Author Siargey Kachanovich
Witness complex representation
Definitions
Witness complex is a simplicial complex defined on two sets of points in :
set of witnesses and
set of landmarks .
Even though often the set of landmarks is a subset of the set of witnesses , it is not a requirement for the current implementation.
Landmarks are the vertices of the simplicial complex and witnesses help to decide on which simplices are inserted via a predicate "is witnessed".
De Silva and Carlsson in their paper [21] differentiate weak witnessing and strong witnessing :
weak : is witnessed by if
strong : is witnessed by if
where is a distance function.
Both definitions can be relaxed by a real value :
weak : is -witnessed by if
strong : is -witnessed by if
which leads to definitions of weak relaxed witness complex (or just relaxed witness complex for short) and strong relaxed witness complex respectively.
Strongly witnessed simplex
In particular case of 0-relaxation, weak complex corresponds to witness complex introduced in [21] , whereas 0-relaxed strong witness complex consists of just vertices and is not very interesting. Hence for small relaxation weak version is preferable. However, to capture the homotopy type (for example using Gudhi::persistent_cohomology::Persistent_cohomology ) it is often necessary to work with higher filtration values. In this case strong relaxed witness complex is faster to compute and offers similar results.
Implementation
The two complexes described above are implemented in the corresponding classes
The construction of the Euclidean versions of complexes follow the same scheme:
Construct a search tree on landmarks (for that Gudhi::spatial_searching::Kd_tree_search is used internally).
Construct lists of nearest landmarks for each witness (special structure Gudhi::witness_complex::Active_witness is used internally).
Construct the witness complex for nearest landmark lists.
In the non-Euclidean classes, the lists of nearest landmarks are supposed to be given as input.
The constructors take on the steps 1 and 2, while the function 'create_complex' executes the step 3.
Example 1: Constructing weak relaxed witness complex from an off file
Let's start with a simple example, which reads an off point file and computes a weak witness complex.
#include <gudhi/Simplex_tree.h>
#include <gudhi/Euclidean_witness_complex.h>
#include <gudhi/pick_n_random_points.h>
#include <gudhi/Points_off_io.h>
#include <CGAL/Epick_d.h>
#include <string>
#include <vector>
typedef CGAL::Epick_d<CGAL::Dynamic_dimension_tag> K;
typedef typename K::Point_d Point_d;
typedef std::vector< Vertex_handle > typeVectorVertex;
typedef std::vector< Point_d > Point_vector;
int main(int argc, char * const argv[]) {
std::string file_name = argv[1];
int nbL = atoi(argv[2]), lim_dim = atoi(argv[4]);
double alpha2 = atof(argv[3]);
Point_vector point_vector, landmarks;
point_vector = Point_vector(off_reader.get_point_cloud());
witness_complex.create_complex(simplex_tree, alpha2, lim_dim);
OFF file reader implementation in order to read points from an OFF file.
Definition: Points_off_io.h:122
Simplex Tree data structure for representing simplicial complexes.
Definition: Simplex_tree.h:81
Constructs strong witness complex for given sets of witnesses and landmarks in Euclidean space.
Definition: Euclidean_strong_witness_complex.h:51
Constructs (weak) witness complex for given sets of witnesses and landmarks in Euclidean space.
Definition: Euclidean_witness_complex.h:53
void choose_n_farthest_points(Distance dist, Point_range const &input_pts, std::size_t final_size, std::size_t starting_point, PointOutputIterator output_it, DistanceOutputIterator dist_it={})
Subsample by a greedy strategy of iteratively adding the farthest point from the current chosen point...
Definition: choose_n_farthest_points.h:69
@ random_starting_point
Definition: choose_n_farthest_points.h:34
Example2: Computing persistence using strong relaxed witness complex
Here is an example of constructing a strong witness complex filtration and computing persistence on it:
#include <gudhi/Euclidean_strong_witness_complex.h>
#include <gudhi/Persistent_cohomology.h>
#include <gudhi/choose_n_farthest_points.h>
#include <boost/program_options.hpp>
#include <string>
#include <vector>
#include <limits>
using K = CGAL::Epick_d<CGAL::Dynamic_dimension_tag>;
using Point_d = K::Point_d;
using Point_vector = std::vector<Point_d>;
void program_options(int argc, char * argv[], int & nbL, std::string& file_name, std::string& filediag,
int main(int argc, char * argv[]) {
std::string file_name;
std::string filediag;
int p, nbL, lim_d;
program_options(argc, argv, nbL, file_name, filediag, max_squared_alpha, p, lim_d, min_persistence);
Point_vector witnesses, landmarks;
if (!off_reader.is_valid()) {
std::cerr << "Witness complex - Unable to read file " << file_name << "\n" ;
exit(-1);
witnesses = Point_vector(off_reader.get_point_cloud());
std::clog << "Successfully read " << witnesses.size() << " points.\n" ;
std::clog << "Ambient dimension is " << witnesses[0].dimension() << ".\n" ;
std::back_inserter(landmarks));
strong_witness_complex.create_complex(simplex_tree, max_squared_alpha, lim_d);
std::clog <<
"The complex contains " << simplex_tree.
num_simplices () <<
" simplices \n" ;
std::clog <<
" and has dimension " << simplex_tree.
dimension () <<
" \n" ;
pcoh.init_coefficients(p);
pcoh.compute_persistent_cohomology(min_persistence);
if (filediag.empty()) {
pcoh.output_diagram();
} else {
std::ofstream out(filediag);
pcoh.output_diagram(out);
out.close();
return 0;
namespace po = boost::program_options;
po::options_description hidden("Hidden options" );
hidden.add_options()("input-file" , po::value<std::string>(&file_name),
"Name of file containing a point set in off format." );
po::options_description visible("Allowed options" , 100);
Filtration_value default_alpha = std::numeric_limits<Filtration_value>::infinity();
visible.add_options()("help,h" , "produce help message" )("landmarks,l" , po::value<int>(&nbL),
"Number of landmarks to choose from the point cloud." )(
"output-file,o" , po::value<std::string>(&filediag)->default_value(std::string()),
"Name of file in which the persistence diagram is written. Default print in standard output" )(
"max-sq-alpha,a" , po::value<Filtration_value>(&max_squared_alpha)->default_value(default_alpha),
"Maximal squared relaxation parameter." )(
"field-charac,p" , po::value<int>(&p)->default_value(11),
"Characteristic p of the coefficient field Z/pZ for computing homology." )(
"min-persistence,m" , po::value<Filtration_value>(&min_persistence)->default_value(0),
"Minimal lifetime of homology feature to be recorded. Default is 0. Enter a negative value to see zero length "
"intervals" )("cpx-dimension,d" , po::value<int>(&dim_max)->default_value(std::numeric_limits<int>::max()),
"Maximal dimension of the strong witness complex we want to compute." );
po::positional_options_description pos;
pos.add("input-file" , 1);
po::options_description all;
all.add(visible).add(hidden);
po::variables_map vm;
po::store(po::command_line_parser(argc, argv).options(all).positional(pos).run(), vm);
po::notify(vm);
if (vm.count("help" ) || !vm.count("input-file" )) {
std::clog << std::endl;
std::clog << "Compute the persistent homology with coefficient field Z/pZ \n" ;
std::clog << "of a Strong witness complex defined on a set of input points.\n \n" ;
std::clog << "The output diagram contains one bar per line, written with the convention: \n" ;
std::clog << " p dim b d \n" ;
std::clog << "where dim is the dimension of the homological feature,\n" ;
std::clog << "b and d are respectively the birth and death of the feature and \n" ;
std::clog << "p is the characteristic of the field Z/pZ used for homology coefficients." << std::endl << std::endl;
std::clog << "Usage: " << argv[0] << " [options] input-file" << std::endl << std::endl;
std::clog << visible << std::endl;
exit(-1);
Options::Filtration_value Filtration_value
Type for the value of the filtration function.
Definition: Simplex_tree.h:88
void initialize_filtration()
Initializes the filtration cache, i.e. sorts the simplices according to their order in the filtration...
Definition: Simplex_tree.h:916
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:602
size_t num_simplices()
returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:580
Structure representing the coefficient field .
Definition: Field_Zp.h:27
Computes the persistent cohomology of a filtered complex.
Definition: Persistent_cohomology.h:52
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
Example3: Computing relaxed witness complex persistence from a distance matrix
In this example we compute the relaxed witness complex persistence from a given matrix of closest landmarks to each witness. Each landmark is given as the couple (index, distance).
#define BOOST_PARAMETER_MAX_ARITY 12
#include <gudhi/Witness_complex.h>
#include <iostream>
#include <fstream>
#include <utility>
#include <string>
#include <vector>
using Nearest_landmark_range = std::vector<std::pair<std::size_t, double>>;
using Nearest_landmark_table = std::vector<Nearest_landmark_range>;
Nearest_landmark_table nlt = {
{{0, 0.0}, {1, 0.1}, {2, 0.2}, {3, 0.3}, {4, 0.4}},
{{1, 0.0}, {2, 0.1}, {3, 0.2}, {4, 0.3}, {0, 0.4}},
{{2, 0.0}, {3, 0.1}, {4, 0.2}, {0, 0.3}, {1, 0.4}},
{{3, 0.0}, {4, 0.1}, {0, 0.2}, {1, 0.3}, {2, 0.4}},
{{4, 0.0}, {0, 0.1}, {1, 0.2}, {2, 0.3}, {3, 0.4}}
witness_complex.create_complex(simplex_tree, .41);
std::clog <<
"Number of simplices: " << simplex_tree.
num_simplices () << std::endl;
pcoh.init_coefficients(11);
pcoh.compute_persistent_cohomology(-0.1);
Constructs (weak) witness complex for a given table of nearest landmarks with respect to witnesses.
Definition: Witness_complex.h:38
