11#ifndef TANGENTIAL_COMPLEX_UTILITIES_H_
12#define TANGENTIAL_COMPLEX_UTILITIES_H_
14#include <CGAL/Dimension.h>
15#include <CGAL/Combination_enumerator.h>
16#include <CGAL/IO/Triangulation_off_ostream.h>
18#include <boost/container/flat_set.hpp>
31namespace tangential_complex {
38:
public std::atomic<T> {
39 typedef std::atomic<T> Base;
43 Atomic_wrapper(
const T &t) : Base(t) { }
45 Atomic_wrapper(
const std::atomic<T> &a) : Base(a.load()) { }
47 Atomic_wrapper(
const Atomic_wrapper &other) : Base(other.load()) { }
49 Atomic_wrapper &operator=(
const T &other) {
54 Atomic_wrapper &operator=(
const std::atomic<T> &other) {
55 Base::store(other.load());
59 Atomic_wrapper &operator=(
const Atomic_wrapper &other) {
60 Base::store(other.load());
67typename K::Vector_d& normalize_vector(
typename K::Vector_d& v,
69 v = k.scaled_vector_d_object()(
70 v,
typename K::FT(1) / std::sqrt(k.squared_length_d_object()(v)));
74template<
typename Kernel>
76 typedef typename Kernel::FT FT;
77 typedef typename Kernel::Point_d Point;
78 typedef typename Kernel::Vector_d Vector;
79 typedef typename std::vector<Vector>::const_iterator const_iterator;
82 std::vector<Vector> m_vectors;
84 std::size_t origin()
const {
88 void set_origin(std::size_t o) {
92 const_iterator begin()
const {
93 return m_vectors.begin();
96 const_iterator end()
const {
97 return m_vectors.end();
100 std::size_t size()
const {
101 return m_vectors.size();
104 Vector& operator[](
const std::size_t i) {
108 const Vector& operator[](
const {
112 void push_back(
const Vector& v) {
113 m_vectors.push_back(v);
116 void reserve(
const std::size_t s) {
117 m_vectors.reserve(s);
122 Basis(std::size_t origin) : m_origin(origin) { }
124 Basis(std::size_t origin,
const std::vector<Vector>& vectors)
125 : m_origin(origin), m_vectors(vectors) { }
127 int dimension()
const {
128 return static_cast<int> (m_vectors.size());
134template <
typename Kernel,
typename Po
int_range>
135std::ostream &export_point_set(
137 Point_range
const& points,
139 const char *coord_separator =
141 typename Kernel::Construct_cartesian_const_iterator_d ccci =
142 k.construct_cartesian_const_iterator_d_object();
144 os << points.size() <<
"\n";
146 typename Point_range::const_iterator it_p = points.begin();
147 typename Point_range::const_iterator it_p_end = points.end();
149 for (; it_p != it_p_end; ++it_p) {
150 for (
auto it = ccci(*it_p); it != ccci(*it_p, 0); ++it)
151 os << CGAL::to_double(*it) << coord_separator;
162template <
typename Elements_container,
typename Output_iterator>
163void combinations(
const Elements_container elements,
int k,
164 Output_iterator combinations) {
165 std::size_t n = elements.size();
166 std::vector<bool> booleans(n,
false);
167 std::fill(booleans.begin() + n - k, booleans.end(),
true);
169 boost::container::flat_set<std::size_t> combination;
170 typename Elements_container::const_iterator it_elt = elements.begin();
171 for (std::size_t i = 0; i < n; ++i, ++it_elt) {
173 combination.insert(*it_elt);
175 *combinations++ = combination;
176 }
while (std::next_permutation(booleans.begin(), booleans.end()));
