total_number_of_cells + 1) {
   91    for (std::size_t i = 0; i != this->total_number_of_cells; ++i) {
   92      this->key_associated_to_simplex[i] = i;
  108                         const std::vector<Filtration_value>& top_dimensional_cells,
  109                         std::vector<bool> directions_in_which_periodic_b_cond_are_to_be_imposed)
  110      : T(dimensions, top_dimensional_cells, directions_in_which_periodic_b_cond_are_to_be_imposed),
  111        key_associated_to_simplex(this->total_number_of_cells + 1) {
  112    for (std::size_t i = 0; i != this->total_number_of_cells; ++i) {
  113      this->key_associated_to_simplex[i] = i;
  140      std::clog <<
"Simplex_handle null_simplex()\n";
  142    return std::numeric_limits<Simplex_handle>::max();
  148  inline std::size_t
dimension()
 const {
return this->sizes.size(); }
  155      std::clog <<
"unsigned dimension(const Simplex_handle& sh)\n";
  157    if (sh !=
null_simplex())
return this->get_dimension_of_a_cell(sh);
  166      std::clog <<
"Filtration_value filtration(const Simplex_handle& sh)\n";
  170    return std::numeric_limits<Filtration_value>::infinity();
  178      std::clog <<
"Simplex_key null_key()\n";
  180    return std::numeric_limits<Simplex_handle>::max();
  186  Simplex_key
key(Simplex_handle sh)
 const {
  188      std::clog <<
"Simplex_key key(const Simplex_handle& sh)\n";
  191      return this->key_associated_to_simplex[sh];
  201      std::clog <<
"Simplex_handle simplex(Simplex_key key)\n";
  204      return this->simplex_associated_to_key[
key];
  214      std::clog <<
"void assign_key(Simplex_handle& sh, Simplex_key key)\n";
  217    this->key_associated_to_simplex[sh] =
key;
  218    this->simplex_associated_to_key[
key] = sh;
  234  typedef typename std::vector<Simplex_handle> Boundary_simplex_range;
  244  class Filtration_simplex_iterator {
  248    typedef std::input_iterator_tag iterator_category;
  249    typedef Simplex_handle value_type;
  250    typedef std::ptrdiff_t difference_type;
  251    typedef value_type* pointer;
  252    typedef value_type reference;
  256    Filtration_simplex_iterator() : b(NULL), position(0) {}
  258    Filtration_simplex_iterator operator++() {
  260        std::clog <<
"Filtration_simplex_iterator operator++\n";
  266    Filtration_simplex_iterator operator++(
int) {
  267      Filtration_simplex_iterator result = *
this;
  272    Filtration_simplex_iterator& operator=(
const Filtration_simplex_iterator& rhs) {
  274        std::clog <<
"Filtration_simplex_iterator operator =\n";
  277      this->position = rhs.position;
  281    bool operator==(
 const {
  283        std::clog <<
"bool operator == ( const Filtration_simplex_iterator& rhs )\n";
  285      return (this->position == rhs.position);
  288    bool operator!=(
 const {
  290        std::clog <<
"bool operator != ( const Filtration_simplex_iterator& rhs )\n";
  292      return !(*
this == rhs);
  295    Simplex_handle operator*() {
  297        std::clog <<
"Simplex_handle operator*()\n";
  299      return this->b->simplex_associated_to_key[this->position];
  302    friend class Filtration_simplex_range;
  305    Bitmap_cubical_complex<T>* b;
  306    std::size_t position;
  316    typedef Filtration_simplex_iterator const_iterator;
  317    typedef Filtration_simplex_iterator iterator;
  321    Filtration_simplex_iterator begin() {
  323        std::clog <<
"Filtration_simplex_iterator begin() \n";
  325      return Filtration_simplex_iterator(this->b);
  328    Filtration_simplex_iterator end() {
  330        std::clog <<
"Filtration_simplex_iterator end()\n";
  332      Filtration_simplex_iterator it(this->b);
  333      it.position = this->b->simplex_associated_to_key.size();
  356      std::clog <<
"Filtration_simplex_range filtration_simplex_range()\n";
  376  std::pair<Simplex_handle, Simplex_handle>
endpoints(Simplex_handle sh) {
  377    std::vector<std::size_t> bdry = this->get_boundary_of_a_cell(sh);
  379      std::clog <<
"std::pair<Simplex_handle, Simplex_handle> endpoints( Simplex_handle sh )\n";
  380      std::clog <<
"bdry.size() : " << bdry.size() <<
"\n";
  385          "Error in endpoints in Bitmap_cubical_complex class. The cell have less than two elements in the "
  387    return std::make_pair(bdry[0], bdry[1]);
  393  class Skeleton_simplex_range;
  395  class Skeleton_simplex_iterator {
  399    typedef std::input_iterator_tag iterator_category;
  400    typedef Simplex_handle value_type;
  401    typedef std::ptrdiff_t difference_type;
  402    typedef value_type* pointer;
  403    typedef value_type reference;
  407        std::clog <<
"Skeleton_simplex_iterator ( Bitmap_cubical_complex* b , std::size_t d )\n";
  411      while ((this->position != b->data.size()) &&
  412             (this->b->get_dimension_of_a_cell(this->position) != this->dimension)) {
  417    Skeleton_simplex_iterator() : b(NULL), position(0), dimension(0) {}
  419    Skeleton_simplex_iterator operator++() {
  421        std::clog <<
"Skeleton_simplex_iterator operator++()\n";
  425      while ((this->position != this->b->data.size()) &&
  426             (this->b->get_dimension_of_a_cell(this->position) != this->dimension)) {
  432    Skeleton_simplex_iterator operator++(
int) {
  433      Skeleton_simplex_iterator result = *
this;
  438    Skeleton_simplex_iterator& operator=(
const Skeleton_simplex_iterator& rhs) {
  440        std::clog <<
"Skeleton_simplex_iterator operator =\n";
  443      this->position = rhs.position;
  448    bool operator==(
 const {
  450        std::clog <<
"bool operator ==\n";
  452      return (this->position == rhs.position);
  455    bool operator!=(
 const {
  457        std::clog <<
"bool operator != ( const Skeleton_simplex_iterator& rhs )\n";
  459      return !(*
this == rhs);
  462    Simplex_handle operator*() {
  464        std::clog <<
"Simplex_handle operator*() \n";
  466      return this->position;
  469    friend class Skeleton_simplex_range;
  472    Bitmap_cubical_complex<T>* b;
  473    std::size_t position;
  484    typedef Skeleton_simplex_iterator const_iterator;
  485    typedef Skeleton_simplex_iterator iterator;
  489    Skeleton_simplex_iterator begin() {
  491        std::clog <<
"Skeleton_simplex_iterator begin()\n";
  493      return Skeleton_simplex_iterator(this->b, this->dimension);
  496    Skeleton_simplex_iterator end() {
  498        std::clog <<
"Skeleton_simplex_iterator end()\n";
  500      Skeleton_simplex_iterator it(this->b, this->dimension);
  501      it.position = this->b->data.size();
  515      std::clog <<
"Skeleton_simplex_range skeleton_simplex_range( unsigned dimension )\n";
  520  friend class is_before_in_filtration<T>;
  523  std::vector<std::size_t> key_associated_to_simplex;
  524  std::vector<std::size_t> simplex_associated_to_key;
  530    std::clog <<
"void Bitmap_cubical_complex<T>::initialize_elements_ordered_according_to_filtration() \n";
  532  this->simplex_associated_to_key = std::vector<std::size_t>(this->data.size());
  533  std::iota(std::begin(simplex_associated_to_key), std::end(simplex_associated_to_key), 0);
  535  tbb::parallel_sort(simplex_associated_to_key.begin(), simplex_associated_to_key.end(),
  536                     is_before_in_filtration<T>(
this));
  538  std::sort(simplex_associated_to_key.begin(), simplex_associated_to_key.end(), is_before_in_filtration<T>(
this));
  542  for (std::size_t i = 0; i != simplex_associated_to_key.size(); ++i) {
  543    this->key_associated_to_simplex[simplex_associated_to_key[i]] = i;
  548class is_before_in_filtration {
  552  bool operator()(
const typename Bitmap_cubical_complex<T>::Simplex_handle& sh1,
  553                  const typename Bitmap_cubical_complex<T>::Simplex_handle& sh2)
 const {
  562    std::size_t dim1 = CC_->get_dimension_of_a_cell(sh1);
  563    std::size_t dim2 = CC_->get_dimension_of_a_cell(sh2);
  573  Bitmap_cubical_complex<T>* CC_;
  578namespace Cubical_complex = cubical_complex;
Filtration_simplex_range provides the ranges for Filtration_simplex_iterator.
Definition: Bitmap_cubical_complex.h:312
Class needed for compatibility with Gudhi. Not useful for other purposes.
Definition: Bitmap_cubical_complex.h:480
Cubical complex represented as a bitmap.
std::pair< Simplex_handle, Simplex_handle > endpoints(Simplex_handle sh)
Definition: Bitmap_cubical_complex.h:376
Bitmap_cubical_complex(const std::vector< unsigned > &dimensions, const std::vector< Filtration_value > &top_dimensional_cells)
Definition: Bitmap_cubical_complex.h:88
Bitmap_cubical_complex(const std::vector< unsigned > &dimensions, const std::vector< Filtration_value > &top_dimensional_cells, std::vector< bool > directions_in_which_periodic_b_cond_are_to_be_imposed)
Definition: Bitmap_cubical_complex.h:107
Definition: Bitmap_cubical_complex.h:354
Bitmap_cubical_complex(const char *perseus_style_file)
Definition: Bitmap_cubical_complex.h:69
Simplex_key key(Simplex_handle sh) const
Definition: Bitmap_cubical_complex.h:186
std::size_t dimension() const
Definition: Bitmap_cubical_complex.h:148
std::vector< Simplex_handle >::iterator Boundary_simplex_iterator
Definition: Bitmap_cubical_complex.h:233
Filtration_value filtration(Simplex_handle sh)
Definition: Bitmap_cubical_complex.h:164
Boundary_simplex_range boundary_simplex_range(Simplex_handle sh)
Definition: Bitmap_cubical_complex.h:348
void assign_key(Simplex_handle sh, Simplex_key key)
Definition: Bitmap_cubical_complex.h:212
static Simplex_key null_key()
Definition: Bitmap_cubical_complex.h:176
Definition: Bitmap_cubical_complex.h:199
unsigned dimension(Simplex_handle sh) const
Definition: Bitmap_cubical_complex.h:153
void initialize_simplex_associated_to_key()
Definition: Bitmap_cubical_complex.h:528
std::size_t num_simplices() const
Definition: Bitmap_cubical_complex.h:133
Skeleton_simplex_range skeleton_simplex_range(unsigned dimension)
Definition: Bitmap_cubical_complex.h:513
static Simplex_handle null_simplex()
Definition: Bitmap_cubical_complex.h:138
virtual ~Bitmap_cubical_complex()
Definition: Bitmap_cubical_complex.h:124
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
