sparsify_point_set.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Clement Jamin
4 *
5 * Copyright (C) 2016 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef SPARSIFY_POINT_SET_H_
12#define SPARSIFY_POINT_SET_H_
13
14# include <boost/iterator/function_output_iterator.hpp>
15
16#include <gudhi/Kd_tree_search.h>
17#ifdef GUDHI_SUBSAMPLING_PROFILING
18#include <gudhi/Clock.h>
19#endif
20
21#include <cstddef>
22#include <vector>
23
24namespace Gudhi {
25
26namespace subsampling {
27
48template <typename Kernel, typename Point_range, typename OutputIterator>
49void
51 const Kernel &k, Point_range const& input_pts,
52 typename Kernel::FT min_squared_dist,
53 OutputIterator output_it) {
55 Kernel, Point_range> Points_ds;
56
57#ifdef GUDHI_SUBSAMPLING_PROFILING
58 Gudhi::Clock t;
59#endif
60
61 Points_ds points_ds(input_pts);
62
63 std::vector<bool> dropped_points(input_pts.size(), false);
64
65 // Parse the input points, and add them if they are not too close to
66 // the other points
67 std::size_t pt_idx = 0;
68 for (auto const& pt : input_pts) {
69 if (dropped_points[pt_idx++])
70 continue;
71
72 *output_it++ = pt;
73
74 // If another point Q is closer that min_squared_dist, mark Q to be dropped
75 auto drop = [&dropped_points] (std::ptrdiff_t neighbor_point_idx) { dropped_points[neighbor_point_idx] = true; };
76 points_ds.all_near_neighbors2(pt, min_squared_dist, min_squared_dist, boost::make_function_output_iterator(std::ref(drop)));
77 }
78
79#ifdef GUDHI_SUBSAMPLING_PROFILING
80 t.end();
81 std::cerr << "Point set sparsified in " << t.num_seconds()
82 << " seconds." << std::endl;
83#endif
84}
85
86} // namespace subsampling
87} // namespace Gudhi
88
89#endif // SPARSIFY_POINT_SET_H_
Spatial tree data structure to perform (approximate) nearest and furthest neighbor search.
Definition: Kd_tree_search.h:70
void sparsify_point_set(const Kernel &k, Point_range const &input_pts, typename Kernel::FT min_squared_dist, OutputIterator output_it)
Outputs a subset of the input points so that the squared distance between any two points is greater t...
Definition: sparsify_point_set.h:50
