#include <gudhi/Alpha_complex_3d.h>
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <string>
#include <vector>
#include <limits>
using Vector_of_points = std::vector<Point>;
int main(int argc, char **argv) {
  if (argc != 1) {
    std::cerr << "Error: Number of arguments (" << argc << ") is not correct\n";
    std::cerr << "Usage: " << (argv[0] - 1) << " \n";
    exit(-1);
  Vector_of_points points;
  points.push_back(Point(1, -1, -1));
  points.push_back(Point(-1, 1, -1));
  points.push_back(Point(-1, -1, 1));
  points.push_back(Point(1, 1, 1));
  points.push_back(Point(2, 2, 2));
" simplices - " << simplex.
num_vertices() <<
" vertices." << std::endl;
    std::clog << "Iterator on alpha complex simplices in the filtration order, with [filtration value]:" << std::endl;
      std::clog << "   ( ";
        std::clog << vertex << " ";
      std::clog << ") -> "
      std::clog << std::endl;
  return 0;
Simplex Tree data structure for representing simplicial complexes.
Definition: Simplex_tree.h:81
Filtration_simplex_range const & filtration_simplex_range(Indexing_tag=Indexing_tag())
Returns a range over the simplices of the simplicial complex, in the order of the filtration.
Definition: Simplex_tree.h:273
Simplex_vertex_range simplex_vertex_range(Simplex_handle sh) const
Returns a range over the vertices of a simplex.
Definition: Simplex_tree.h:284
static Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
Definition: Simplex_tree.h:537
size_t num_vertices() const
Returns the number of vertices in the complex.
Definition: Simplex_tree.h:574
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:602
size_t num_simplices()
returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:580
Alpha complex data structure for 3d specific case.
Definition: Alpha_complex_3d.h:118
bool create_complex(SimplicialComplexForAlpha3d &complex, Filtration_value max_alpha_square=std::numeric_limits< Filtration_value >::infinity())
Inserts all Delaunay triangulation into the simplicial complex. It also computes the filtration value...
Definition: Alpha_complex_3d.h:435
typename Alpha_shape_3::Point Point_3
Alpha_complex_3d::Point_3 type is either a Alpha_complex_3d::Bare_point_3 (Weighted = false) or a Alp...
Definition: Alpha_complex_3d.h:248
